Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Soap drawer on bottom washer won't open
The soap dish seems locked, There is a red light showing where you would add the jet dry. That lid will come off but cannot open the soap drawer at al. Ran a cycle without adding soap thinking perhaps someone had open the drawer mid cycle and drawer was locked so one could not add more soap,but that didn't seep to help.
  • 145 Answers
Hi and welcome to FixYa.
That cup is held closed by a simple clip that is molded into the dispenser. There is nothing that would really keep it closed unless it is physically broken. Without being there to see the situation it is is hard to offer up anything else. I can say that if the cup is broken, that dispenser is a part #526860. It is not hard to change at all, you can do it yourself and you can order one here:
http://fisherpaykelparts.net/index.php?categoryid=113&productid=19
Hope this helps.
Posted on Dec 28, 2008
Cloudy dishes
cloudy dishes, white generally means an overdose of salt in the dishwasher, try turning down the salt setting usually set to 4 from factory
Oct 24, 2012 | Bosch Dishwashers
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
My kids put liquid dish soap (not for dish washers) into the hole where you put special rinse product. We got all the soap out of the hole and took towels to dry out the tub, but F1 comes on even when the...
You can download the user manual but that may not help you solve the problem.
I can see that there has been foaming in the dishwasher due to the incorrect detergent which caused the flood switch to trip.
You will have to take both drawers out and dry out the flood switch at the base of the housing from inside. You will use towels and hair dryer.
Make sure the power is turned off at the circuit breaker.
See the installation manual on page 7 step 2 to find out how to remove the drawer. Make sure you don't pull out carefully so the hoses at the back don't get stretched.
Aug 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
What kind of dish soap do you use and where do you put it?
Any dish washer soap powder. Refer to the manual.
Mostly if you open the door you will find a small plastic type box for the soap powder.
Unable to find ! Do not worry. Put it in a small lid and place it. The water jet will do the rest!!
Mar 29, 2010 | Equator 20 in. PLS602 Free-Standing...
Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Mar 04, 2010 | Dishwashers
The dishes come out with a white film on them. they are not clean clear dishes, the bowls and glasses have a film. I was using cascade dry soap switched to liquid soap still have the problem. what can I do...
add Jet Dry or some other sheeting agent to the wash. also most pros frown on liquid soap (gel) so try the hard tablets, most have the jet dry built in. This also ensures the correct amount of soap. if this is a new development check the screens on the bottom of the washer under the spray arm and see if they are clogged with food or gunk. sounds like you are not getting a good rinse.
Dec 13, 2009 | Dishwashers
We own a Bosch SHU5307UC dishwasher. Recently, during the 60 minute cycle, the foam builds up and at the end you can see all of it on the bottom. And the last minute dispaly stays on for a while. It...
the unit is over sudzing cut back on soap and dont clean dishes and then put them in dishwasher.dont use to much of the soap with jet dry. regular soap without jet dry in it then add and fill jet dry compartment
Dec 01, 2009 | Bosch SHU5307UC Built-in Dishwasher
Bottom drawer of the fisher paykel dish drawer seems to be leaking jet dry? I have to refill it continuously. Any ideas?
the small check valve in the rise-aid pump is bad. i'm having to buy a replacement soap/rise aid dispenser from ebay.
Oct 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
172 people viewed this question
Top Fisher and Paykel Dishwashers Experts
TomDicker
Level 1 Expert
Simon Flummox
Simon Flummox
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
