Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Machine just won't start
Machine is 5 yrs old since home was built I am a single guy, use it twice a month during the 5 yrs. A cycle ran and the water did not drain and now it won't run even after I drained all the water cleared all the lines. All breakers are good. A Whirlpool Series 980 Any suggestions??
  • 2 more comments
  • pwcochren Dec 28, 2008
    I will check it out and most likely replace it Thanks
  • Curtrpt Jan 02, 2009
    I went to start my washer and it now will not start. I never had problems in the past and I have already checked the breaker. It's a stackable and the dryer still works fine but now the washer doesn't appear to be getting any electricity. Please help!
  • rci2 Feb 13, 2009
    Maytag LSG78066AAE.  Completed last load perfectly.  When I tried to run the next load, the tub would not fill with water.  Not hot or cold. But the spin cycle still works.  What are two most likely problems?
    Thanks very much!
  • Anonymous Mar 13, 2014
    Hello - my Whirlpool 980 series suddenly stopped working. It won't drain or fill or wash. The buttons light up when pushed, but nothing happens - except that the heating coil heats up. Any suggestions?
I had the same problem with a LSE7806ADE. The fuse kept blowing but the lid switches were OK when checked with a multi-meter. It truned out the the switch arm ( AP4026768 ) somehow was bent and would not engage the two lid switches properly. I bent it back, replaced the fuse again and all seems to be working fine.
Posted on May 04, 2009
  • 3 Answers
Replace the "lid check switch". This seems to be a comon problem with this washer.
If the switch fails, the only thing that it will do is fill it with water. Everything else will work only if the switch is working.
Posted on Feb 08, 2009
  • 659 Answers
Will it fill and wash? The lid switch will only stop the spin cycle
Posted on Dec 28, 2008
  • 115 Answers
You have probably a bad lid switch
Water is going into the washer very slow during the rinse and spin cycle, also not carring the softner into the machine
Machine is not that old, the wash cycle water intake is ok? maybe bad water inlet valve? try seeing how it works on only cold and only hot water, change the hose lines from hot to cold and see what happens? as for the fabric thingy may have abad clogged line or a tiny hole in line and its going elsewhere
Sep 21, 2014 | Crosley Washing Machines
Water not hot, dishes not clean or dry, and may not be draining entirely?
hay audra ,it seems like your heating element is bad , test it for continuity or open the door 2 minutes after you start the cycle (caution it may be hot ) good luck APPLIANCES R EN
Mar 14, 2013 | LG LDF8812 Stainless Steel Built-in...
I am looking to buy a used Frigidaire GLWS1233AS2 Top Load Washer and GLER331AS2 . They are supposed to be 3 years old. Are they good machines or do they have lots of problems?
Mine is 10 yrs old and I am just now having a problem. Clothes are too damp after last spin cycle. Hopefully, I'll get an answer here soon. Another problem I noticed a few months after I got it, with this model, is the fabric softener dispenser on top of the agitator. You have to remove it every single time and clean it. I added a little water to it before adding fabric softener and thought that would help to stretch the cleaning to maybe once or twice a week. Don't do it! I started to smell mildew and found out why. The agitator shaft that this dispenser sits on was caked with old fabric softener. I just use the blue Downey ball now. The fabric dispenser stinks but I have had 10 yrs of good washing.
Feb 14, 2013 | Frigidaire GLWS1233A Top Load Washer
What controls the water cut-off feed during cycles and when dail is set in off position.
There are electronically turned on and shut off water valves that are controlled by a water level sensor which varies based on what load size/water level you need Small, Medium, or Large. So if the valve gets stuck open since it's an old machine, the water will just keep coming in. But let me ask you this? If you turn the house water value on n NOW...will the wash machine just start filling? If so, it means your valve is stuck open so you would need to replace the water valve which is like $50 online. If the house water valve is on, and when you start the washing machine it starts filling, but just keeps on filling...that's probably because your water level sensor is messed up. So you have 2 things to check...is it the washer water valve is stuck open? or is it the water level sensor that isn't sensing when the washer is full so it just keeps filling it.
Dec 21, 2017 | Home
Dishwasher only a couple of months old. Ran it
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Aug 25, 2009 | Dishwashers
Adg450 about 5 yrs old. Beep Beep.....Beep
Hi, I have a very simular problem, I have just read that running the water in the kitchen sink until its hot may work, if not could you please let me know if you get an answer to this problem,
Thanks
Peter
Aug 01, 2009 | Whirlpool ADG450 Slim-Line Built-in...
GE Adora Frontload Washer shredding clothes
We were having the same problems with ripped clothing and longer cycles. Our rubber seal by the door has ripped twice now causing massive amounts of water to run out. I learned through other threads that many people are having these problems and was told that zipping up zippers and turning jackets and clothing with big heavy stuff on them in side out to protect from ripping the clothing and the rubber seal. I removed the panel on the front bottom of the machince and there is a small gray cover that housed the coin trap. Mine was clogged and once I cleared that out, my cycle times got better. I hope this was somewhat helpful. We definitely won't be purchasing another GE front loader!!
Mar 29, 2009 | GE WSXH208A Front Load Washer
Hot water goes into cold water washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG WM-1832C Front Load Washer
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
367 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
