Question about Brother MFC 3820CN All-In-One InkJet Printer
Broken Hinges I have a Like new MFC-3820CN. The hinges, both sides, have broken. And after a close inspection, I really can not understand, HOW THEY WOUL NOT BREAK. So here is my question. Where can a person in California obtain new hinges? Is this thing now junk? I mean if it has pronted 30 sheets of paper I would be surprised.
  • 1 more comment
  • Bill Nadzam May 08, 2007
    I have started down both paths. Super Glue did not hold. And a scrap one is more than I wish to pay. Next time, its HP I think.
  • lgoering Feb 06, 2009
    I have the same problem. The hinges pieces are attached to each other with a stupidly small loop of plastic. I know someone with a model 3420CN. Same problem.
    I'm tossing both Pieces of S... in the garbage. I won't be buying anything with the name Brother on it, ever again.
  • UP4IT_NZ May 26, 2009
    But how do you actually remove the hinges, thats my problem?
I removed the hinges and drilled the flat end of them with a half inch drill. There is a spring inside that needs to be removed. It works fine now, except that the lid needs to be propped open when changing ink ( I use a plastic chop stick for this purpose).
Posted on Apr 18, 2009
    Genius:
  • 2,985 Answers
Repair hinges with super glue or fabricate something but parts of this nature are out- no way Look for one somewhere that has expired for other reasons and acquire the scrap for parts
Posted on May 08, 2007
My hp4050n laserjet cover top hinges are all broken and its saying CLOSE COVER TOP when i want to use it.
Your LaserJet can't detect that the cover is closed because the hinges are broken. Replacing the broken cover should set things right.
Oct 15, 2018 | Office Equipment & Supplies
Oven door will not close the whole way
Your oven door hinges(s) are broken, the springs that hold the door closed inside the hinges are either weakened or their mounting points have become worn.
You need to purchase a pair or replacement hinges which you can fit yourself if you have some basic mechanical skill. Don't try to just replace one side if you determine which side has failed as the extra strain put on the old hinge can cause the door to twist and break the door.
Mar 05, 2012 | Tappan Kitchen Range
Driver side door does not close. Latch broken and door sits down below catch on body of car.
may need new hinges on door and body of vehicle, if so it is about 600 -700 to replace , may be able to get new bushing and pins , without replacing hinges
Sep 09, 2010 | 1998 GMC Jimmy
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Door doesn't close tightly and sometimes the light stays on. Can I tighten the springs?
One of both of the springs are probably off or broken. Slide it out and inspect the hinges and springs which are at the bottom of the door. The springs hook to the hinge and the base of the oven farther back. You may have to remove the side cover.
Nov 27, 2009 | Jenn-Air Ovens
Broken nintendo ds lite hinge. Do I send it away for repairs or get a new console?
Nintendo will fix the hinges depending on a few things, first thing would be to determine how the hinges were broken. The hinges are tested before they leave the factory, the only way that they actually break would be because of physical damage/impact. Physical damage is not covered under the manufact warranty so you would get a discounted price depending on if your under warranty or not. Regardless giving them a call and having their techs fix them will be the best bet, not only because you know it will be fixed right and your warranty will start over the day it gets repaired.
Dec 15, 2008 | Nintendo DS Lite Console
Broken hinge Colman cooler
I have three colman coolers with broken hinges. I would like to find some new hinges to replace them . model # 6270 6273
Oct 03, 2008 | Coleman 36qt Xtreme Cooler
Platten hinge broken
Those hinges have been updated by Brother. You need to go to Brother's website and find a local service center.
Jun 17, 2008 | Brother MFC-8440 All-In-One Laser Printer
CHECK ORIGNAL
you have the problem with your adf on machine try to see where is sensor jammed or broken
Feb 28, 2008 | Brother MFC-8840D All-In-One Laser Printer
Document Cover Open
I had the same problem with mine. Lift the top scanner, and check the hinges on the left. That error message means that the little black sensor on the left next to the hinges is not meeting flat with the unit when closed. Hold the sensor in for a few seconds, and your printer will start working properly.
Oct 11, 2007 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC 3820CN All-In-One InkJet Printer Logo
176 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
