Question about Panasonic SC-DT100 System
Subwoofer of Panasonic SC-DT 100 does not work
Hi, the subwoofer is silent though it seems to be OK when I ran the test for the speakers. Could you please help me with some advice how I can fix it?
Thanks
Tamas from Budapest, Hungary
  • darin_obrien Jan 17, 2009
    I have the same problem - no subwoofer sound. Swapped subwoofer cord with left front and subwoofer speaker worked fine, swapped back to correct original plug and no sound. Can isolate problem to amp. Read manual and turned subwoofer on/off OK witrh remote, but still no sound.
  • goga_27 May 11, 2010
    Olga! Go to http://www.fixya.com/support/t1445518-su... -your problem is solving...
I also have same problem if anybody has solution pls let me know thanks
Posted on Jan 17, 2010
I have the SB-HW950 subwoofer and teh SC-PT950 speakers and I just purchased a Denon Receiver to replace my DVD/ receiver player. So now I have SC-PT950 speakers playing through the Denon but for some...
Yes, the old Panasonic SC-PT950 did drive the subwoofer by its own amp, such as it was.
http://www.retrevo.com/support/Panasonic-SC-PT950-Home-Theater-Systems-manual/id/2869dj183/t/2/
It's never a good idea to adapt prescribed connectors to bare speaker wire or vice versa.
Speaker Level and Line Level signals are worlds apart and equipment damage may result. Your Denon (model unknown) probably requires a POWERED SUBWOOFER, to which it would provide Line Level LFE from its Pre Out.
Read the manual where it doesn't say to convert a speaker wire to RCA.
Feb 06, 2011 | Panasonic Audio Players & Recorders
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
Panasonic sb-wa 340 active subwoofer has just low freequensy noice from subwoofer ! The other speakers working good and dvd fanction normally !
This is normal operation.. The subwoofer will only play sounds below a set frequency...There may be a crossover setting in your menu that you can adjust the frequency cutoff to your liking.
Oct 01, 2010 | Panasonic SC-HT690 System
Replacing Panasonic SA-HT500 with Newer Model that has HDMI Input
ANY amp will be ok, as long as the wattage of your new amp does not exceed the wattage of your speakers. Otherwise you could overdrive your speakers and damage them. First clue, if you turn up the volume and the speakers start to shut off and on you are pushing too much power to them.
Feb 03, 2010 | Panasonic SC-HT500 System
Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
May 27, 2009 | Panasonic SC-HT930 System
The Subwoofer will not work but all other speakers do!
Hi look for a sub level control in the set up and turn it up,this may give it a kick start,also is ther a volume control on the sub? if so turn it up half way.
HOPE THIS HELPS.
CABLE GUY.
Aug 05, 2008 | Panasonic SC-PT1050 System
No sound, subwoofer or speakers
Er so you plug the speakers into anther system and they work? Blindingly obvious but there is no fault with the speakers.
Oct 06, 2007 | Panasonic SC-HT730 System
Panasonic SC-DT100 System Logo
278 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
