Question about Samsung TV and Video DVD Recorder with VCR
Samsung dvd/vcr the vcr portion of my dvd player (just over one year old) tapes and plays only static pictures. even older tapes that have been previously taped (and viewed) are playing static pictures. settings are correct. already purchased and used a tape head cleaner. any ideas?
  • 76 Answers
SOURCE: video playback
may still need to be cleaned andy.Sometimes cleaning tapes wont get the dirth out.This is more than likely what is wrong.How old is cleaning tape you tried may be time to try new cleaning tape,.
Posted on May 21, 2007
  • 3 Answers
SOURCE: Samsung DVD-V$357 recorded dvds won't play on other machines
Did you finalize the disk? If not, this should solve your problem. When the disk is finalized you should be able to play it on your computer if you can play other DVDs on it. Some other DVD players can only play specific disks (i.e. DVD-R, DVD+R). This may be another problem.
pjrsop
Posted on May 01, 2008
BobbyR1234
  • 173 Answers
SOURCE: vcr tape stuck in unit
Marvin,
I am not registered here as an expert, so there should not be any charges. I do not have the option of chatting I am guessing only the registered experts have that. Here goes: 1. Take a phillips screw driver and remove all the screws that are holding the case on, there will be some big ones on the sides and a few maybe smaller ones on the back. 2. Lift the the case off 3. You should see the tape on the inside the vcr 4. You may or may not have to remove some of the metalic shielding which should be only anywhere from 4-6 screws if you have a piece of metal directly over the vcr tape some have them some do not. 5 Gently pull the magnetic tape up from around the feeder posts and the drum. 6. Try and work the vcr tape up and out, If you are having extreme difficulties with this try plugging the vcr back up and pushing the eject button while still holding the magnetic tape. The tape should eject now and you and carefully pull it out. 7. When you get the tape out, use your thumb to push up and turn one side of the white reals on the tape to slowly wind the magnetic tape back inside the tape. 8. Unplug the vcr again and replace everything that you had to remove and replace the cover.
I hope this helps and let me know if you need further assistance. And since I am not a registered expert here there should be no charge for this help unless you chatted or got help from one of the registered experts.
Posted on Jul 06, 2008
SOURCE: vhs eject will not release tape.
I had a suggestion that did work. Reach into the VHS compartment with left hand and press down toward the back of the tape. With the right hand press the eject button a few times and the tape did come out. I would not buy a Samsung product again. No help from their 800 tech support. No more playing the VHS side of the player. Lynn
Posted on Jul 14, 2008
  • 3422 Answers
SOURCE: Stuck VHS Tape in Samsung TV/VCR Combo
HI,
Please unplug all the cords of your TV for 4 hours and allow it to reset.After 4 hours plug the cords back in and now try removing the tape.
Let me know the result
Posted on Oct 09, 2008
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
Feb 20, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
I am unable to get any picture from my DVD or from the video 2 input on my component. I am able to receive a picture when I use the VCR, however. Please help!
Have you set the DVD up for progressive scan while trying to play through an interlaced (older) TV? press the progressive button below the VHS tape and see what happens.
Jan 02, 2010 | Samsung DVD-V4600 DVD Player/VCR
Hello! i have a samsung dvd vcr combo. 4 yers old. the vcr eats my tapes and pic is jumpy. what can i do to fix?
HELLO
You have a Tape Path problem here. There a few causes but I think the main one is the pinch roller may be worn/mis-shaped or even dirty. You need to have the tape path cleaned totally first and to try the deck again (has it been serviced/cleaned in four years?) If it still has the problem you will then need to have the pinch roller replaced.
There is also the possibility that the VCR deck may be developing a mechanical fault.
I wish you well with it. (:-)
Oct 31, 2009 | Samsung DVD-V5500 DVD Player/VCR
No picture when playing in VCR mode
have you cleaned the heads recently?is there sound?check the tape you played to see if the machine is chewing up the tape and blanking the picture...good luck
Aug 02, 2009 | Samsung DVD-V4600 DVD Player/VCR
Tape chewing
use a vcr cleaning tape.
Feb 18, 2009 | LG XBR446 DVD Recorder/VCR
DVD recorded discs (from VHS) do not play on other dvd players
I called the manufacturer. They admitted to improper instructions. They provided me a fix to their copying protocol and it worked. Also, they game me instructions on how to fix already copied tapes. It works well and I would have to say I was impressed with their customer/technical service.
Dec 26, 2008 | Philips Magnavox DVD/VCR Dual Player
I have a V3650 DVD Player, can i copy my old VCR tapes to DVDs ?
this player will not record copy garded material (this will not work! and yws the life of a VHS Tape is only about 15 years!
Dec 09, 2008 | Samsung DVD-V3650 DVD Player/VCR
Vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
May 13, 2007 | Philips MWD2205 DVD Player/VCR
Televison & Video Logo
26 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
