Question about Westinghouse LTV-40w1 HDC 40.02 in. LCD HDTV
Tv converter i have a new lcd tv that has 2 hdmi ports and a dvi port in the back, but no port for me to hook my cable up to it(i think the specific wire i want to hook up is called an "ant" wire but im not sure) is there any like converter i can buy that will convert the wire to hdmi or is there another solution out there?
  • 54 Answers
There is no way to convert your antenna/cable wire to use either hdmi or dvi. you must use either a cable box or satellite reciever. on any new tv sold within the last year there is a " rf connector " where you would attach the antenna or cable wire. take a look at your owners manual to find out exactly where.
Posted on Jan 21, 2009
What kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Feb 03, 2012 | Panasonic VIERA Televison & Video
How to connect a Samsung R700 PC to Sony LCD TV KDL-46S2010
hi my name is Rui i would like to help you with your problem...
its just easy to connect a PC to a sony lcd tv...^_^ here are 5 ways to do it...
1. S-Video - This is probably the most common method out there currently because an S-Video Cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA Cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with "digital" being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI - Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Coverter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
just try hooking up 1 of this tips i give you.well if you ask me i prefer HDMI & VGA. ^_^
but it will still depend on your preference..
hope this will help you... Good luck... ^_^
Jul 17, 2011 | Samsung Computers & Internet
Cant connect laptop to tv
Hey
If you're using a newer laptop look for either a HDMI (looks like elongated USB port) port or a DVI (a female port similar to a serial port but wider. Usually a white) port on the back/sides of your laptop.
If it's an older one, Look for an SD port (Resembles a PS/2 port which you plug the mouse in).
That being said, your TV must be able to pair with one of the above ports.
HDMI -> HDMI (using a HDMI cable)
DVI -> DVI
SD cable usually splits into three, Red, Yellow and White pins. Two for the LEFT and RIGHT audio channel and the other is for the video.
You might also be able to find converters from one format to another.
Hope this helps.
Cheers!
Dec 19, 2010 | Computers & Internet
What sort of lead should I use to connect my Sanyo CE27LC6-B - 27" Widescreen HD Ready LCD TV to my laptop?
So here's a quick walk-through of all the methods that I know (if you know any more, please comment) to connect a laptop or PC to your TV:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You'll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC's are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won't find a VGA port on regular TV's though, so this option is if you have an HDTV.
5. Scan Converter Box - This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here's a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel free to comment!!! Thanks!
Nov 13, 2010 | Computers & Internet
I cant connect my acer aspire 5810 tg with my samsung lcd tv.the tv say "NO SIGNAL"
Nov 13, 2010 | Acer Computers & Internet
How could i connect this tv to laptop
Connect by this way:
Sep 16, 2010 | Samsung CW29M64NS 29" TV
How do I connect my dell laptop to my LG LCD TV
1. S-Video – This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI – Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box – This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
May 30, 2010 | Dell Latitude E6500 Laptop
Conecting laptop to tv
1. S-Video ? This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You?ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC?s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work. 2. VGA ? If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won?t find a VGA port on regular TV?s though, so this option is if you have an HDTV. 3. DVI - DVI stands for Digital Visual Interface with ?digital? being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80. 4. HDMI ? Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI. 5. Scan Converter Box ? This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Apr 07, 2010 | Hannspree XV37 HDTV 37 in. LCD TV
I'm trying to hook my Macbook Pro to my TV (Samsung 50'' Plasma 720), I have all the cables needed to hook up sound and picture. I have the Mini display port to Dvi Adapter and Dvi to HDMI cable. My...
Hi
It may just be possible that DVI signal does not convert to HDMI signal. So in theory this may not be possilbe for you to get a result with your present attempt. May i suggest connecting to the DVI port of the TV. i.e Mini Display to DVI.
Regards
Dec 29, 2009 | Apple Computers & Internet
PC to TV can't seem to get to work.
okay buddy its esay just give me a good rate!
u select:
1. S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA - If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
Feb 06, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
172 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
