I have downloaded Skype but it isn't connecting.
My ISP is Virgin Media and my connection to the internet is cable via an NTL modem. Would it help to remove the Skype and then reinstall it?
  • 6,487 Answers
Yes removing first the skype from your computer will be a great idea to fix this problem , make sure when you reinstall skype use the latest version from their web site...
Posted on Dec 28, 2008
Connecting Cisco 851 cable to virgin media super hub Problem
are you using the cable modem as your router? if so then simply hard code your media hub to a static ip address in the same range that the router/modem communicates on. (private address side)
Dec 27, 2013 | Computers & Internet
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
CHANGE FROM WIRELESS TO WIRED INTERNET CONNECTION
It is possible .. just get youself an ethernet cable .. connect one end to your router and the other end to the back of the pc ( ethernet port ) .. and u will be connected via the wire.. You can disable the wireless connection from the router for that you can either call your Internet service provider or the netgear support team.
All The Best!!!
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Zooless
May 24, 2010 | Computers & Internet
I have a modem supplied by virgin media can i
Well, Virgin Media provides Cable Internet connection and with those connections you can not use this ADSL modem. If you have internet services from Virgin.net then only you will be able to use this modem with them. This modem will not work with Virgin Media connection.
Hope this answers your query.
Regards
Anand
Mar 30, 2010 | NetGear DG834G Router
Buffalo router
Let me verify your network configuration with you. You have your modem connected to the WAN/Internet port of your router via an ethernet cable and then your PC connected to your router via another ethernet cable, correct?
If this is your setup, then try this:
  1. Unplug the power cord from the modem & router
  2. Plug the power cord into the modem and wait for it to boot up (most modems have an "Internet/Connection" light to indicate they are connected to the ISP)
  3. Plug in the power to the router, wait for it to complete the bootup process (usually when the lights stop flashing it's done), and see what happens.
Feb 09, 2008 | Buffalo Technology (WYR-G54) Router
Can not connect to router via a wireless connection.
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Jan 23, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
No connection
Is your physical connection right???
the WAN port should be connected to your modem, and the LAN1 should be connected to your pc.....
if right, but still doesn't connect....
check if the lights of your router is working
the POWER should have a solid light,
the STATUS, WAN, LAN 0r WLAN should be blinking...
What kind of connection do you have?
is your modem automatically detects your password...?
or you manually type your password to connect to the internet...?
Jan 17, 2008 | D-Link DI-704P Router
Wlan connection problem
please be specific, what exactly is happning???
Nov 07, 2007 | Acer Aspire 5630 Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
