Question about Denon AVR588 Receiver
No audio from PS3.
I am having difficulty getting audio from PS3 through denon AVR-688 receiver. How do I hook it up, correctly?
If you are hooking your PS3 through HDMI, there will be no sound since the Denon does not support sound through HDMI. I am using a Fiber Optic cable for my sound.
Then go into your Sound Settings in your PS3 and select what sound source you are using.
Posted on Feb 24, 2009
Works great, plenty of plug-ins, easy set up, but you get 2 hdmi ins 1 out. hdmis' work great one cable for sound and video but the denon avr588 doesn't accept sound through the hdmi cable.(it's noted in the manual) why not? i don't understand. so you go with optical or coaxial for audio. it works but extra cables.
Posted on Dec 29, 2008
DENON AVR-1912 PS3 ISSUE
You might just have a handshaking issue between your PS3 and your receiver. See if there are any firmware upgrades for your PS3, Receiver or both. This usually takes care of the problem. If not - your receiver has a 2 or 3 year MFG Warranty. Have it checked out or exchanged.
May 02, 2012 | Denon AVR1912
Electronicaly challenged
Could you please tell me what is hooked up to your receiver and via what inputs? Thanks.
Jan 16, 2008 | Denon AVR-2308CI
Denon avr-688
I have the same problem with my AVR-688, were you able to find a help?
Sep 18, 2009 | Denon AVR688
I am having trouble hooking up my xbox through my denon avr 688. I can get audio but no video. Help me, please.
Are you using an hdmi or a component vid from the xbox to the avr? and a hdmi from the avr to the tv? Some receivers only pass through not upscale the video. My xbox uses the component vid out to my avr so I have to also use component to my tv from my avr.
Aug 19, 2009 | Audio Players & Recorders
I am having troubling hooking up my PS3 to my denon AVR-1907 receiver. I am using the PS3 component inputs and hooking them up to the "VCR" input.
Connect your component cable to the PS3 OUTPUT (there is no input) and connect that to the component IN on your receiver.
Jun 14, 2009 | Denon AVR-1907 Receiver
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Denon AVR-688 Dolby Digital issues
IT IS ALWAYS BEST TO CONNECT ANALOG AUDIO IN ADDITION TO THE OPTICAL, COAXIAL OR HDMI AUDIO CONNECTION. IF USING OPTICAL OR COAXIAL CONNECTIONS BE SURE TO CONFIGURE IT IN THE RECEIVERS DIGITAL ASSIGNMENT AREA IN SETUP.
ALSO, ON THE FRONT OF THE RECEIVER IS AN INPUT MODE BUTTON, PRESS THIS BUTTON UNTIL AUTO IS DISPLAYED
Jan 03, 2009 | Denon AVR688
No sound when ps3 is hooked up to a denon avr 1609
The 1609 only has video on the HDMI. No audio comes through the HDMI cables. Hook up an optical cable between your ps3 and the receiver and you should be good to go.
Dec 29, 2008 | Denon AVR588 Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
Denon AVR588 Receiver Logo
286 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
