Question about Panasonic DMR-E55 DVD Recorder
DVD recorder continually stuck on a loop trying to read disk.
Hi, we have a Panasonic DVD recorder model number DMR-E55. Lately every time we want to watch something we have recorded or even turn the machine on it take ages to read the disk and seems to be stuck on a loop. The machine is continually trying to read the disk. We fiddle about with the wires and after 10 minutes the machine then recognises the disk and we can start to watch our recordings. Please help, we are not sure what has gone wrong, whether we can fix it or do we need to buy a new one? This happens whichever dvd we try to play not just rewritable ones.
Mrs Atsa.
  • 3 more comments
  • ozlematsa Feb 01, 2009
    Hi, I wanted to send a message to Palmbeach but can't seem to find out how to send a message directly. Anyway hope you get this.
    Just wanted to say a massive thank you for your solution to my problem with the DVD recorder Panasonic EMR-E55. Luckily my husband is a dab hand at fixing things and had all the tools needed for the job. We ordered the regulator online and we tried to repair the maching today...and it works!!!! We were a little dubious as to whether it would work but we followed all your instructions and switched it on and like magic the recorder is working perfectly and hope it will continue to do so.
    Thank you so much for taking the time to reply to our problem, you are an expert! and you have saved us a whole load of money getting it repaired or buying a new recorder.
    Thanks a million. Mr and Mrs Atsa. London.
  • evita-4 Apr 12, 2009
    Having experienced the same "Self Checking" loop with my my own DMR E55 I have ordered a replacement voltage regulator. In the meantime realising my in laws had an identical unit still in working order I hastily carried out a mod to upgrade the existing heatsink by the addition of a 2mm thick 50mm X 35mm aluminimum plate cut to provide a finned heatsink. I ran the unit for 30 minutes with a disc in the drive but just on idle (motor spinning). The modded heatsink felt fairly warm to touch after this period. I did not bother with any tmperature measurements but it certainly was sufficient to prove how hopelessly inadequate Panasonics own design of heatsinking is.
    Failing to rectify this problem which must have shown up in initial manufacturers testing goes a long way to prove that this is a built in fault waiting to happen. I will certainly be pursuing the cost of the replacement component with Panasonic when rectifying the fault with my own DMR E55.
  • Palmbeach
    Palmbeach May 11, 2010
    Hi
    This is a common failure with this machine. Thankfully it can be repaired and it is relatively easy for anyone with a little technical ability.
    Have you seen my posting from Jan 2008? If not I have pasted it here. You may be able to repair it yousellf, if not take these instructions to someone who can use a soldering iron and you'll recover you recorder. These are great recorders and it's well worth giving them a second chance.>>>>
    Jan 2008 - Ok guys, you asked for a fix for the DMR E55 Self Checking cycle. Here goes.
    In 99% of cases this is caused by a faulty regulator on the main power board. The power board is located on the right hand side of the unit. The regulator is IC001 which is mounted on a thin metal strip which acts as a totally inadequate heatsink. This means that this component constantly works at temperatures beyond its tolerance. Because of this it usually lasts a couple of years and then starts causing problems. The Self Checking syndrome is typical. If the regulator burns out completely, it can take other components with it, blow fuses and scorch the circuit board.
    If you are competent in using a soldering iron with care, order an STRG 6353 regulator. These can be obtained online from a number of suppliers.
    Disconnect your DMR E55 from the power source and remove the lid.
    Next, remove the fixing screws from the circuit board on the right where the regulator is located. Carefully remove the multi connector on the left side of the board. Remove the screw above the power connector on the rear of the unit. The power board can now be removed from the cabinet. Using a small pair of wire cutters, clip all five pins from the old regulator as close the the top of the board as possible. Undo the screw securing it to the heatsink and remove the old regulator which can now be thrown away.
    Next, using your soldering iron, remove what's left of the pins from the printed board and with a solder ****** or desoldering braid, clear the holes ready to accept your new regulator. Be careful because if you over heat the print it can lift away from the board.
    Use a little heatsink compound on the back of your new regulator, poke the pins through the circuit board and then secure it to the heatsink. I usually fit an extra heatsink on these units which helps to reduce heat and prolong the life of the new component.
    Next, resolder the 5 pins on the print side of the board. Use a magnifying glass and make sure you haven't missed anything or bridged connections in error and caused short circuits.
    Now put the board back. This can be a little tricky but it's easy enough if you take care. Replace all the screws and carefully reconnect the multi connector.
    If you have followed this correctly, switch the unit back on, pop in a DVD and give it a try. Unless you are very unlucky, your DMR E55 will no longer repeatedly self check and will operate correctly.
