Question about Acer Aspire 1310XC Notebook
Laptop ACER 1310 - DC Input in Short Circuit
I am looking for the Electrical Diagram for the ACER 1310 Laptop.
The DC input is in Short Circuit and blow the Power Supply
Kind Regards
N.Y.
2000 ranger wipers dont work
Do you know what a wiring diagram is ? How to use a DVOM - digital volt ohm meter to test automotive electrical circuit's ? Do you know anything about automotive electrical ? Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. Year , make , model and engine size . Under system click on body & accessories , then under subsystem click on wiper/washer . Click the search button then the blue link . Looking at the diagram I see the wipers are controlled by an electronic module (GEM) . The switch is an input to the GEM which controls relays to turn on the wipers . Do you know what DTC'S - diagnostic trouble codes are ?
B1431 Wiper Brake/Run Relay - Circuit Failure GEM/CTM GO to Pinpoint Test A . B1432 Wiper Brake/Run Relay Short to Battery GEM/CTM GO to Pinpoint Test A . B1434 Wiper Hi/Lo Speed Relay Circuit Failure GEM/CTM GO to Symptom Chart. B1436 Wiper Hi/Lo Speed Relay Circuit Short to Battery GEM/CTM GO to Pinpoint Test C . B1438 Wiper Mode Select Switch Circuit Failure GEM/CTM GO to Symptom Chart. B1441 Wiper Mode Select Switch Input Short to Ground GEM/CTM GO to Symptom Chart. B1446 Wiper Park Sense Circuit Failure GEM/CTM GO to Pinpoint Test D . B1450 Wiper/Washer Interval Delay Switch Input Circuit Failure GEM/CTM GO to Symptom Chart. B1453 Wiper/Washer Interval Delay Switch Input Short to Ground GEM/CTM GO to Symptom Chart. B1458 Wiper/Washer Pump Motor Relay Circuit Failure GEM/CTM GO to Pinpoint Test E . B1460 Wiper/Washer Pump Motor Relay Coil Short to Battery GEM/CTM GO to Pinpoint Test E . B1462 Seat Belt Switch Circuit Failure GEM/CTM REFER to Section 413-09 . B1466 Wiper Speed Not Switching GEM/CTM GO to Pinpoint Test C . B1467 Wiper Hi/Low Speed Circuit Motor Short to Battery GEM/CTM GO to Symptom Chart. B1473 Wiper Low Speed Circuit Motor Failure GEM/CTM GO to Symptom Chart
Symptom Chart Condition Possible Sources Action
  • The Wipers Are Inoperative
  • Fuse(s).
  • Circuitry.
  • GEM/CTM.
  • Multi-function switch (13K359).
  • Wiper run/park relay.
  • Wiper HI/LO relay.
  • Wiper motor.
  • DTC B1431.
  • DTC B1432.
  • DTC B1438.
  • DTC B1450.
  • DTC B1840.
  • GO to Pinpoint Test A .
Your best bet , take it to a qualified repair shop.
Feb 23, 2018 | Cars & Trucks
I have Acer Laptop with a JV50PU motherboard which has a faulty DC input socket connection. The laptop works OK on Charged battery but not on DC input. Is it possible to get a schematic of the motherb
If the DC Power Jack is soldered onto the motherboard then take the time to unsolder it and remove it. Then buy another DC Power Jack which costs less than $8.00 and solder it into it's place. Normally when it is soldered onto the motherboard there is no cable involved. That's all there is to it if it's soldered onto the motherboard.
If it sits on a slot in the motherboard and has a cable harness attached to it then you can purchase that too for less than $15.00. All you do then is follow where the other end of the cable harness plugs into the motherboard and unplug it. Then place the new dc jack in the slot where the old one sat and plug the other end of the cable harness into the motherboard.
Mar 20, 2012 | Computers & Internet
I have a Nissan Frontier with accelerator & throttle problems. I have sensor codes p2122 & p2138. How do i fix this problem? Is it a self fix problem? HELP!
Throttle/Pedal Position Sensor/Switch "D" Circuit Low
P2122 - APP Sensor 1 Low Input
Probable Causes:
1 - Failed APP Sensor 1
2 - Open or short circuit condition
3 - Poor electrical connection
P2138 - APP Sensor Performance Condition Fault
Probable Causes:
I hope this helps you and thank you
Feb 14, 2010 | Nissan Frontier Cars & Trucks
Circuit diagram
I'm afraid I cannot comply with your wishes, as there are copyright laws governing this, for one. (For existing circuitry)
Two, there is the liability issue. Take for example that I design the requested circuit, give it to you freely, and you or someone in your group is injured using my circuit.
Will state that this is a basic circuit design. I believe that if you 5 put your minds together, you can build this circuit.
Sep 14, 2009 | Powerline 200Watt DC to AC inverter...
DC input jack broken
you need to buy a new jack for replacement. then solder the broken one out of the mainboard and clean the place and solder the new one. or some acer have a separet jack then that one is easy only to change.
Dec 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
How do I get into my Easynote R4650 to change power input socket
hi,
check if ur input socket is moving , i mean a bit loose. if so then u got problem with ur DC power jack of ur Laptop. u have to get it fixed. if it seems fine then there should be problem with ur power cable of ur adapter. get it checked for short circuit.
cheers :)
Oct 22, 2008 | Computers & Internet
DC power input center pin is gone
Part costs about $ 5-10 bucks.....labor to fix it ranges from $ 100 - $250. Problem is caused by jerking or tugging on the power cable too much. All laptops need a Cable Retention Device like the one in this video. . .
Jan 05, 2008 | Acer Aspire 3610 Notebook
DELL LAPTOP PP19L - INPUT POWER FROM ADOPTER SHORT CIRCUITED - TO BE FOUND OUT
sounds like the charging circuitry is faulty. I was looking at the service manual and it looks like it is on the motherboard.
Here is the online manual, see what you think.
http://support.dell.com/support/edocs/systems/ins630/en/sm/index.htm
Dec 02, 2007 | Dell Inspiron 2200 Notebook
Acer Aspire 1360 d/c input port
I have the exact same problem, the dc jack port pin as come off of the motherboard circut..so I do not know where to even try to solder it. I hate their input jacks, the laptop, a Acer aspire 5570, is only 6 months old, and useless, because i cannot charge the battery or use the charger directly. What a poor design, designed to wear out. So I just end up buying a stand alone external battery charger online from www.portatechs.com at least i will be able to charge the battery and put it in the laptop
Nov 29, 2007 | Computers & Internet
Computers & Internet Logo
185 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
