Question about Labtec Arena 530 Computer Speakers
My speakers all work, but the subwoofer sound lowers when they are all working
I hooked in every speaker into the subwoofer, and apparently the subwoofer sound lowers 50% or more... And whenever i pull out the rear speaker input, and the front speakers are just working, the subwoofer works just fine, and its the exact same thing if i pull out the front speaker input..Does anybody have a clue about this?
  • Anonymous Dec 15, 2007
    my suround speakers are working but not the sub and its conected  corectley? any ideas
I have a Sansui Subwoofer and when i turn it on the sound coming out is very low, its very hard to hear, can anyone advice ??
Posted on Feb 22, 2008
    Brigadier General:
  • 6,966 Answers
Hi, pls don't get me wrong, but might it be that you are just hearing more of either the front or the rear since they operate on the frequencies our ears are attuned to with the sub just producing the low ones. Other than that, might it be also the placement of the speakers? The front and/or rear are placed relatively higher than that of a sub woofer hence closer to the level of your ears and therefore you can hear them more distinctly while the sub being lower, you probably feel it as well as hear it but not as loud. Since all of them are working albeit the sound level, I can think of no other explanation. If however this is not the case before and that this problem just recently came up, then may I suggest that you bring the set to a qualified service personnel since this involve checking out the individual amplifiers and their attendant electronic circuitry. If you are comfortable working down to component level, you would probably have to start with determining how many amps are inside the unit and diagnosing each one including the PSU. Far chance as it may be, there is a possibility that the PSU is not able to supply the current demands when all the amps/speakers are working. Hope this be of some help. Pls post again how things turn up. Regards.
Posted on Apr 26, 2007
How to hook up a Kenwood subwoofer to a pioneer receiver
It depends on the speaker and receiver inputs/outputs. If The speakers have bare wires, and the receiver has spring clamps, you are in luck! Check out what I mean by spring clamps in the image linked below. If you can give the model number of the receiver and describe the wires coming from the subwoofer, I can help a lot more.
www.audioholics.com/diy-audio/how-to-use-a-speaker-selector-for-multi-room-audio/NilesSpringLoadedSpeakerSelector.jpg/image_preview
Jun 11, 2015 | Pioneer Audio Players & Recorders
Hook up lower level input to the audio source 230 subwoofer but can't get any sound for the speaker that is hook up through the speaker level input or output.
The speaker level connectors on the sub are for use when you DON'T have an AV receiver-style subwoofer output. They only pass-through from YOUR amp to other speakers. You should NOT use both Line level and Speaker Level input to the sub.
What is your electronics? Have you looked at the manuals?
May 02, 2011 | AudioSource System 230 / 235 System
I have a klh home theater speakers with a subwoofer the sub work but when i hook up speakers no sound comes out?
The sub works but the speakers don't? Do you hook up the speakers to the subwoofer output "loop"? This is a circuit issue when it works and stops working. I have the same issue so I wound up joining the wires that go to the sub and the wires that go to the speaker together and place those connections into the sub. The sub works, the satellite speaker works and the impedance load is no issue for my system. Confused? Simply run your neg/pos wire to the sub and where it connects to the sub, run another cable to the speaker (pos to pos., neg to neg).
The only way to repair it would be to deal with component level repair. Although I have the experience, it is too petty and it works fine the way it is.
Apr 12, 2011 | KLH ASW10-120 Subwoofer
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here: http://www.jbl.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=PSW-D110
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
Subwoofer turns on and is hooked up, but no sound.
The signal don't seems to be present to the sub input.
Try change the wire betwen the audio system and the subwoofer.
Spider Guy
Mar 15, 2010 | Onkyo 630-Watt 7.1 Channel Home Theater...
Passive radiator speaker wiring
Passive Radiators are not driven by the amp. They have no voice coil and no power goes to them. They are used to enhance the bass or lower frequencies in a speaker system. They work by utilizing the back pressure that a driver (woofer) produces. When a woofer produces sound, it moves forward and backwards inside the speaker cabinet. This backward motion is what drives the passive radiator. So in order for the passive radiator to work, it would have to be placed in speaker cabinet along with a woofer that is hooked up to an audio amp.
Jul 23, 2009 | Audio Players & Recorders
Bose Cinemate speakers stopped working
Sounds like you need to take them back for exchange. A new electronic product is most likely to fail in the first few months, when any weak or defective parts that made it through final test at the factory decide to **** out after a few hours of use. This is a very common situation, especially nowadays with manufacturers buying the cheapest parts they can find, and the general public crying out for lower prices instead of paying more money for better quality. Bose has traditionally been "top of the line" stuff, but even they have to cut corners to keep prices low and sell stuff in this economy.
Dec 14, 2008 | Bose Cinemate Digital Home Theater System...
No sound from my speakers
connect the speaker cord to the socket on the tower properly and check for the sound mute
Sep 26, 2008 | Audio Players & Recorders
Subwoofer will not work when connected
cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
Feb 11, 2008 | Velodyne CT-80 Subwoofer
Labtec Arena 530 Computer Speakers Logo
232 people viewed this question
Top Labtec Audio Players & Recorders Experts
Alun Cox
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
