This problem should be removed because:
Problem with PC Laptops
how did u install win xp on compaq presario CQ60 104tu?
Hi, I am facing problem with installation. I have already slipstreamed ICH10 SATA) drivers and service pack 3 in my XP installaion cd. This cd works fine on other machines that require SATA drivers during installation to recognise the SATA har disk.
On Compaq CQ60 104 TU , it recognises the hard disk,and i am able to partition it. However after the first reboot, the setup stops giving BSOD (Blue screen) and nothing seems to go ahead. I have tried diferent CMOS settings but there is hardly any scope due to limited settings available there.
I have checked the memory and Hard drive and found OK.
Solutions (10)
Best Solution
to install xp in any machine that has an intel chipset be it hp, dell or whatever is relatively easy ....the solution is found here
go to http://downloadcenter.intel.com/ and in the search textbox type "
32-bit Floppy Configuration Utility" then download it.
extract the content of that zipped file that is called f6flpy3287.zip .
then click on this site http://www.tacktech.com/download.cfm?file=microsoft/sata/sata-drivers.zip....here you get all the drivers for sata intel chipsets ....The content of this zipped file is similar to that of f6flpy3287.zip but its advisable you use f6flpy3287.zip contents to slipstream.
secondly download a software called winlite from http://www.nliteos.com/download.html ...its a freeware
then follow this site
http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html
Altenatively ....for the ... advanced users
http://www.tacktech.com/display.cfm?ttid=411
yours karanja
karanjae@gmail.com
kenya
My Name is maina (Kenya) and I had the same problem but is all now solved, please contact me on minor726@yahoo.com, And I'll guide you at a very small fee
Go into bios and change hard drive from SATA to IEEE
process of slipstreaming for cq60 104tu
Remember, you have to manually load disk drivers at the begining of the windows cd boot, prior to installation. Windows will ask you at the bottom of your screen "load third party drivers..." Check that you slip streamed with all the correct drivers for SATA. I don't know your Compaq hardware flavors so I don't know what you need. There are many SATA drivers. You need to get all your hardware specs in vista prior to XP install, as you will not have them otherwise. Use Belarc to find out about your hardware. Drop all your drivers onto second partition, or create a CD. Every driver is availiable from vendors, or HP/Compaqs website. Don't use driver websites. I am running XP on a CQ50, no problems, runs better.
i m not able to install windows xp on my compaq cq60 104tu laptop
when i boot the cd the exatrating process work properly and after extraction of all file when windows is startup a blue screen appears and
and message displayed in the screen check ur hard disk for vireuses
and installation stop
I used a dell windows xp pro service pack3 cd . After pressing the any key cd the screen will remain black leave it for 5-15 min and then press the spacebar you should be able to continue the installation .
to install the windows xp in compaq priserio60 laptops. insert the windows98 cd and select work with cd-rom support. in the A:/> type fdisk and delete all the partisions and creat a single partision. and exit from the fdisk and restart the system. then again go to the A:/> and format the c drive and restart the system and remove the windows98 cd from u r system. and insert the windows xp cd in to the drive. and press any key to boot from the cd or dvd. then follow the steps to install the windows xp and enjoy u r windows. to down load the drivers for the windows xp click on this link http://www.getpcmemory.com/drivers/download-compaq-presario-cq60-notebook-series-windows-xp-drivers/
hello mr shrikantdudh cq60 104tu dosent having a ICH10 CHIPSET, just go for (ich9 AHCI CONTROLAR (MOBILE) IF U DOSENT HAVE .. E-MAIL ME ON ameetpatel007@yahoo.co.in/gmail.com/hotmail.com/rediffmail.com/zappakmail.com i send u throu mail and all procedure to install xp and supported drivers for xp...
AMEET PATEL
CREATIVE COMPUTER
AHMEDABAD
9426063555
sir this is not a solution.. if they dont have a sata driver of floppy drive than what to do? i have all solution for this.. and very simple for all dealer to do this... kindly e-mail me on [ameetpatel0072yahoo.co.in] thanks.....
guys i too tried with slipstream that didnt work.
now follow the steps i tell u
things u need
1. a notepad.
2. a pen
3. 2 blank disc
4. information about ur drivers.
5. a vista or 7 operating system
u might be wondering y a vista or 7 operating system.
we need to find the configration ur laptop is made up of.
so for it click on my computer then properties and then get to device manager
first click on the options of bluetooth and when it expands wirte down the specifications.
for example
>bluetooth (it will look similar to thi
click on >
it expands and might show
HP bluetooth intergrated module
note tis in ur notepad
then with graphics sound and all the specs note it down.
now go to www.filehippo.com and download mu torrent software then go to www.torrentz.eu and type windows xp sp3 with sata drivers then download it and burn it. after that go to goole and get all ur drivers and then install it in normal way
mu mail id is mr.hardhik@gmail.com if any quieries write down.
i installed xp in cq 60 408tx i got the drivers too.
Sound drivers,vedio controller
I have compaq notbook of M.No:CQ60 104 TU,pls help to downloding these compaq notbook drivers.
can i install win xp in compaq cq60 104 tu
driver of xp
i am not able to find any audio and network
i am not able to find any audio and network drivers for my laptop(Compaq Pressario CQ 104 TU) can any one help please
how to install xp2 or
how to install xp2 or xp3 for presario cq60 104 tu
Add Your Solution
is LG RD400 have WiFi adapter inbuilt
note book doesn't support WiFi
install realtek failure
Failed to install Realtek Sound Driver
Fix-O-Meter
11,080
11,080 people viewed this problem
- 35 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top PC Laptop Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
