Question about Acer Aspire 5315 Notebook
Will not boot up ( acer aspire with vista basic)
During power up my 5315 note book shows black page with the following messages, PXE-E16 media test failure, check cable, PXE-M0F exiting broadcom PXE ROM, no bootable disk--insert boot disk and press any key. When a system recovery disks are attenpted ( 9 total) the note book states disk error after installing disk 2 with a trouble code of 0xa 0000000. This problem happens with or without unit being plugged in to the wall. Thanks for any suggestions.
  • 837 Answers
0xa 0000000 is a hard drive error .. either your controller or your hard drive has failed ..
Posted on Dec 28, 2008
I have an Acer Aspire 5630 when i turn it on i get a black screen showing. PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM. Operating System not found I have got a...
The message is the laptops way of saying that it has looked for an operating system and could not find one. The PXE rom message refers to it trying to find a network boot record.
Test this by checking your Bios settings, in the boot order, see that the CDRom is set to 1st boot, then the second bot is the HDD, If the thing will not boot. Check you can see that the laptop "sees" the boot devices, if it does not, you have a problem, as it looks like the controllers are damaged.
If it Does find the boot devices, but it still defaults to a network boot, there is either NO OS on the hard drive, or it has been corrupted.
Use the Vista DVD to re-install Windows (you may be lucky enough to get away with a repair installation), after you have reinstalled windows, the drivers etc can be found on Acer's site quite easily
Jun 19, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
When power is on i get the PXE-E61 code on the screen "MEDIA TEST FAILURE ,CHECK CABLE" after that PXE-MOF code is show "EXISTING BROADCOM PXE ROM ..." my laptop is an acer aspire...
It is trying to boot from the network, basically from the internet cable that can be plugged in. If you enter the bios you can typically disable the PXE boot option so it won't show up again.
May 17, 2011 | Acer AS5741 CI3226 156 3GB320GB DVDR WLS...
Acer aspire 5315
well i think you are asking for to use your dell cd to install in your sister's laptop.maybe it will not work because they are specific system configured .you can't use them everywhere.
Mar 31, 2010 | Acer Aspire 5315 Notebook
I GOT THIS MESSAGE TODAY PXE-E61 MEDIA TEST FAILURE CHECK CABLE WHEN I TRIED TO BOOT MY ACER ASPIRE 5630 THIS MORNING. IS THERE A QUICK FIX FOR THIS? EXITING BROADCOM PXE ROM OPERATING SYSTEM NOT FOUND
It is trying to bbot up using network boot because it cannot find OS on the hard drive, you can turn off the network in the BIOS setup page, but more likely you have problem with the hard drive or the OS is corrupted.
Nov 04, 2009 | Acer Aspire 5630 Notebook
My aspire 5315 laptop is stuck on this sceen, broadcom undi pxe 2.1 v10.0.9 copyright (c) 2000-2006 broadcom coporation copyright (c) 1997-2000 intel corporation all right reserved. pxe-e61: media test...
Hello higgstwiligh,
The above message is mainly informational and doesn't necessarily indicate a problem. The acronym 'PXE' stands for Preboot Execution Environment. It's an environment to bootstrap computers using a network interface card. Usually the reboot is done by a remote computer on a LAN (Local rea Network). The Realtek NIC (Network Interface Card) somehow expected a PXE boot to be taking place when the computer was restarting. One solution is to restart the computer and go to the boot menu (F2 on some systems) and choose to boot from the master drive.
*Here's a link to a good article explaining what PXE is: http://www.search.com/reference/Preboot_Execution_Environment
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Nov 01, 2009 | Acer Aspire 5315 Notebook
My acer aspire 5315 is stuck n i have no disk to reformat
the computer can't detect the hard drive to start from it or, then theres a problem with your windows. Use the recovery discs or windows setup cd to try to install windows to the computer again to fix the problem. Let me know how that goes. Thanks
Jun 07, 2009 | Acer Aspire 5315 Notebook
Aspire 5315, no bootable device, PXE-E61 media test failure,
With any standard laptop (your Aspire included) the default boot disk should be set to drive C:
If the system is not finding drive C:, the boot sector may be damage or the drive may have failed completely.
Depending on your operating system (probably Win XP for this one) you can make a boot disk on a friend's optical drive and change the boot sequence in the BIOS setup to your optical drive. Just make sure the disk you've made is compatible with the drive in your Aspire; such as CD - DVD+-, etc.
Once you can get some kind of prompt, either from a basic Desktop or just E:\ from your boot CD, try typing in "C:" (without the quotes) to see if it is accessible. If not, the drive may be bad.
If the drive is still readable, you have more work to do to restore the damaged boot sector.
Mar 21, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315 will not boot up, indicating no bootable device
Sounds like you wiped out the harddrive try reinstalling the os if that does not work you may ned a new harddrive
Mar 16, 2009 | Acer Aspire 5315 Notebook
No boot disk
when this error is showing give me details
mujahed@imsindia.co.in
Sep 27, 2008 | Acer Aspire 5315 Notebook
PXE-E61:Media Test Failure
you got that error message because your harddrive isnot detected so it try to boot from network and you don't have OS in the network.
Most of the time is your hdd is dead. In some cases the motherboard is dead.
You can replace your hdd.
for OS (vista vs XP), if you have enough rams and high cpu, you should install vista, but for me, I prefer XP.
for the price, you should call microsoft seller.
Jul 05, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5315 Notebook Logo
604 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
