Question about Sansui COM1307AD 13 in. Combo
Sansui 13" Combo comes on, plays fine for 5 min, then turns off
Once this happens, I can turn the tv back on, but screen remains blank, no sound, no anything. Sounds to me like the sleep timer somehow got set, but can't seem to turn it off or fix the problem. I'm wondering if the tube is going bad and once warmed up shuts down, but there's no sound either. It just seems to shut down after about 5 min.
  • 556 Answers
SOURCE: sansui tmv1916 tv no pic
have a sansui tv with a date of sept 2002 i bought the tv because it was on sale and have since lost the reciepts. anyways , no i need the tv and when powered up there is no picture but the sound comes on fine. i turnd it upside down and beat it and shook it and the pic came on for a min only to turn back off in 5-6 minutes. help. oh and i dont have electrical or circuit knowledge but willing to change a bulb or fuse. as you say that sound is ok and picture also comes some time so please check loose contact in luminance section of chroma ic . weak signal may cause rolling and intermittant picture problem for that checkloose near antena socket thanks
Posted on Sep 10, 2007
SOURCE: Need a remote control code for a Sansui TDC2075 TV/VCR/DVD combo
Contact Fox International parts at 1-800-321-6993
or Sansui troubleshooting hotline at 800-289-0980
thanks
Posted on Nov 13, 2007
  • 78 Answers
SOURCE: Sansui TV/VCR 13" color
there is what is called a "dew sensor" in a lot of vcr's that keep you from playing a tape if it senses moisture in the unit because a tape will stick to the video head and get all bunged up. sometimes they go bad and will keep you from playing a tape even when there is no moisture present. if your are electronically inclined you can take the back off and locate the dew sensor, then disconnect it. the constant whirring noise is the unit's way of trying to dry off the video head cylinder. the dew sensor, which is usally located behind the video head, is a dark grey thing about a half inch by half inch and has two wires going to it.
Posted on May 05, 2008
jmgldsmth
  • 2005 Answers
SOURCE: Sansui tv shuts off by itself after being turned on.
the relay on the power board needs to be replaced; if you feel confident to do this:unplug the tv wait about a 1/2 hour then remove the tv's case carefully look for a small black or, brown box about 1/2" x 1" x 1/2" this relay should have a designation such as Rly 1 printed on the circuit board it must be unsoldered and, removed the numbers on the relay can be entered into a search engine to find a replacement
Posted on May 03, 2009
SOURCE: Sansui 13" DTV1300 shuts itself off
My girlfriend had the same issue with her 1300a. We saw on another forum that they took off the extra AV panel and infared receiver, so we opened it up. We couldn't really find either, but when we tightened all the plugs up things seem to be working fine again. Back to watching the Lifetime channel :(
Posted on Aug 02, 2009
Hi i have an orion 24in led tv, I use it for my Xbox. So basically before it used to work fine but now it sometimes goes to standby mode and then comes on. sometimes this happens once in an hour and...
You have a bad "signal board".Some call this the main board. In this case the T-con board is in the signal board (main board) and not a separate board,as other TVs have. You will need to replace the board that has been reworked. A new replacement board will fail. Visit Sansui.com and ask for a reworked board. Thanks for asking. Matt of Martins TV Repair.
Sep 11, 2013 | Orion 24RTC 24 in. TV
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
13" sansui AC/DC 12 volt use
Did you check the fuse inside the plug on the 12volt cord?
Feb 01, 2009 | Sansui COM312AD 13" TV/VCR Combo
Screen turns black except for one inch around the outer edge
Use the tv/cap/text button to turn off the text box function of the closed captioning.
Jan 26, 2009 | Sansui COM3101 13" TV/VCR
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Sansui tmv1916 tv no pic
Sep 10, 2007 | Sansui TVM1916 19" TV
Televison & Video Logo
29 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
