Question about Sony STR-DE575 Receiver
Only center speaker is working. L R speakers still work on 2 channel mode. I have checked the connections and tried each speaker independently to ensure they are in good order. Thanks for any input even if it is to scrap it and purchase a new one.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Try each speaker on test tone.
    Change amp menu options and surround modes.
    Reset receiver, might be procedure available in user manual.
Thank you. We purchased a Harmon Kardon AVR-154 and discarded the Sony.
Posted on Jan 01, 2009
My center speaker connection is faulty?
There should be some fault to internal output circuit.
May 11, 2013 | Philips Audio Players & Recorders
Hi I have bought a new sony DAV-DZ310 model home theatre.I have connected all the speakers and a woofer.All are working fine except the center speaker.It is not at all working.I have made the connections...
This may not be Dependant on the Music or DVD, but with the setting on the Home Theater system. Try out all the modes - such as 2 Speaker, Multi etc. within the Home Theatre system. In one of the mode only the center speaker works.
Hope this helps. Good Luck.
~SmokinJoe~
May 24, 2011 | Audio Players & Recorders
I've had my Denon AVR-2308CI receiver for 3 years and last week I turned it on to watch a movie and there is no sound coming from my rear speakers? I have a 5 speaker set up (3 in front and 2 in the rear)...
On the front display of the unit, you should have indicator icons that light up if a speaker is being used. Are there only 3 speakers lite up, or are there 5? As a quick check, make sure your speaker connections are secure, and then make sure your surround mode is set to a 5 channel surround mode. 5 channel Stereo is a good one to test with. Also, you can hit the "test" button to see if the speakers are connected and working, it will give a test signal out of each speaker independently. Let me know what you find, and I can answer more.
Mar 05, 2011 | Denon AVR-2805 Receiver
Rear speakers are dead, never got them to work. Changed front to back and rears work so speakers and wireing are good. Is it possible that because I did not hook up a center speaker this is the problem?
if its a 5.1 channels it means 2 front speakers,2 rear speakers or either the center speaker or the subwoofer.try to hook up either center speaker or subwoofer.
Jun 05, 2010 | JVC RX-888V Receiver
Back surround speakers dont work.
If the display reads 2 chan then that means stereo, and the sound mode is not in any type of surround processing. For your surround speakers to operate you must select a surround sound mode.
Dec 06, 2009 | Audio Players & Recorders
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Outside speakers
The two volume controls only work independently when you set the jukebox to 2 channel and mono. One controls the jukebox, the other controls the speakers. There are 3 switches to change on the amp before it will work.
Dave F.
Jul 28, 2008 | Wurlitzer Jukebox 1015 One More Time...
AV-DV75 center speaker works surround speakers do not
If all others had been fine before this problem arose, and you are sure that you haven't changed anything in your amplifier's channel selection menus, the problem might be deeper to solve! Try these out; 1-If the amplifier has a test menu to check out all channels plugged in, activate it. You must be able to get sound, which is like rustle, from each speaker. 2- Check your plugs, cables etc. be sure that there isn't any short circuit 3- Grab your amplifier's remote control and find the "channel selection menu" that allows you to increase and decrease volume levels for each speaker independently.
Apr 15, 2007 | Aiwa AV-DV75
Sony STR-DE575 Receiver Logo
259 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
