Google When turning in computer for first time an error comes up stating Googledestopexecommon.dll hit OK comes back and states to close program. Can I remove this error and if so how
    Guru:
  • 731 Answers
HI
You need to uninstall the Google desktop from your computer.
1. click Start -->Run
2. Type appwiz.cpl and hit OK
3. Check for Google desktop in the list, click and highlight it and then uninstall
Thanks
Riz
Posted on Dec 29, 2008
Getting an error on outlook mapi cant find the msncon.dll file
what version operating system did you install on . most likely it is not compatible with your OS
Jun 28, 2015 | Microsoft Office Outlook 2003 for PC
Cant sign on to computer
    • 1 Download the missing comctl32.dll file. Locate a website that offers the comctl32.dll file. You can also use the link in the Resources section.
    • 2 Unzip the download file if it is a .zip-type file. Right-click on the file and choose "extract" to make the file available in a .dll format.
    • 3 Install the missing comctl32.dll file in the proper folder on the computer. If the operating system is 64-bit Windows, copy comctl32.dll to the "C:\Windows\SysWOW64" folder. If the operating system is 32-bit Windows, copy comctl32.dll to the "C:\Windows\System32" folder.
    • 4 Restart the computer by clicking on the "Start" button and selecting the "Restart Computer" option.
    • 5 Open the computer program that previously displayed the error message stating that the file comctl32.dll was missing. This will verify the program now works properly.
Nov 21, 2011 | Dell Latitude D 600/610
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
When i try to install googlechrome i get error code=0x80040909
First, ensure the Windows installation is not in Windows Audit Mode.
Windows Audit Mode is used by PC manufacturers to setup a new installation template for your computer. When I re-installed my laptop's Windows image, it was in Windows Audit Mode. To put Windows in a Normal mode, please try the following:
1. Go to the Start menu, and where it says Search Programs and Files, enter the following in that box: regedit
2. You will see the REGEDIT program icon, click it
3. Windows will ask if you're sure, click OK.
Now you have the Registry Editor open. Double-click the following to find the value we need to change (called STATE):
- HKEY_LOCAL_MACHINE
- SOFTWARE
- Microsoft
- Windows
- CurrentVersion
- Setup
- STATE
Right-click on STATE
Select Modify.
Delete the value (so it's blank)
Click OK and close the Registry Editor.
At this point, I tried the Chrome Stand-alone installer, and it still did not work.
So, I installed another browser (Firefox), and made that browser the default for my Windows 7 installation.Then, using Firefox, I tried the regular Chrome installer at www.google.com/chrome, and it worked perfectly.
Dec 06, 2010 | Computers & Internet
Win xp error code 0 x 80090006 after win update
Some times this problem occurs.You dont worry.you will update after some days.Now you can do the bellow steps
start->all programs->accessories->system tools->system restore->restore my computer earliar time ->
then choose the best cheak point .then ok->close.
wait 10 to 20 minutes. your system automaticaly restored in previous state.(Before Updated state).
Note: You must chose the date before update the windows.(Cheakpoint)
Feb 13, 2010 | Microsoft Windows XP Professional
How to stop start up error " STlog.dll not found"?
See: http://forums.techguy.org/all-other-software/849895-solved-st-service-exe.html
which states (after my editing):
The problem is related to DELL DATASAFE LOCAL BACKUP on your machine. It's the backup program that comes with your DELL.
STservice.exe is an unimportant part of this backup program.
It's just the scheduler. You won't need it.
The problem consists in the fact that the program can't find
its resources.
It seems to me that you cannot download DELL DATASAFE LOCAL BACKUP from any site on the internet.
Here is my solution:
1. If you can find DELL DATASAFE LOCAL BACKUP on the DELL DRIVERS AND UTILITIES CD that comes with your Notebook, Uninstall the whole program, ... and install it again from the CD.
Nov 20, 2009 | Microsoft Windows Vista Home Premium...
The network connections folder was unable to retrieve the list of network adapters
Goto Start --> Run and type (1 line at a time and don't forget to press enter or the [OK] button for each line):
regsvr32 netshell.dll
regsvr32 netcfgx.dll
regsvr32 netman.dll
After each line you should get a popup stating something like "DllRegisterServer in <file> succeeded", if not, please post the error message here. When all succeeded, reboot and check the "network connections folder", the error message should be gone now ...
Aug 16, 2009 | Computers & Internet
I cannot restore my 5th generation 30 gig ipod
HI
Try this out
Disconnect and reconnect your iPod and then attempt to restore.
  • Restart your computer and then attempt to restore your iPod.
  • Disable or Enable Disk Use on your iPod and then attempt to restore.
  • Try connecting your iPod to a different USB port and then attempt to restore.
  • Remove any third-party USB devices you have connected to your computer (it is not necessary to remove your keyboard or mouse).
then try this out
  1. Disconnect the iPod from the computer and close iTunes.
  2. Highlight all of the following 10 lines of text that begin with regsvr32 and then choose Copy from the Edit menu of your web browser: regsvr32 /s softpub.dll
    regsvr32 /s wintrust.dll
    regsvr32 /s dssenh.dll
    regsvr32 /s rsaenh.dll
    regsvr32 /s gpkcsp.dll
    regsvr32 /s sccbase.dll
    regsvr32 /s slbcsp.dll
    regsvr32 /s mssip32.dll
    regsvr32 /s cryptdlg.dll
    regsvr32 /s initpki.dll
  3. Open the Notepad program by navigating to:
    Start > All Programs > Accessories > Notepad
  4. In Notepad, choose Paste from the Edit menu. Note: make sure that the text that appears in Notepad is the same as what is shown above.
  5. From the File menu, choose Save As.
  6. In the File name: field type appleipod.bat and save the file to the Desktop.
  7. Close Notepad and locate the appleipod.bat file. It should appear on the Desktop with the icon shown below: ts1539_1.jpg
  8. Double-click the file and you will see a black window appear on the screen for about a minute. Wait until the window automatically disappears and proceed to the next step.
  9. The appleipod.bat file can be deleted at this time.
  10. Open iTunes and connect the iPod.
  11. When the iPod appears in iTunes, restore the iPod and resync your content.
this should work fine
Aug 10, 2008 | Apple iPod MA446LL/A MP3 Player
Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll
I followed these steps and haven't had any issues since:
1. Go to START menu
2. Select RUN
3. Type MSCONFIG and click OK (or press ENTER)
This will bring up your System Configuration Utility window.
4. Select the STARTUP tab.
5. Find M3PLUGIN, untick it, select APPLY and then OK
This will bring a popup dialogue box stating the following:
"You must restart your computer for some of the changes
made by System Configuration to take effect."
6. Select RESTART.
When your computer restarts, you should no longer receive that message.
Jun 30, 2008 | Intel Motherboard
Error - Kernel32.dll
Microsoft defines Kernel32 errors as follows: "The Kernel32.dll file is a 32-bit dynamic link library file that is found in Windows 95, Windows 98, or Windows Millenium Edition (Me). The Kernel32.dll file handles memory management, input/output operations, and interrupts. When you start Windows, Kernel32.dll is loaded into a protected memory space so that other programs do not take over that memory space. On occasion, you may receive an invalid page fault (IPF) error message. This error message occurs when a program tries to access the Kernel32.dll protected memory space. Occasionally, the error message is caused by one particular program, and other times the error message is provoked by multiple files and programs."
Sep 21, 2005 | Polaroid PhotoMax MP3 Digital Camera
29 people viewed this question
k24674
Marvin
Marvin
