Question about JBL Cinema ProPack 600 System
Panasonic multi connections
Hi am really struggling ! Have the Panasonic freesat tv and am trying to connect a Panasonic home cinema system and Panasonic Blu ray - the problem is I cant get any sound from the full set of speakers on the surround system and indeed it doesnt seem to work when connected only to the tv with HDMI - I was under the impression with the Viera link etc that all I would need to do would be to HDMI the surround sound system to the back of the TV, and again with the blu ray and all would become compatable !! Please please help
  • chris grams
    chris grams May 11, 2010
    or the other devices?
  • chris grams
    Have you enabled surround sound on the tv?
    Problem Solver:
  • 9 Answers
HDMI audio in this setup is a one way street. Audio will not come back from the TV to the audio system.
Sorry as you have not shown the model number I can not advise on the system fully.
However, it is standard on the current Panasonics to use Optical audio as a return feed or phonos.
Optical would be best as it carries full digital surround, whilst the phonos only carry "surround"
It may help for you to look a the new Panasonic web sit as there is now an interactive "How to connect your system"
PanamanNE
Posted on Jun 22, 2009
Hi i have just connected up panasonic home cinema system via my projector and the titles etc are back to front any ideas ?? Regards
Trying to understand your problem. Sounds like an orientation problem with your projector. Check your manual to get image orientation setup correctly for your projector. Look for projecting image onto the front of screen instead of projecting image thru the back of screen. Some times the application calls for projecting from behind screen just like a projection TV.
Feb 14, 2015 | Panasonic 5.1 DVD Home Cinema System 1000W...
Panasonic home cinema connection issues
What other audio/video outputs does the TV have? Does it have an HDMI port? If so, connect TV to your home theater using HDMI to HDMI.
Jun 07, 2013 | Panasonic SC-BTT490 5.1 3D Home Theater...
Connecting Panasonic SC-PT550 to TX-L42E5B
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
Nov 26, 2012 | Audio Players & Recorders
Is it possible to connect an LG 5010 tv to a
Yes, you can connect any home system into the TV by either using a scart or HDMI connector to produce the picture on the TV. The sound will still be present through the cinema system
Nov 22, 2009 | LG 42LC2D 42 in. LCD HDTV
How do i connect my non hdmi xbox 360 to my panasonic scbt205ebk home cinema and panasonic 42v10 plasma so that the sound comes from the home cinema system. i also have sky hd
If you use a component system (1 yellow video wire, 1 red audio wire and 1 white audio wire)
You will have to connect the audio wires to your cinema system and the video directly to your set.
The unfortunate part of this is that when you want to use your system, you will have to change the input of the TV AND the Cinema system.
The same would be true if you wanted to use the DVD connectors (YBPBR). You would connect the video to the TV and the audio to the Panasonic unit.
The system you have is meant more for just playing DVD's and not a total cinema system. This is why there are limited (extremely limited) video inputs. The system is mostly for output of sound and of a the built in DVD video.
Aug 05, 2009 | Panasonic Televison & Video
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Jan 04, 2009 | Panasonic Home Theater System System
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
JBL Cinema ProPack 600 System Logo
198 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
