Question about Sony VAIO VGN-FE550G Notebook
Built-in camera not connected
When using web cam on yahoo messenger an error displays that camera is not connected.is there any solution on control panel?
Why does my webcam show a black screen?
Which version r u using? 8 or 9 beta?
1.for 9 beta:
*Can you see your cam clearly? I mean no black screen.
If your web-cam is having black screen, then you have to set it.
On main messenger screen:
click messenger
click connection
tick "connect directly to the internet"
click apply and ok.
Then open your cam and check if it working or not.
*Visit:
http://help.yahoo.com/l/us/yahoo/messeng...
2*Follow the steps below to change your camera source.
Click "Messenger"
Click "My Webcam.
Click "Messenger" again.
Select "Preferences."
Click "Webcam."
Click "Camera Source."
Click the pull-down menu and select the camera you want to use.
Click "OK."
*Best is to visit following link:
*Messenger 8 :
First, please check your connectivity settings within Yahoo! Messenger to make sure you're not connecting through a proxy server. Here's how:
Select " Yahoo! Messenger."
Select "Connection."
Select "No Proxies."
Click "OK."
Close Yahoo! Messenger completely and start the program again. This should eliminate the error message.
please visit these site
www.autodirectmarket.com , www.autoloanph.com to learn more
Apr 28, 2011 | Yahoo Messenger
My yahoo and webcam won't work together i keep getting an error message on yahoo, what do i do???
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to Yahoo Messenger.
COMPATIBILITY WITH YAHOO MESSENGER
Use Internet Explorer to visit this page to check compatibility and automatically download the latest webcam control
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/webcam/mstacamtest.html
CONFIGURE SOFTWARE
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it. Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Of all the chat programs, Yahoo is the most painful software to set up but if you follow these instructions you should be ok.
INTERNET CONNECTION
Webcam connected
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING
> Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start. You should be rewarded at this stage with your happy smiling face.
SET WEBCAM DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK
Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
PERMISSION OPTIONS
> Messenger > Preferences > Webcam - make your selections ( who you will allow to view you) > Apply > OK
IN USE
When you are both on line and wish to show your webcam > Actions > 'Invite to view my webcam'. This will launch an invitation on your contacts screen when they 'Accept' your webcam broadcast will start- There can be considerable time lag ( 1 minute) before they see you, so don't be too impatient ( You can check the status on the bottom left of your webcam panel. You can 'drag and drop' the frame to a convenient location by grabbing the top border.
Your contacts needs to configure their connection the same as above or they may get a "webcam not connected" message
Dec 06, 2009 | HP USB Web Camera
I can't chat with my web cam with other ACER netbook users. I would like to chat with my friends who have ACER netbooks but i cant seem to figure out how. I own a ACER laptop netbook with a built in web...
Do you use yahoo messenger to chat? If your are using yahoo messenger, while chatting, look be-nit the chat box, you would see a web cam symbol, click it and you will see a warning box pop out. Click OK and your web cam will automatically be activated.
You would have to wait a little while for the web cam to show, because it has to load. Loading time depends solely on your computer and internet connection speed.
Best wishes.
Nov 28, 2009 | Acer Aspire 5500 5570-2609 Laptop
Pk635k web cam
Plug in webcam
Visit this page, using Internet Explorer only !!
Make sure your webcam is displayed and allow time for control software to download onto your computer
Once your webcam is working here, you know its compatible with Yahoo and you can make your settings.
Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, or disable/enable them webcam in Device Manager.
INTERNET CONNECTION
Webcam connected
TESTING
DEFAULT WEBCAM
Sep 10, 2009 | A4tech PK-7ma Flexi Webcam
Acer aspire one webcam. HELP?
The Acer Crystal Eye Web Cam automatically integrates itself into whichever program you are using be it an aftermarket video control or Windows Live Messenger or Yahoo Messenger. The only way I know how to bring it up MANUALLY is to go to the Control Panel or your Start menu (in Accessories) and bring up the Scanner & Camera Wizard. When you bring that up, click "Next" and it will start the camera and you will see yourself. When using a program like Windows Live Messenger (version 8.5 is the BEST!) you will have to tell the program what source to use for the camera, Your only choice is the Crystal Eye Web Cam unless you have installed a different cam that sits atop your screen, in which case, tell the program to use that one. You might try downloading a program called YAWCAM from the web and installing that. Just do a Google search for it. Give that a try because the Acer web cam doesn't do video with the limited controls in Scanner & Camera Wizard.
May 18, 2009 | Yahoo Messenger
Inverted picture on yahoo messenger
under c:\windows\bisoncam there is a program that will allow u to change this.
Nov 26, 2008 | Computers & Internet
Web cam getting network error
goto yahoo messenger -> prefrences - > webcam -> camera source check if it found or not if not reinstall the camera driver hope it willl found and work
Oct 15, 2008 | Yahoo Messenger
No transmission when used with messenger
Hey guys I'm having the same problem i got the logitech quickcam express and when I try to connect to yahoo and even aim it comes up connecting...then attempting to reconnect, then an error message comes up. The cam works fine, it just won't connect to the messengers. Did you guys figure it out? Thx B
Nov 14, 2007 | Logitech QuickCam Express Web Camera
Sony VAIO VGN-FE550G Notebook Logo
121 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
