Question about HP Compaq Presario V2000 Notebook
Device manager is gone from control panel
Recently I discovered that device manager is not on my control panel. I did a search for it and nothing comes up. Where has it gone and how do I get it back?
    President:
  • 948 Answers
In Windows XP it has moved. Double-click System, go to the Hardware tab and you will see it.
Posted on Dec 28, 2008
Dell Inspiron 1318 webcam not working
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X
right click to reinstall drivers or update driver
W7
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question/exclamation mark ? ! or a red X a new driver will need to be installed
hope this helps
Jun 28, 2012 | Dell Inspiron 13 Notebook
ADVENT Discovery MT1804 Desktop web cam not working
Go to Control Panel
go to device manager
Have a look down the list to see if there is an entry which has a yellow triangle containing an exclation mark next to it., see if the entry matches your webcam.
Providing that you have discovered your webcam in this list, right click on the entry and click on update drivers. Follow the prompts and see if your pc locates new drivers for the device.
If this fails, search Advent's website for drivers for your pc
May 03, 2011 | Computers & Internet
My inspiron 1501 is stuck in safe mode I'll gone to the set up and tried turning it on with regular setting but still stuck in safe mode.
go to computer>system properties>device manager, or search through the control panel menus for device manager. in device manager, click on each "+" to expand your hardware views, looking for a red "x" or a yellow "!", which would signify a hardware problem. if you find any "x"'s or "!"'s, then you will need to either disable those devices or reinstall the drivers for them. if this does not fix it, then you probably have a defective video card or network card.
Nov 06, 2010 | Computers & Internet
My speakers wont work, everything is plugged in, and nothing will still not work.
I know this was old query, but i recently had a problem with sound cutting out. Discovered if I jammed a spoon between the two cables input to the sub box, I could get sound back. Today finally got around to opening it up and discovered the soldering on both sides of the 8 pin anchor leads were broken. The pressure of the spoon jam allowed the connection to "seat" temporarily. Fixed with 25w iron and 60/40rosin core 0.032" solder. Wicked the old broken mess off and applied dab of new shiny complete solder. Good Luck all.
Sep 11, 2010 | Altec Lansing Audio Players & Recorders
We recently had to have our gateway computer set back to factory settings and now our GMAX 2100 Computer Speakers won't work. I have everything plugged in correctly (I think!) but they won't work. I have...
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 10, 2010 | Gateway GMAX 2100 Computer Speakers
I have an ABS laptop. I have gone into control
First make sure nothing is muted.
Start>Control Panel > Sounds and Audio Devices
If nothing is muted, and your volumes are up and still no sound, try updating your audio drivers,
Start>Control Panel > System > Hardware > Device Manager > Sound Video and Game Controllers
Right click your audio drive and select Update driver.
Dec 06, 2009 | Ultimate Sound COMPUTER ABS | Ultimate V1...
WD 1TB Hard-drive, worked perfectly now it won't :'(
If you go into Administrative Tools, Computer Management, you will see a tree for disk management. It should be listed there - probably without a drive letter..
You can partition and format there.
To get to administrative tools: Go into your control panel - click on classic view and it is one of the top options.
Jul 12, 2009 | Western Digital Elements powered by WD 320...
I have no sound. My audio controller,"this device cannot start.[code 10]"
Hi Empressandi. Have you recently updated your audio driver? If so try rolling back your driver. If your operating system is Windows XP goto start menu, control panel, system, device manager, locate your audio controller and click on roll back driver Likewise under Vista goto start menu, control panel and in the search box, top left, type device manager.
If this audio controller has never worked try searching for an updated driver.
Hope this helps.
May 01, 2009 | Dell OptiPlex 170L PC Desktop
HP Compaq Presario V2000 Notebook Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