    Whilst it saddens me to hear that some would toss your DMR E55s into the trash can for such an easily repairable problem, please do not attempt this unless you are confident in your own ability.
    Finally, do check that the fan operates but remember it is temperature controlled and will not activate until it is needed. Do not assume it is faulty because you do not see it working straight away. I have repaired lots of DMR E55s and I have never found a single fan or fan control circuit to be faulty. That's not to say it can't fail. good luck...
  • Malcolm Farrell
    Malcolm Farrell Jul 19, 2012
    Just to add my success with the result of fitting a new regulator to my DMR-E55. Dates from 2004, this problem being the first since then.
  • miss_honeych
    miss_honeych Oct 23, 2012
    Can anyone please confirm if this solution applies to the DMR EX769EB model? I am getting similar messages about self-check, but also about the hard disc being scratched. Many thanks for any help!
  • 185 Answers
Hi again
I am so pleased to hear that you have restored the DMR E55 and for taking the trouble to let me know. It's always satisfying to achieve something like that and I guess you'll get even more pleasure from using it now than you did before. They are good machines and well worth the effort to keep them going.
Thanks again and kind regards
Posted on Feb 01, 2009
Self checking
I have had a Panasonic DMR-E85 with this exact same problem you are describing. As I bought a Freeview Dual-tuner PVR I just bought a second-hand DMR-E55 as I liked the Panasonic interface. Two months down the line it is now exhibiting the exact same problems, except now as well as the continual self-check rebooting, it's also refusing to eject the disk. Booo. Time for me to buy a new DVD recorder again, and this time certainly not Panasonic... :(
Dec 04, 2009 | Panasonic DMR-E55 DVD Recorder
Recorder keeps 'self checking' then taking dvd back to begining, although only on recordable dvd's, not rented. Are recorders worth repairing or are you better just buying another?
Dec 02, 2009 | Panasonic DMR-E55 DVD Recorder
The panasonic dmr e55 will burn a disc from my video camera and play on the dvd player but no other dvd player. and i read all the instructions step for step
Have you finalized the disk after recording? Are you using DVD-R disks? Also, I can replay my recorded DVRs on my portable DVD player, but not on a TV with a built-in DVD player. That one is just to finicky.
Nov 19, 2009 | Panasonic DMR-E55 DVD Recorder
How do i finalize a disc
..issues with the DMR-E55 recorder:
http://club.cdfreaks.com/f106/problem-recording-panasonic-dmr-e55-130046/
..here is your manual:
http://www2.panasonic.com/consumer-electronics/support/DVD-Recorders/model.DMR-E55K
...and on page 33 of that manual they discuss how to do the finalizations.
From my experiences on a friend's DVD recorder,
you need to go 'step by step' and in exact order or the processor
in the machine may not see the correct labeling codes on your disk
at the time you finalize. The "problem issues" referenced in the first
link should help you keep from stumbling over an 'error prone' situation
and may/may-not apply, but IF it does please contact your original sales location with that information.
WW specialsystems@bizland.com
Oct 04, 2009 | Panasonic DMR-E55 DVD Recorder
Dmr-e55 disc will not eject
Try pressing and holding ENTER and RETURN on the remote simultaneously and see if that clears the problem.
Apr 12, 2009 | Panasonic DMR-E55 DVD Recorder
Recording from hard disk to dvd
Must be a trick question... it has a recordable drive.
No to DVDs, Yes to DVD-R, DVD RAM, DVDDL
Dec 03, 2008 | Panasonic DMR-E55 DVD Recorder
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
AELFCHECK Problem with Panasonic DVD Recorder
Hi
This problem is associated with a regulator on the power board. It's an easy fix if you can use a soldering iron.
If not you may be able to get someone to repair it for you. I have posted instructions on how to replace the defective component.
Please note the instructions I have given refer to the DMR E55 but the E95H is much the same.
To see my earlier posting, please Click >HERE<
Mar 13, 2008 | Panasonic DMR-E95HS DVD Recorder
Panasonic dvd video recorder dmr-e55 user manual
http://service.us.panasonic.com/OPERMANPDF/DMRE55.PDF
Oct 13, 2007 | GoVideo Home Audio&Video: Go-Video DVD...
Panasonic DMR-E55 DVD Recorder Problem
I have been told that panasonic now have a faster speed disc on sale to suit the newer dvd recorders that dmr-e55 cannot record on as they are too fast. You have to buy the slower speed ram discs to suit the dmr-e55.
Aug 26, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
2,155 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
