Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven won't heat
The broiler works, the stove top works, however when the bake is presses, it shows 100 degrees, and nothing else. Is this an ignitor? Where is this located?
  • 76 Answers
This could be the ignitor. The ignitor is located under the bottom of your oven. you get to it from the inside of the oven. A quick check though is to set the oven to bake and wait about 30 seconds and see if you can see a faint orange glow from the bottom inside of the oven. If you do then your ignitor is probably working ok and the problem lies somewhere else.
Posted on Aug 12, 2007
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven wontr come on, but broiler does//
you have a bad ignitor part number 74007498 and it's around 65 dollars.pull out the racks and remove the floor of the stove and you'll see the ignitor screwed to the burner tube,wet the screws with a wet paper towel,they will come out easier or if it makes it any easier remove the tube and then remove the ignitor.first start the stove if the ignitor glows but doesn't ignite the flame in 40 seconds or less it's bad,if it doesn't glow at all check it for continuity but it sounds like the ignitor is bad,if the new ignitor comes with wire nuts,cut the wires close to the body of the old ignitor,trim some of the wires back on the new ignitor and wire nut them together with the ceramic wire nuts,on some you can get the screws out of the ignitor,cut the wires close to the body,mount the new ignitor,trim back the wires on the new ignitor and wire nut them together and you're done,it doesn't matter how long the wires are just as long as the wire nuts are under the floor and away from the tube.it might help to remove the bottom draw to get at the wires,hope this helps and good luck.
Dec 11, 2011 | Maytag MGS5870 Gas Kitchen Range
Bake cycle wont work gas kenmore with electric controls you can set temp it goes to preheat and nothing happens broiler works and all the tops work
here is a tip i wrote covering that
What the problem is when your gas oven ignitor glows,but no heat for the...
MessageRate.ThreadID = 9947539; MessageRate.ProductID = 0;
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Aug 03, 2011 | Kenmore Ovens
Model: JDS8850AAS -- Oven won't preheat above 150
Hope this helps
Gene
Aug 02, 2011 | Jenn-Air Ovens
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 03, 2011 | Microwave Ovens
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Top oven not heating up on BAKE, broiler gas and flames come on. Stove top burners work, Bottom oven heats for BAKE and BROIL.
heatman101
Jan 08, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Stove top and broiler work Oven won't heat
the way to check this is to first see if ignitor comes on or put an amp clamp meter on it. the ignitor needs to draw 2.8 amps or more to engage the gas valve. if it doesnt lite or draw any amps at all. check voltage to bake ignitor. it will be the ignitor most likely. but the gas valve or control could be bad.
Aug 04, 2010 | Amana AGR5835QD Gas Kitchen Range
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
187 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
