Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Code h120 machine turns slowly and displays code h120
  • sandracarr01 Dec 28, 2008
    error code H20 after pipe off pump now refitted how do I remove the error code
  • Hotpoint Master
  • 3,463 Answers
I think you mean code H20, if so it means no water coming in, check water turned on ,check hose(s), check filter in inlet valve is clean, check water pressure is sufficient.
Plz rate my solution.
Thanks.
Posted on Dec 28, 2008
Have a tradesman h120 pressure washer..it will not spray any water at all.. pump is workig?
If the pump was run without having the supply hose hooked up and water to the pump before turning it on, you have destroyed the seals and they need replacing.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
May 24, 2014 | Garden
LX30H THROWS A CODE EO after running awhile. I hit the high reset button under the flaps on the front for both the boost and reg elements . It will work for a couple cycles and then does the same thing....
Machine won't fill or won't fill high enough. site water pressure meets minimum flow pressures. (LX18, LX30 display shows working.
"E0," "E2," "E3," or "E4". LX40 display shows "DR1 PRBLM," "FILL1 PRBLM," FILL2 PRBLM," or "FILL3 PRBLM". Machine will not run.)
1. Low water pressure - check for clogged hose strainer; check that
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be
4. Drain valve open - turn machine OFF to drain machine, then
ON. Repeat twice (this assists in clearing any drain valve
obstructions). Wait for machine to reach READY mode and
press WASH. Slowly open door several seconds later and note
water level. Close door; 30 seconds later, open door slowly and
check that water level is the same as it was. If not, repeat the
OFF-ON procedure. If problem persists, call your local Hobart
Service Office.
5. Delime machine.
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F18615%20Rev%20I.PDF
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 10, 2013 | Hobart Lx30h Commercial Dishwasher
Error code E20
Turn the dial to off.
Press and hold the start pause and nearest option button to it.
Whilst holding them, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons.
Now turn the dial slowly through each position, stop and position 10 (9 clicks after letting go of the buttons) and note the error code displayed.
Continue turning the dial until you get to off.
Now turn to any programme, then, turn to off again.
Finally, turn to a programme and try the machine.
(It is very important that you turn to Off, a programme and then Off again).
Let me have the error code you retrieved if the appliance still doesn't work.
Oct 14, 2012 | Electrolux Washing Machines
Reboot my h120 iriver
every time you turn on h120 (it will reboot)...update by itself...unless you get stuck while playing (freezes)...you will need a little needle/ safety pin to stick in the tiny hole on the bottom of the h120.......just tap it and take the pin out...player will shut down and start up by its self........feel free to rate the help
May 13, 2010 | iRiver iHP-120 MP3 Player
Pioneer GM-h120 car amp how do i get it to turn on with the remote from my stock 2004 f350 radio and cd
u could run the remote from the radio fuse and install a toggle switch to turn the amp on and off
Jan 29, 2010 | Car Audio & Video
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Regional code
1) Turn the DVDR3590H on, with no DVD in the drive
2) press HOME, so the browser appears
3) press PLAY/PAUSE. The display on the machine should say "BROWSER"
4) Slowly enter the following code: 159121212005255 (the numbers should appear on the display)
5) press PLAY/PAUSE.
6) Turn the player off
You might have to try it several times before the numbers will appear in the display panel. Don't enter the numbers too slowly either.
Oct 19, 2008 | Televison & Video
AEG OKO LAVAMAT
- Turn Off - Press down Prewash and Soaking together. Keep them held down. - Slowly turn the knob clockwise to Gentle Spin - This should reset the machine
If you get a beep instead of a reset, there is a problem. - Keep the two buttons held down. - Slowly turn the know anti-clockwise to Wool 40 degrees - It should now give you an Error Code. - Google for the manual, which will tell you what the error code means
Feb 29, 2008 | Washing Machines
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
199 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
