Question about MTV Games Rock Band for PlayStation 2
I broke the wire to Guitar Hero foot pedal?
Can I replace the wire? If not, can I buy just a drum pedal and not the whole drum set.
    Scholar:
  • 65 Answers
I would say that you could just change the wire. Or just go to e-bay or some store on line and just buy another one. They are not to much
good luck.
Good luck 2913
Posted on Dec 29, 2008
Is there a guitar hero foot pedal wire replacement as the wire to hook up pedal to drums is broken? Can I buy just the wire or do I need a whole new foot pedal? And if I can buy the wire, where do I buy...
you will have to get a new foot pedal var fctb_tool=null; function FCTB_Init_62176759b3424b9cbe761805261ece8a(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_62176759b3424b9cbe761805261ece8a(document['FCTB_Init_4530bd1f4dd44a9eb15294e262e76316']); delete document['FCTB_Init_4530bd1f4dd44a9eb15294e262e76316'] var fctb_tool=null; function FCTB_Init_2d8b2df2973d4407bec8a4def7152a67(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_2d8b2df2973d4407bec8a4def7152a67(document['FCTB_Init_f65b37e3b16a4105b681111044638705']); delete document['FCTB_Init_f65b37e3b16a4105b681111044638705']
May 05, 2011 | EA - Electronic Arts Rock Band
Tip
Guitar Hero Drum Set Common problem
hello guys, i just wanna share with u one of the most annoying problem in the drums its the pedal, some times while u r playing on guitar hero drums hiting the notes its suddenly start kicking the pedal by it self and u cant continue playing because of that, what i want to tell u that before u react to that by start opening the pedal to fix it, you should first make sure that the pedal itself is damaged or not. just follow the steps ok.
1- remove the pedal and replace anything on the behalf of it like your headsets, just put anything in its place on the drums location and start a game and play and hit on the drums as hard as u can and see if the pedal is still kicking when ur hitting the red, green, blue drums if YES then its not the pedal its the drums itself, if not then u have to fix the pedal, i will tell u how later ok. 2-now after using some other device and finding that the pedal is ok and ur having this problem, just flip the drums and remove all the screw at the back ( trust me its so safe and easy) now open the drums and and go to the place where the pedal made to fit in u will see a chips and a screw in the middle, just screw lift ( most of times while ur playing and because of the heavy hitting on the drums the screw get relaxant so all u have to do is tight it up very well and it will solve the problem. 3- get everything back as it was and enjoy good and AWESOME play like if its brand new drums :))) hope i was very helpful
and about fixing the pedal if it was damaged flip and remove the first gray label its some kind sticky but its ok just remove it and u will find 2 screw remove then and go back to the front where the wire goes inside the pedal push it inside and then push it up it will be removed and there u will find 2 wires they may need to get fixed its easy weld the damaged wire and everything is ganna be FINE
on Feb 06, 2010 | Activision Guitar Hero
I have guitar hero 3 on xbox 360 along with the wireless drums (cymbal and hi hat) and the wireless guitar. I can not get them to play together. The guitar plays but I can't get the drums to play. do I...
Unfortunately, Guitar Hero 3 does not support drums. World Tour is the first game in the series to support them. In addition, if they aren't official Guitar Hero drums, they aren't guaranteed to work with World Tour. Hopefully they do work. Good luck!
Mar 14, 2011 | Activision Guitar Hero III: Legends of...
The wire came out of my drum pedal.. is there a way to fix it without buying a new one???
Indeed Take it apart or push the wiring back into pedal and use tape or glue... use your child side ^^
Have fun.
May 03, 2010 | Activision Xbox 360 Guitar Hero II
Foot Pedal Guitar Hero Xbox360
If you are still within warranty, then take it to the store, if you got an extended warranty, then give you a number at the store to call. If you have an extended warranty, call the number and request an adress label, and put it on a box and UPS/FedEx your foot pedal to them, if you don't have a warranty anymore, you're out of luck.
Jan 16, 2010 | Activision Video Game Consoles & Games
Pedal lead broken
you can just solder it back. there are 2 screws under the front-most velcro. open them, and take out the round plastic where the pedal hits. there are two wires. you'll see 2 white solder points where the wires broke off from. you don't need to solder in the exact same place, just one on the outside ring and one in the middle. 3 minute work. when you close everything up and it works, i suggest taping the part of the wire closest to the pedal to the pedal itself. that way, if you accidentally yank the cable, it won't tear off from the soldering.
Jan 12, 2010 | Activision Guitar Hero World Tour Guitar...
Broken cord to cymbal
get wire snips and strip the wire on both ends.then twist them together and then wrap the wires in electrical tape
Dec 22, 2009 | Activision Guitar Hero
Red drum wont work
Unscrew that drum and see if you can find a wire that has been cut off. If you do, tape it back together and try it. If it doesn't work, buy a new drum set. Cheap at Walmart and or Gamestop
Oct 18, 2009 | Activision Guitar Hero World Tour Guitar...
Wire out of cymbol
you cant buy the symbol separate but you can get a hole new set. I might be wrong. But i am pretty sure that i am right.
try going to:
http://www.amazon.com/s/ref=nb_ss_vg?url=search-alias%3Dvideogames&field-keywords=drum+set+for+guitar+hero&x=0&y=0
copy and paste it. you can get them for $20.00
Jul 18, 2009 | Activision Guitar Hero World Tour Guitar...
How to solder guitar hero drum set wire
any tin/lead solder you get from maplins will do , I think they do a little tube with a coil of the stuff for about £2,,,
May 22, 2009 | Nintendo Activision Guitar Hero World Tour...
MTV Games Rock Band for PlayStation 2 Logo
531 people viewed this question
Top MTV Games Video Game Consoles & Games Experts
Marvin
Marvin
DROPNDEAL
DROPNDEAL
Are you a MTV Games Video Game Console and Game Expert? Answer questions, earn points and help others
