Question about HP LaserJet 1000 Printer
NEW HP COMPUTER. CAN'T INSTALL OLD HPLASERJET 1000 (NO DISK)
HOW CAN I INSTALL AND USE AS MY DEFAULT PRINTER?
  • Anonymous Mar 10, 2009
    driver
  • 837 Answers
You may need new drivers .. go here and download for your OS
Posted on Dec 28, 2008
Hplaserjet p2055d prints blank pages
check your ink level. you will find it under Hp Laser Jet P2055B series.
Terry
Apr 25, 2014 | HP Hewlett-Packard HEWCE457A HPLaserJet...
Hplaserjet M1005 software cd is not installing in windows7 home basic laptop
Try downloading the drivers/software from HP website as long as the operating system is supported by HP for your printer model, if it's not then you may have to try and find a third party driver which may prove very difficult, if windows 7 did not detect & install the driver automatically then it may be a case of upgrading the printer depending on how old it is.
I have just tried a check on availability and windows 7 32/64 bit are supported.
As a second point you could try other cd/dvd to make sure DVD drive is working ok.
Mar 14, 2013 | HP ljM1005-HB-pnp-win2kxp-en.exe
I cannot load the HPLaserjet 6L on my Aspire Acer laptop. I have the cd but don't know what to type for "Copy manufacturers files from"
HP.com and download the HP Universal pcl 5 driver. That should get you going. That printer is so old that HP no longer made drivers for it specifically so you will need to use the universal driver.
Jun 12, 2011 | HEWLETT-PACKARD HP LaserJet 6L Printer...
No printing
Well this issue must be related to the drivers of the printer, possibly incompatibility. Let's try to fix it with the easiest method.
First uninstall the driver after the printer is disconnected from the computer. Then run a registry cleaner (click here to download a freeware registry cleaner) to clear any unwanted registry files. You'll also need to clean the system using the feature with this application.
Now download this driver Hplaserjet 2100 windows vista32 (if your system is 32 bit) or hplaserjet 2100 windows vista64. Extract the files to a specific folder and follow the instructions as follows;
Click "Start" , select "Settings/control panel" and click the "Printers" folder.
Double-click "Add Printer".or click "File" on the menu and select "Add printer"
The "Add Printer wizard" will open. Select "My computer" then click "Next".
Select LPT1 (whether directly connected or networked) and click "Next".
Click "Have Disk".
Click "Browse".
The Locate file window will come up saying a: "is not accessible" . Click "Cancel".
Under "Look in" select the folder where the file is saved.
Highlight "HPLAOUT.INF" and click "Ok".
The Install from Disk window will reappear, click "Ok".
Select "HP LaserJet 2100 Series PCL 6" and click "Next".
Select the "Replace existing driver" option and click "Next". (This window will not come up if the uninstaller was used).
Select Not Shared and click "Next" .
Select "Yes" and then click "Finish".
Please don't skip even a step from the uninstall process. And do let me know when you are done.
Till then, Good luck.
Thanks for using FixYa.
Jun 29, 2010 | HP LaserJet 2100 Printer
Have a HPLaserJet 5100 - probably purchased in 2004/2005 - bought new computer with Windows 7 - can't seem to get plans to print correctly from adobe or maxview
no matter what ever printing problem u have, here is the solution for all:
download the software call "fine print" its a free software u can easily download from google, install it as your default printer, from the next time the print job will go to your laserjet printer via fine print, and it will deffinately fix it. i have been working with hp fro quite a sometime & with the help of this software i resolve most of the issues.
Apr 01, 2010 | HP LaserJet 5100 Printer
How to install a printer
I think the 20-year old software will not be able to handle the multi-functions of your new fangled printer.
You may need to find an old dot-matrix printer of that era ...
Jun 15, 2009 | HP LaserJet 3100 All-In-One Printer
I just got a new computer with windows vista.my old computer was windows xp .i have a hp psc 1315v scanner printer copier.all in one series,my old disc wont get it running wiyh this program.how do i...
hp.com, click drivers and downloads, then enter the model number then download and install your drivers using the add printer wizard, have disk tab. good luck!
Sep 23, 2008 | HP Office Equipment & Supplies
1020 PRINTER DRIVER HP
There are no drivers for fixya but I have found a workaround by some anonymous poster
Xp software&drivers will work in Vista after a little tweaking in printer properties.
1)Install the CD-Rom HP Software/Drivers that came with your Printer at the time you purchased it. These Xp software&drivers are Vista Compatible after tweaking the Printer Properties. Reboot after installing.
2)Goto Start/Printers. Right click HPLaserJet1020 then Left click Properties. An HPLaserJet Properties window should have popped up.
3)Click the Advanced Tab. Click the Print Processor button located at bottom of window.
4)Select print processor as>>>IMFPrint. Then Select Default Data Type as>>>RAW. Click OK.
5)Now return to the Main HPLaserJet Properties window and click the General Tab. On the Bottom of that window; Click the Print Test Page Button. Finished! A test page should be printing out if you adjusted the printer properties correctly. Enjoy!
optionally you may have to disable print spooling
Quote "This did not work for me until I changed the option in that same window (advanced settings) to "print directly to the printer". Spooling does not work. "
Jul 14, 2008 | Office Equipment & Supplies
Open Questions:
See all HP LaserJet 1000 Printer Questions
HP LaserJet 1000 Printer Logo
43 people viewed this question
Clive
Clive
