Question about Zhone 6211-I3-200 Router
No 'Status' light on the modem
There was a power supply surge at my apartment and my modem was affected.It came back and the 'Status' light on the modem has not come on solid green since then. The LAN and USB lights are flashing and when I try to set up the modem,I'm told that 'A network cable is unplugged'. I've installed the modem on another PC and it's the same problem withe no assistance from my ISP's tech support department. I can't even access the modem's admin page to look at anything there.
  • 585 Answers
First of all, who owns the modem? If the ISP provided it and charges a monthly fee as part of your service, have them replace it and set it up. Problem solved!
If it's yours however, the surge may have damaged the LAN port, turning it into a brick, and you'll need to find a replacement. There is the possibility though, that the settings have just gotten corrupted. If that is the case, defaulting the unit will allow you to access the modem's admin page and re-configure (you must know the default IP address). Defaulting to factory is usually a matter of disconnecting power for 30 seconds or so, holding the reset button, usually accessible through a small hole with a toothpick or paper clip, and plugging the power back in while holding the button.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 28, 2008
Samsung Plasma will not turn on. Status light is still on. When power button is pressed, the status light extinguishes but comes back on immediately. TV never turns on.
Hi!
I know the problem but you need a pro. Your TV does not start because there is a board defect. There are voltages to be taken at precises places but it is too technical and to dangerous you do it yourself, high voltage. I would strongly recommand you to see a pro. Good luck,
Serge.
Apr 17, 2016 | Samsung Televison & Video
I have a Dell computer that will not come on since a strong storm came through and knocked out the power into house! What needs to be done to get it up and running again?
Power supplies have an internal trip feature. Unplug the power supply from the wall power. If the power supply has a switch on it, cycle this switch as well. Wait about one minute and try again. Also, ensure that the surge suppressor/power strip/wall outlet has power. Also, disconnect and LAN and modem cables that are attached to the unit. A power surge thru one of them can cause damage to the mainboard that would affect the ability to power up. If the unit still will not power up, chances are that the power supply or mainboard has been damaged.
Aug 01, 2014 | Computers & Internet
Rca lcd tv power surge lighting
The power supply is a likely place to find what's causing the problem
Jul 11, 2013 | RCA Televison & Video
I just reset my dell computer back to factory setting. How do I now reset up for internet connection. My provider is verizon and I am using internet explorer
You want to reset your internet connection???
If yes then follow the given steps....
Step 1
Turn the modem so that the back of it is facing you. Locate the power supply cord connected to the back of the device.
Step 2
Gently unplug the power supply cord and leave it unplugged for about 10 seconds. If you also have a router connected to the modem, disconnect the power cord of the router as well.
Step 3
After about 10 seconds reconnect the DSL modem power cord. Wait for the status lights on the front of the unit to come on. They may blink at first before turning solid green, or they may first illuminate as orange, then turn green, depending on the modem model. The "Internet" and "Incoming" lights may continue to flicker, this is normal operation for modems.
Step 4
After the modem is reset, reconnect the router power supply if you have a router. Wait a few minutes before resuming normal Internet use.
If you need any kind of technical assistance you can contact support cell
Jan 19, 2013 | Computers & Internet
We lost power for a few hours .The cable company ( charter ) had to reboot the modem to reestablish the internet connection. Since then I cannot get the Cisco router to work.. I've done all the plug,...
1. if the power went out and then back on it is possibly due to a "power surge" and it possibly damaged the power supply to the Cisco router and or to the router itself.
2. check the routers power supply and replacement is needed if the router was not plugged into a surge protected socket.
Jul 15, 2011 | Computers & Internet
Wirelessrouterstepbystep learn howto setup
Choose your equipment wisely. There are many types of wireless routers, and they are not all created equal. Some of the lower end wireless routers are very basic, and will limit your home network to speed of 56 megabits per second (Mbps.) This is really not a very fast speed. If your access points will be very far apart, consider getting a router with ultra-range abilities, or a dual-band router. Also, while you're at the store, be sure to pick up one wireless access point for each computer you intend to connect to your network.
Remove your DSL or cable modem from the power supply.
Remove the Ethernet cable which connects your DSL or cable modem to your computer from the computer, but leave it plugged into the back of your modem. This cable looks something like a phone cord on the ends, but with much larger connectors and a larger, round cable. Do not remove the phone cord from the modem which is plugged into the telephone jack on your wall.
Connect the loose end of the Ethernet cable to the internet port on the back of your router. This port should be clearly marked, and will probably be a different color than the other ports.
5
Reconnect your modem to the power source. To protect it, plug it into the same surge protector which guards your computer.
6
Plug the Ethernet cable which came with your router into the Ethernet connector on the network card on the back of your computer. Then plug the other end into one of the Ethernet network ports on the back of the router.
7
Plug the router's power cord into the power supply. This device should also be protected by a surge protector. If you run out of plugs, it is well worth ten or twenty dollars to invest in a second surge protector.
8
Check the lights on the front or top of your router. The power light should be on, as well as the internet light, the wireless light, the security light, and a light for one of your Ethernet network connections. Check to see if any lights are off, flashing, or red or amber in color. This will indicate that the router is having a problem. If any lights are not on as they should be, check your cable connections to ensure that they are securely connected. Repeat the setup steps if necessary.
9
Install the software provided by your wireless router's manufacturer.
This is it you are done
Thanks .
Oct 07, 2010 | Computers & Internet
DSL modem no power in house, OK at shop, same cables.
Well, by process of elimination, it sounds like it may be a problem in the wiring in the house. Your best bet may be to test your outlets for proper wiring (ie. hot/netural faults), and for cycle rate (in hz, 60hz is nomal). I would also look into a surge bar that is built for normalizing power (Often called Power Cleaners). If you have older electrical service into your house (fed from a pole) or if you are in an apartment or condo type building, there may be line problems with the power supply. Basic outlet testers are under $10 and really handy to have around if you do any sort of electrical work, but the surge bars can be quite pricy. I would look at other outlets in the house that have similar AC/DC converters attached (like cordless phones, laptop computers) and see if it works in those outlets. Really a very strange problem, and may go deeper then just the modem itself.
Jul 12, 2009 | 2wire (1000-000057-000) Modem
My cpu got a power surge during a lighting storm an burned up my power suplie ive replaced it an now the power light will come on when i push the power button on and the fan on the mother board works but...
In addition to your power supply, your motherboard was also probably affected by the surge. Most surges do damage beyond the motherboard. The power supply is still supplying power to it, which is why the fan runs and power lights come on, but it probably isn't doing much more then that. You might want to start looking for a motherboard replacement. The best and most inexpensive place is www.tigerdirect.com.
Mar 25, 2009 | HP Compaq Presario SR1303wm PC Desktop
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Sep 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Light Bulb Icon Flashing
Unplug it from power.Pull the side cover to check for burnt smell or burnt spots on your board modem or power supply. Unplug the power suppy from the board, unplug the hard drive . Then plug it all up again , put the cover back on it .Plug power cords back up and try it again.If you get no where after this the surge knocked out your power supply or hard drive or board. Always use a good surge protector on all computers and printer and copiers.
Aug 06, 2007 | Compaq Presario S6300NX PC Desktop
Zhone 6211-I3-200 Router Logo
413 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
