Question about Baby Gear
No PhotoViewer is found, Program Termined!
Can some1 please help me, i've recently received a photo key chain gift for christmas, i installed the disk that came with it being "PhotoViewer" successfully, i managed to select the photos that i wanted to transfer onto my key chain and synchronised, but nothing was happening with my key chain, in other words i could not turn it on. I've uninstalled and re-installed the software and now when i click on the PhotoViewer tab a message comes up saying "No PhotoViewer is found, program termined!" does any1 have an idea for a solution?
  • Anonymous Jan 01, 2009
    We have the same problem, the key chain was brought from Next.
  • megantravel Apr 05, 2009
    i have same problem with photo viewer did you ever fix
SOURCE: digital photo key chain problems
Hi Maria, I accidentally found out how to get it to work. What the instructions do not tell you is after you move the arrow to USB Update, you want to hit the little power button on the keychain. You should hear a little tone that your computer makes when new hardware is attached. At that point, you should be able to run the program and it should recognize your device.
I suggest you modify they instructions on Step 1.
Dina43
Posted on Dec 22, 2007
SOURCE: digital photo keychain
The program can't connect with the gadget if it's in 'usb charge' mode. You need to make sure you select 'usb update' when you connect the keychain to your computer and then click your menu button. It would be more helpful if the error message pointed that out instead of 'termining' the program.
Posted on Jan 08, 2008
SOURCE: Sharper Image Digital KeyChain
The software on the CD never worked for me but when I downloaded the software from the website it's worked perfect...
Posted on Aug 27, 2008
SOURCE: Photo viewer doesn't find the pictures stored on my computer
I had the same problem. What I did was in My Pictures, I selected the ones that I wanted to use for the keychain. Then, I downloaded them to a new folder (renamed the folder). I highlighted the new folder and sent "moved to" the C drive. Once I went back into photoviewer, I was able to see the folder after I double clicked on the C drive and the pictures were there. I hope this helps you!
Posted on Dec 06, 2008
  • 3 Answers
SOURCE: Photo viewer device not found
I got a key ring for Christmas too ...when the keyring is on 'charge' mode it doesnt show on computer ...you have to remove the lead from key ring, switch off key ring then replace lead and switch to 'update' mode. Now if you double click on icon it should work!!!
Posted on Dec 27, 2009
Testimonial: "Yay! You're spot on. Otherwise a good keyring - but not really clear for the novice user!"
When I try to install the coby dp 151 it says: cant find photoviewer or program that owns it. the program will exit. ?? confused
The error you describe, is also mentioned in the Setup Guide for the DP151.
When you connect the Key Chain to the USB port of your computer, on the Key Chain will prompt the message to select: USB charge or USB update.
For proper function of the Chain Key:
0) Before connecting the Chain Key, have the Photo Viewer software installed:
You need adminstrator rights to perform installation of programs.
Install the photo viewer from the CD or download this program
from the Coby support site:
> enter cobyusa.com in the address bar of internet explorer
> enter DP151 in the Product Search bar
now all support for the Chain Key will show
> run the DP151_PhotoViewer zip file directly or save the zip file onto your computer, unzip and run the setup.exe file later
1) Connect the Chain Key and Select USB update on the Chain Key.
Again, to be able to update, you need adminstrator rights.
2) Run the Photo Viewer on the computer.
Aug 15, 2010 | Computers & Internet
Digital photo album - keychain
The message "No Photo Viewer Found, program termined" will happen unless you have the keychain plugged into the USB port in syncronization mode not charging mode. It's just saying it can't find a Photo Viewer plugged in to sync with. That should solve your problems. You can't update you image library unless it is plugged in
Regards
Balisonu79
Feb 16, 2008 | Digital Products Monaco Ezcolor Photo...
Nov 22, 2009 | Fuji Electronics - Others
Software won't install coby photo viewer key chain
You need to make sure the usb cable is in all the way to the viewer. You have to push it hard. No silver showing. Always need the viewer plugged in first before starting the viewer program. After that it is pretty simple.
Nov 14, 2008 | Computers & Internet
Cannot find how to load photos onto Dolphin 1.5" Digital Photo Frame Key Ring
I had the same problems but solved it by uninstalling the useless POS software, rebooting the computer and reinstalling everything.
I have found that you have to do this everytime that you want to add or delete photos. Probably the worst piece of software I have seen in 15 years of working on computers.
If it won't detect as a seperate drive in "My Computer" then you will have to uninstall it and start again.
There is also no need to format the device. Just ignore it and start downloading photos and it worked straight away. (Using XP Home) As to battery life, I suspect I will never know because it is liable to have a visit from my sledge hammer before it runs out of power.
May 18, 2008 | Electronics - Others
Photo key chain
Connect to pc. Press 'on' button on keyring. Change from 'charge' to 'update', then press > button. Photoviewer will then load. Good Luck!
Jan 27, 2008 | Tao Spectare digital picture Remote...
Digital keychain photo album
Three months, hours of frustration with innovage digital PhotoKeychain I can't get it to work. My kids gave it to me as a Christmas gift and keep asking me if I like it. Please help. They will be here to visit for my 55th birthday and I want them to see I like thier gift. Thank You
Dec 26, 2007 | Innovage Mini Flip Phone 1510255
Digital photo key chain problems
Dina43
Dec 21, 2007 | Tao 89811-PB1 Digital Picture Keychain
Digital photo keychain
The solution is....USB 2.0! This is now standard on new computers, but mine (that is just 1 1/2 years old) does not have USB 2.0. Actually, one out of six of my USB's say it is, but I never got it to work. The sad part to all of this hard work--it takes 5 minutes on the right computer!
If you need to borrow a computer, you will not need to send them all of your full size photos. Just "Save a Backup" on your computer and e-mail that file as an attachment--it's very small. The you will "Load a backup" to get your pictures into the KeyChain Manager. You will need to install the software on your borrowed computer, but as I'm sure you know, that's the simple part!
Hopefully this helps!
Dec 10, 2007 | Cameras
Can run photoviewer program for photo keychain
Your computer will certainly have its own program for viewing photos. For example, if you are using Windows XP, you just right click on a photo file and choose "preview". It can be difficult to find the photos on your computer if you have been using one of the silly organizers that come with cameras. You can search for a photo if you know its filename or for *.jpg to find all the photos on your hard drive.
Sep 11, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Baby Gear Logo
183 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
