Question about Symantec Norton AntiVirus 2004 - (Open Box) for PC
Pen drive stops functioning - Symantec Norton AntiVirus 2004 - (Open Box) for PC
  • Anonymous Dec 29, 2008
    I bought new Transcend 4GB pen drive. The drive works for first few times (3 to 4) after which the pen drive stops functioning. When I replug the device PC freezes, upon removing the pen drive PC works fine.
    I could not even format the drive, I have replaced the pen drive as it was in warranty and got a new drive. Still the same problem, the drive works perfectly fine for first few times then stops working.
    As of now I have replaced the pen drive 4 times and got new ones, but the problem does not seem be be fixed.
    Once the pen drive corrupts, it does not work in other PCs as well. I scanned my PC for virus, but none deducted.
    Now my system does not detects the drive, neither able to scan the drive, nor able to format the drive. Also does not work in other PCs as well.
  • Sebastian Salgado May 11, 2010
    What do you mean by "stop functioning"?
    Please, be more specific describing the problem
    President:
  • 281 Answers
I forgot to take out my oen drive from my pant and put the pant for washing. I removed the pen drive and it was well wet in soap water...Now what should I do? I am worried about the data as well as the...
Just put your pen drive in a sunny atmosphere for 2 or half day. I have also an experience like you. Till today my pen drive works fine and your pen drive will also be work fine. Thanks for using FixYa.
Sep 11, 2011 | Computers & Internet
Not format 8gb pen drive
What do you mean not format?do you mean not formatted?
  1. Go to my computer
  2. Right Click your Drive and on the menu choose format
  3. I suggest you use fat32 and do not use QUICK FORMAT.
  4. Press Start.
If this doesnt work try this one.
  1. Download this Software -------------------> http://www.mediafire.com/?x2yt2fgyzo2
  2. Extract and Install it to your Computer
  3. Plug your Pen Drive
  4. The software must automatically detect your pen drive
  5. format the pen drive. Do not use quick format.
Hope it help. Please give me updates regarding this problem thanks.
Jun 29, 2011 | SanDisk Computers & Internet
System hangs by inserting pen drive.I have tested the pen drive in other systems the pen drive is perfectly functioning. please help
run compatibility wizard and chose that flash drives to run as / chose different settings,
usually caused by older flash drive drivers
check manufacturers web site for compatible drivers/ upgrades
Feb 11, 2011 | IBM ThinkCentre S50 8183 - P4 3 GHz...
PEN DRIVE SHOW USED AND FREE SPACE 0 BYTE ?
Here is the solution,
After you connecting the pen drive go to my computer.
Select the drive of your pen drive. (For eg: E:/)
Then right click on it and select format.
After formatting the pen drive restart your computer.
Then conect it again.
This should work .
My pendrive was also like this when I brought
and formatting solved my problem.
Try this.
Dec 13, 2010 | Transcend (589307) Media
My pen drive is 8gb but i think bad sectors there in my pen drive so working only 2gb what i do
Hi User ,
In case you have bad sectors in the pen drive ,It wont Function properly , its always advisable to Format the Pen drive and Use it Afresh .
1. Copy the Content of the Pen drive to the Computer
2. Right Click on the Pen Drive Drive Letter Ex E:\ or G;\ and Click on format
3. Select Quick Format
4. Once the Format is Finished ,,Right Click on the pen Drive Letter and Click on properties to Check the Available Free Space
Please let me know if it worked
Thanks and regards
Aboobacker sidiq
Internet explorer Specialist
Nov 27, 2010 | Computers & Internet
Pen drive not opening and say format and not formatting
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Nov 04, 2009 | Fuji (MAP3367NP) 36.7 GB Hard Drive
Pendrive Shows Write Protected
These are the tech specifications of your pen drive which includes write protection micro S/D switch. So search it and make it read and write
USB 1.1 compliant and 2.0 compatible,
True Plug and Play for hot swap function
Maximum Transfer speed of 1.5MB (12M bit) per second at full speed
Powered directly via the USB port.
No external power or battery needed.
Operating Systems Supported: No driver required for Windows Me/2000/XP, Mac OS 9.0 or later, or Linux kernel 2.4 or later.Only Windows 98SE needs the provided drive
Write-Protect Function: Write-protect switch Security Function: Password protection available via supplied software (Windows environment only) Boot-Up
Function: Makes JetFlash a MS-DOS Boot Disk LED: Flashing LED indicates
Data Traffic Specifications : Size: 75mm X 11mm X 25mm (L x W x H)
Weight: 15g Data Retention: Up to 10 years Shock Resistance: 1000G (maximum) Erase Cycles: 1,000,000 times Speed: Read 9.0 Mbyte/s, Write 8.0 Mbyte/s (Max.) Certificate: FCC, CE,
BSMI System Requirements: Win 98/98SE/ME/2000/XP, Linux Kernel 2.4 and above, Mac OS 8.6 or later
Aug 12, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Pen drive is not opening
have a 2gb transcend pen drive.till now it was working properly but now wen i try it says insert an drive into I.the light is glowing and it is getting detected.But i am not able to read the data.anyone can please help me.
Aug 11, 2008 | Transcend (589307) Media
Pen drive not functioning in all computer
please check the usb port, it should be same as your drive,i.e 1.1 or 2.0
Jul 14, 2008 | Electronics - Others
Open Questions:
Symantec Norton AntiVirus 2004 - (Open Box) for PC Logo
37 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
