Question about GE Profile PDS20SFSR Bottom Freezer Refrigerator French Door
Problem: GE BOTTEM MOUNT NO FROST REFRIGERATORposted by rshott1 o
Problem: GE BOTTEM MOUNT NO FROST REFRIGERATOR posted by rshott1 on 12/28/2008
How do I replace the evaporator fan ?
  • trlemay Jan 11, 2009
    The evap fan motor assembly p/n 12442204 or 12013209Q fits inside the bottom freezer of a Amana Frig . The problem is, it has two green wires, one white wire and one red wire and only three clips extending from the fan motor. Two are side by side and one is on the bottom for the ground.
    Thank you for your assistance. T.
Thanks, problem solved.
Posted on Dec 29, 2008
GE Profile PGSS5NFXA SS Refrigerator Freezer; the frig warms up?
The problem is most likely to be the defrost heater Check the back of the freezer compartment for frost If you have frost on the back wall of the freezer compartment you will need to unplug the unit and remove everything from.it next get several towels to place on the bottom of the freezer to catch the water from the melting frost Using a hairdryer heat the frosted area to defrost remove the back panel of the freezer under it you will see a frosted up mess after defrosting you will see one or 2 heaters mounted on metal brackets they unplug and can be tested using a ohmmeter or continuity tester also check the defrost thermostat an replace defective items.put it together you should be all set
Aug 02, 2014 | GE Refrigerators
I have a GE Profile Arctica refrigerator that I purchased used last week. Developing quite a bit of frost buildup inside the upper half of the freezer. Also noticing that the flap for the ice doesn't...
Hi yes the flap will cause the frost, you need to replace the solenoid that controls that flap, if this is a side by side, the solenoid is behind the dispenser controls on the freezer door, you take off the control board, and then remove the little mount behind that it has 4 screws and you will see solenoid on right side, it needs to be replaced.
Sean
Mar 17, 2011 | GE Profile Arctica Stainless Steel Top...
Water wont drain stays in the bottem of fridge how to unplug
Clogged drain tube, blow it out. You may also have a P-trap in the back of the unit that needs to be cleaned. Remove it and flush with hot water.
Feb 23, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Freezer not cold and guide fan barely spinning
Do you see frost building on the back freezer wall? It could be a failed defrosting has plugged up the evaporator. You need to access the service panel and have a looksee. BOTTOM MOUNT SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 03, 2010 | GE Profile Stainless Bottom-Freezer...
GE J SERIES MODEL TBX25PAXCRWW WITH KNOCKING NOISE WHEN MOTOR SHUTS OFF.
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Feb 28, 2010 | GE Profile 24.7 cu. ft. Top Freezer...
My GE profile refrigerator's ice maker is frosting over at the exit point for the ice leaving the ice bin. I have cleaned it repeatedly and have no clue as to the cause.
The flap door that opens to let ice drop out of the door has a bad seal or the plastic mounting arm is cracked or broken,this is allowing moisture to enter and turn to frost.This will continue to happen until the flap door is repaired,and sealing correctly.
Sep 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
How to trouble shoot defroster themostat and element
The defroster is on a timer usually locater in the roof of the refrigerator. Turn it until it shuts the compressor down. Use your thumbnail. It should start up again on it's own. If you're having frost problems, look for mouse damage in the back of the unit, where the pipes come through.
Jun 15, 2009 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
GE bottem freeze- not cooling
It is not so much the freezer motor icing up but the drain trough that takes the water from defrost down to the pan.Possibly your drain trough is clogged and needs dethawing and cleaning.
eeggman
Dec 05, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
GE Profile PDS20SFSR Bottom Freezer Refrigerator French Door Logo
171 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
