Cannot reset lamp timer Panasonic 43LC
I have replaced the bulb, it went well. But when I go to reset the Lamp timer, it will not reset. I have followed all the instructions correctly. When the set is turned off and then back on, the time to replace the lamp bulb, keeps coming back on. I can remove the message, but it keeps returning.
The first time I tried to reset it, the bulb lamp went out temporarily. But I never got the message stating the timer had reset. The red indicator to replace the bulb is back on.
4 Suggested Answers
SOURCE: projection lamp timer reset
Turn your television on
Press volume down on the TV
Press the mute button on the remote
Green LED light on power button will flash
-timer now reset (no more warning light)
Posted on Jun 10, 2008
SOURCE: Panasonic PT-61LCX65 Bulb Reset
hold the volume button down on the t.v. & the split button on the remote at the same time for about 8 to 10 seconds.The t.v. tech. did this with my panasonic 61lcx65. Also I had 2 fairly large red / orange & 1 blue spots on the screen which I thought were a result of the bulb being bad , but the tech. attached a device he called an eeprom jig & it reset the chip ? Now the picture is like new again.
Posted on Sep 20, 2008
SOURCE: Need to reset the lamp timer / Panasonic PT-43LC14
hold the volume down on the TV and press and hold down the MUTE button on the remote control. Be sure to hold both buttons down at the same time and until the red light goes out.
This worked for me.
Posted on May 03, 2009
I replaced my bulb in my panasonic tv and reset the lamp timer but the lamp light is still on
Which model are you inquiring about? replaced with Panasonic or Generic lamp?
Apr 26, 2012 | Panasonic Televison & Video
Panasonic projector PT-L78 - Cannot get ride of Lamp time error. To reset the timer
How long ago did you replace the lamp?
If the lamp has not actually been replaced and you are attempting to bypass this safety feature then I have bad news for you. Once the projector determines current flow through the lamp has exceeded the threshold amount, it will put the projector into the mode it is in now - Critical Lamp Replacement. You can set the projector bulb to low power output and see if that allows you to reset the bulb life timer but, again, if you have not actually replaced the bulb assembly, you are in danger of the bulb bursting under pressure. This can actually damage the projector.
You can find the manual for your projector at
ftp://ftp.panasonic.com/projector/ptl785u/pt-l785u_oi.pdf
Nov 01, 2017 | Panasonic PT-L785U Multimedia Projector
Can't reset lamp timer after lamp replacement on Panasonic PT-AE40000
I have a Panasonic PT-AE4000U and could not reset the timer after replacing the bulb with a, non-Panasonic branded bulb. Calls to tech support were not very helpful. It was another bad customer service experience. Through troubleshooting it myself, I discovered the solution was simply to unplug EVERYTHING (serial cable, hdmi cables, etc.) from the device, power it off and back on. Follow the procedure in the manual, the timer immediately reset!!
Feb 11, 2012 | Panasonic Office Equipment & Supplies
When I turn my tv on, there is a box that comes on and says replace lamp bulb and lamp timer, I changed the bulb but I do not know how to change the timer?
I can help you reset the lamp timer for your Panasonic PT-61LCX66 Projection HDTV.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Mar 28, 2010 | Panasonic PT-61LCX66 Television
Replaced bulb,still not turning on-power flashes green then red and lamp light comes on
Did you reset the lamp timer? If you replace the lamp and dont reset the lamp timer the TV will continue to display the lamp error until you do.
Sep 22, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I have owned the PT-43LC since Nov. 2005. Up until now, it has been a great HDTV. Today, I had my first "issue" and have yet to discover a fix. I turn the TV on and it blinks green, indicating that the...
That sounds like a bulb. You should pull it out and check it.
Pretty easy to do, but if mine did the same type thing, replaced the lamp and powered right up.
Sep 12, 2009 | Panasonic PT-43LC14 43" Rear Projection...
How to change the bulb in my panasonic 52 inch model # pt-52lcx66 tv
I can help you change your bulb and reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
  1. Installation instructions for the TYLA1001 bulb are here.
  2. Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Aug 22, 2009 | Panasonic PT-52LCX66 Projection Television
Just replaced bulb to a phillips, lasted one month
Most systems with lamps will have a timer. If the timer gets to a certain hour the set should warn you to replace the lamp. Once you do, you have to reset the timer. If it gets to the max it will not allow you to turn it on till the timer is reset. Check your manual or call the mfg. to see how to reset. Sometimes it's the volume up and down at the same time or menu and power at the same time. They are all different so if you have no manual it's best to call tech support to get the reset steps.
Jul 17, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Lamp replacement
The file is too large to post here but if you post your email address, I can send you the step by step instructions to replace the lamp and reset the lamp hour counter.
Mar 01, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Televison & Video Logo
151 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
