Question about Doro 520 DECT Cordless Phone
Redial I desperatley need a phone number out of this phone but it was the second to last number dialed can I do this.
Try pressing the X button ( mine is one the top right) this shows the last five numbers you dialled. Then just use the 1 or 3 buttons to scroll through. These are the arrow buttons. Hope that helps ( and I hope we have the same model).
Posted on Apr 30, 2007
Automatic redial phone option
On most cell phones, to redial the last phone number dialed, press the green phone icon when the keypad is displayed on the screen. You can only redial the last number dialed. To obtain a copy of the user manual, follow this link and download the pdf. http://www.gsmarc.com/huawei/ascend-g610/manual/
Nov 14, 2013 | Huawei Cell Phones
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
How do I redial on a uniden dect 6.0 cordless phone
bottom lh black button is redial button just press it and it will dial the last number called
Jan 11, 2012 | Uniden DECT 6.0 Cordless Telephone...
Where is the re-dial?
Hi, Hope this helps.
Making a call using the redial list
The last 5 phone numbers dialed are stored in the redial list.
  1. 1 {REDIAL}
  2. 2 Press {^} or {V} to select the desired number.
  3. 3 phone icon.
I have also inserted a link to the manual below: http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.PDF
Hope i have helped, ALAN
Jun 28, 2011 | Panasonic KX-TG5632 Phone
HOW TO USE RECALL KEY OR HOW TO USE THE REDIAL FUNCTION
Don't confuse the two. In most systems, the RECALL button gives you new dial tone on the line you're currently on, and the REDIAL function will dial the last number dialed or a saved number.
Since you're asking about a phone and did not list the SYSTEM, if you set has Last Number (LNR) or just redial, when you press the button, it will either try to use the last line dialed, or you may have to select an outside line and get a dial tone, then press the LNR button. It will dial out. If you press the RECALL button, it will drop your present call and give you new dial tone without having to hang up, pick up the handset, and select a line. You may actually have to press both buttons to effect a LNR sequence.
Carl
Aug 18, 2010 | NEC ETJ 16DD-1 Corded Phone (necetj16dd-1)
When putting the phone in the clip sometimes it will redial the last number called. I don't see any buttons on the outside that would redial. I know the right button on the right top brings back the last...
The right button on the right top that brings back the last dialled number may be the culprit. Check to see if a long press on this button redials the last number. If so, then the clip is pressing it too long. Can you avoid using the clip or modify the clip so as not to press this button.
Nov 09, 2009 | Motorola Mobility i560 Cellular Phone
Automatic redial malfunction
It's been a long time since I have used Panasonic analog phones, but the redial function in them used to be mechanical. It dialed 15 times with a 45 second pause between attempts. The key was, it expected you to pick up the handset, cancelling the redial if you got an answer.
If you got an answer and didn't do anything, it hung up and redialed again until you picked up the handset!
Could that be what your system is doing?
Carl
Sep 14, 2009 | Panasonic Lands Phones
Where is the redial button on my KX-A144ES
you need to press the interlocking circles button on the handset (in the centre at the top) to show the last number dialled (incidentally, you can now press the down arrow to scroll through previous dialled numbers).
When you get to the one you want, simply press the green handset button to dial the number displayed.
That's last number re-dial in 2 steps (there is no single click solution)
Feb 06, 2009 | BellSouth GH5816 Cordless Phone
Recall last phone call to see number
Press "Redial" then *(star). The redial key is a multifunction key. You can either use redial or utilize the phone system speed dial directory.
Jan 09, 2009 | NEC DTH-8D-1 Corded Phone
Redial last number called when turning H700 on
If you are turning it on with the button, that is why. To turn on the H700, you should just need to open the boom mic. Once open, it should connect with your phone. The H700 is designed to dial the last number when the button is pressed. No way around this one.
Dec 01, 2008 | Motorola Mobility H700 Wireless Headset
Doro 520 DECT Cordless Phone Logo
79 people viewed this question
Top Doro Lands Phones Experts
Gene Tuck
ray gallant
Jojo
Are you a Doro Lands Phone Expert? Answer questions, earn points and help others
