Question about Nintendo DS Lite Console
Both my screens keep going white
If you twist the bottom half slightly it comes back on.
    Scholar:
  • 168 Answers
Your ribbon cables need to be properly cleaned and reinserted. the connection is loose on them. I'll be happy to do this for you.
I have repaired many units.
Thanks
ninja_freak318@hotmail.com
Posted on Jan 03, 2009
I was cleaning the lint catcher while the dryer was on and dropped a washcloth into it. How do I get the washcloth out?
first unplug the unit then remove lint trap then try a stiff wire with a slight curl hook on the end a hanger will do its a smooth chamber push it till it hits it or tuches the bottom twist the wire pull it should come out,if this dont work u half to pull the back of and pull the dryer vent filter tube off with screws at the bottom and it should be there..
Apr 09, 2011 | Estate Dryers
My acer aspire notebook is only showing the bottom half of the screen, the top half is white
Grab your screen...right hand on top left hand on bottom. Apply opposite force and attempt to twist screen. If it corrects itself, gets better, gets worse etc...screen is getting ready to be totally shot. Been working on this LCD now for 6 months, just have to twist it here and there to get it to stop turning white. If it does nothing, it's shot. You have to get replacement screen. They are inexpensive and relatively easy to replace.
Jan 12, 2011 | Computers & Internet
When I switch on an error is occuring : Dredgdraw
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
The white thing on the side is for the cappuccinatore. It slides on with a twist. The hose goes into your milk. You twist the little knob on the top when it is steaming until the milk goes up the tube and produces the foam. Once you get the foam going you won't have to move the knob again. Just keep everything clean.
Dec 29, 2009 | Saeco Royal Professional Espresso Machine
The cd wont go in the console i push it in and it wont take it wat do i do
Have you ever performed a force eject from the PS3 by holding down the eject button
If you have this can cause the tack to become unaligned and thus rejects the disk
If you are under warranty that's the way to go if not a repair shop
Or if you do know your way around a PS3 bluray drive then here's how I align my drive
    1. Drive teeth can get terribly misaligned because of worn gear teeth, you may find it easier to reassemble the drive in the loaded position.
    2. With your Blu-ray drive open, remove the platform that holds the rollers. The only one screw is circled in red. Be careful about touching the plastic bumpers circled in blue. Short instructions under "Tips", in case you do.
    3. Twist the white gear denoted with yellow clockwise until the the gear separates from the black platform on the left hand side of the drive. Practically every gear in this area moves every other gear, but the white one seems the easiest to twist. Keep twisting until the two catches circled in green are completely lowered.
    4. Realign the black platform and twist the white gear counterclockwise until the two catches are fully raised. These catches keep you from inserting a second disc. You should not have to twist the white gear fully counterclockwise and it is a good idea not to. Make sure the left black platform is not tight against anything - especially the stuff towards the bottom edge.
    5. Pull the rollers outwards as the pink arrows indicate and screw the roller platform back onto the drive. When this is done, your rollers should be slightly loose. Work with the rollers and the white gear until they were just tight enough to loosely hold a CD as though the drive were reading it.
    6. Insert a junk CD along the top half of the drive as though the drive were accepting it. Pay attention to how the junk CD locks into place as though you still cared about it.
    7. While holding the CD in its loaded position, pop the top half of the Blu-ray drive onto the bottom half. You can shake it lightly, but if it doesn't come together smoothly, something might be misaligned. Go back and tweak until it comes together with relative ease. Don't forget the white magnet.
    8. Screw everything (that you feel like) back together, boot up your PS3, and eject your junk CD. It should come out smoothly and be re-accepted smoothly.
    If this has been some use to you then a rating would be great
    Thanks
    Jul 22, 2009 | Sony Playstation 3 (PS3) Console
    Game disc will not eject itself (eject not
    Or is you do know your way around a PS3 bluray drive then here's how I align my drive
    The photo I can provide if you wish cant post it here
    Thanks
    TV Keeps flashing Fuzzy black and white static then the picture appears
    The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
    Jul 19, 2008 | Sony KV-36XBR450 36" TV
    Laptop Screen White
    Yup. Bad lcd. If under warranty, have the manufacturer replace it. If not under warranty, visit ebay for the least expensive lcd's. Won't find them cheaper anywhere else. Just buy from a seller with a decent rating. Some are offering 100-120 day warranties on new lcd's. You can also find used ones there, as is.
    Oct 26, 2007 | HP Pavilion dv1000 Notebook
    PS3 rejects disc's
    simple , try cleaning your disc first, then put in PS3...
    Aug 09, 2007 | Sony Playstation 3 (PS3) Console
    Front screen only shows the time
    I have had a simular problem with mine and just fixed it. My phone was doing simular things, but it would also sometimes not show the outside display, or half would be upsite down. Also occasionally when I opened the phone I only saw a white screen. **FIX** There is a small ribbon cable that comes from the top half (w/ the screen) and connects into the circuit board in the bottom half (under battery). It came loose which caused all of my problems. If you clean that connection and put the phone back together it should be good as new.
    Jun 25, 2007 | Motorola Mobility RAZR V3
    Nintendo DS Lite Console Logo
    57 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Zhenya Ogorodnikov
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
