Question about Maytag MGR6772 Gemini Gas Kitchen Range
Maytag Gemini MGR6875ADS - Control Panel does not operate ovens
The control panel stopped working. At first the control panel would not operate once either oven was hot. Only the CANCEL button would beep. Then after we used it last evening none of the pads on the control panel work at all.
The clock continues to work, however, the clock does not reset when the unit is unplugged.
I left it unplugged all evening to see if that might have any effect but it did not change any of the symptoms.
huuum
  • 750 Answers
SOURCE: maytag electric gemini,model mer6755aaw
Hello bigboy1666,
Welcome to Fixya,
You said, Oven does not show any displace and does not work. When you try to turn on the top oven, the displace shows h3 132 and the clock shows 12:00 .
You try to turn the upper and lower oven, none of them work. The light in the oven comes on okay.
Lets try to reset the system.
trun off the range.
Now trhow the breaker in the electric box off for 5 minutes.
after waiting 5 minutes turn the power on and try the range!
Let me know how she works.
Huuum at your service.
Please remember to leave a rating!
Posted on Oct 06, 2008
  • 409 Answers
SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Posted on Oct 25, 2008
  • 441 Answers
SOURCE: oven not working Maytag MGR6875ADS
IF THE RANGE IS DOING EVERTHING BUT HEATING THE OVEN IT IS MOST OFTEN THE IGNITOR
Posted on Jul 19, 2009
SOURCE: Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Posted on Oct 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: Maytag Gemini mer6770aw
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Maytag Gemini gas range.
Not that you can do at home, I would just replace it as it is the only component that might cause this.
Jul 13, 2016 | Maytag MGR6875ADS 30" Freestanding Gas...
Display panel control
I had the same problem with my Maytag range. I pulled out the stove and unplugged it. I took off the back panel that protects the digital panel that controls the oven. There was dust all over the electronics. I got a can of compressed air that is used for computers and blew all of the dust out. Plugged the stove back in and it has been working fine since then. Dust can create static electricity. The replacement panel is $300, plus labor.
Nov 28, 2013 | Maytag MER6769 Gemini Electric Kitchen...
The ovens won't light, but the broiler does.
I think it saw it;s better days. time for a new one.
Nov 04, 2012 | Maytag MGR6875ADS
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
The "cancel" button for the upper oven on my Maytag mer6751aaw gemini electric range just stopped working. To turn off the heat I had to unplug the whole thing! Is this something I can fix myself, or must...
Hi. due to the fact that the control is one whole piece, this will require you to replace the entire main control board. The cancel key is integrated into the control board. There is an overlay that protects the circuit, but it is a separate part, and is not connected to the main board. This repair will require you to disassemble the entire control panel. The board is located just behind the control panel piece.
Click here to view a diagram of the control sector, and panel.
The control board is labeld number three on the diagram, and the control panel is labeled number 1. There are four screws on the back side of the rear cover. Once these screws are released, you can access the board, from the rear of the control panel. The part number for your replacemnt board will be W10166967
  • NOTE_ If you are not comfortable with totally disassembling your control panel, and replacing this main control board, i would suggest to call for service. this job is not easy.
Nov 30, 2009 | Maytag MER6751A Electric Kitchen Range
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oven not working Maytag MGR6875ADS
Jul 19, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Top Oven Stops Working
Sounds like a bad sensor for the oven here is the link to the repair manual to help you out
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Feb 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Open Questions:
Maytag MGR6772 Gemini Gas Kitchen Range Logo
707 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
