Question about Compaq Presario S4220NX (Refurbished) (DK396AR) PC Desktop
Booting problems with my video card?
My green power light on my monitor is blinking but I have no image on my srceen (no signal). I know my computer is running(fan etc. is on) and I can hear Windows running in the background.
Compaq Presario S422ONX
  • gidnnihs Dec 28, 2008
    One other comment: Prior to this, it's been hard to get the monitor to come on when it goes into "standby". I wiggle the mouse and it was taking a long time for the monitor to light up! I would have to hard boot the computer and then it would light up. I don't know if this tells you anything.
    I made a mistake over christmas and shut down the entire system while we were gone. Now I can't get it to come back on!
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    Your Graphics card might be fried up. If you restart your computer, does the symptom still persist? Have you tried testing your video card to other computer's motherboard?
    *drop a comment and I will assist you.
  • 45 Answers
First try to plug you monitor into another computer if possible and make sure that it works, if it does not then follow the directions that I have placed below.
What you need to do is pull off the side of computer and unplug the monitor from the card and look for the graphics card and once you find it and pull it out and either blow on it or get a can of air and make sure it isn't dusty, and also where you pulled it from clean there. If the whole inside of the comp. is dusty blow it out as best as you can with air. Make sure the system is OFF and UNPLUGGED. Other wise it is very possible to fry your whole system also make sure you ground yourself first to by touching the side of the case first. Also be warned that if it is covered by warranty opening the side panel of the computer could void a warranty. Plug the card back in, monitor into the card, and power to the computer and try again. Chances are it is a bad card but this is to make sure.. If this does not work go buy a new card and try it. Make sure it is the right type for your computer. If the new one does not work chances are your motherboard slot for the card went which is uncommon. If you have issues please re-post.
Posted on Dec 28, 2008
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
Monitor was in safe mode turned computor off and removed and replace ram. Monitor now flashing RV370 P N 113 A62801 106 BIOS not sure what to do now. to get computor booted back up
Hi...sounds like your video card has died on you. Do you have another video card lying around to swap out with the old and try?
When the video card is sending power to the monitor, the light will be green - if the light never turns from amber to green when the computer is booting, this means that the video card is not sending a signal to the monitor, probably because its toast.
May 01, 2011 | Computers & Internet
When i power on my pc,the monitor power indicator lights green but about 3s later it goes brown.the monitor screen remains unchanged as to when the computer was powered off.my email is...
You are not getting a video signal to the monitor. The fact that it is green initially shows it's working. When it turns orange, that's an indicator that it is getting no signal from the computer. So the next thing to check is if your computer is actually booting up or if your video card is going bad.
Do you normally hear a beep when the computer starts? Do you hear it now? If the answer is yes and no, then your computer is not starting up. To troubleshoot, I would suggest opening the case and disconnecting everything but the video, CPU, and memory. See if it starts. (you should get a message about no boot device if this happens)
If still no video, you have a hardware problem most probably related to the video card.
Mar 18, 2010 | Dell Computers & Internet
No picture - power button is blinking green
The "blink" is an indication that the monitor is *NOT* getting any signal from your computer's video-card. Either your video-card is the problem, or your computer is "sleeping", and you cannot "wake" it.
Reboot your computer, and watch the monitor, to see if anything at all is displayed.
Reboot with a different monitor connected, to see if anything at all is displayed.
If another monitor works, your monitor is the problem. If neither monitor works, it's the vide-card inside your computer that is the problem.
Aug 13, 2009 | Computers & Internet
Monitor will not display - when switched off and on again it say auto detect - entering power save
It is not detecting a signal from your computer.
This means your video card is not sending an image.
You can try another monitor, but I don't think that will help.
I would boot the computer into safe mode and see if that helps.
If it does, then the problem most likely is that your video card is trying to send an image in a resolution that is too high for your monitor.
Otherwise, your video card has a problem. (Assuming that your computer is actually booting up)
Aug 10, 2009 | Dell Computers & Internet
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
When I turn on my pc I an see the hard drive light working and flashing, indicating that it is loading up, but my monitor does not receive any video signal,so I hooked my pc to my freinds monitor and I got...
Sounds like your video card is bad. You will need to purchase a new one. On some machines there is 2 video connectors -like 1 on the motherboard and 1 other mounted in a slot just verify that you have tried both connectors if you have them before buying a new card.
NOTE: Usually the slot mounted video card will over-ride the motherboard video by default.
Good Luck!
Rich
Jan 30, 2009 | E-Machines eMachines Desktop PC
Is it my monitor or my video card
1.there might be a problem with your signal cable. if one of the pin in the signal cable is open. it might also happens
2.adjust signal cable.
3.Check VGA video card is working properly. unplug the VGA card and Re-plug to its slot. if your mother borad has inbuilt video card. this process cannot be performed
4.Even problem with operating system might also happen.. problem with Video Ram memory
5.if you want to check whether your monitor is ok. just get Cpu Box alone frm friends for a while for a testing.
6. if your monitor have problem then contact service centre.
Oct 15, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Compaq Presario S4220NX (Refurbished) (DK396AR) PC Desktop Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
