I have Verizon FIOS with the universal remote that came with the FIOS setup. My TV is a DYNEX. Most of the time it (FIOS) works OK. When it IS working, the sequence of events (as seen on the TV) is as follows:"HDMI", "unsupported format", picture comes on. When it is NOT working, the first two events are the same but the picture does not come on. Sometimes, at that point, if I hit the power OFF on the remote, I see the picture for a fraction of a second just before everything shuts down. So far, I have tried turning the power OFF/ON on the power strip that feeds both the FIOS head box and the TV and just about every combination of Button sequences on the remote before, during & after using the power ON button on the remote. Eventually, everything works - that is, if you fiddle long enough anything works. It looks like some sort of timing problem to me.
  • noyes381 Dec 29, 2008
    Thanks for your quick response.
    I have 2 Dynex LCD TVs - a 19" and a 37". They are in different places in the house and are fed by different head boxes. neither have 2 HDMI inputs. They both have the problem. I don't think that the cables from the head boxs are the source. It looks to me as if either the TV or the head box is turning on before some operation is completed. Do you think that changing the TV code on the remote could help? DYNEX codes are not listed on the Verizo web site.
    Dave
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, to my knowledge, the TV will display "not supported signal" when a non HD channel is tuned into. What happens is the Verizon FIOS will try to uo-convert the non HD channel to 1080i. In some instances the up-convert will not be able to perform and therefore nothing would be displayed on the Dynex.
Offhand, pls try:
  • Turn on TV and STB
  • Turn off STB
  • Hit Select on front of STB
  • Hit Menu on front of STB
Note: if you have the DVR, this won't work while it's actively recording something. BTW, I don't yet have the IMG - I have the old IPG, so getting to this menu is different for me - I'm basing the directions, above, off of postings others have put out there. Once in that menu, you'll be able to change settings. Look for one called SD Override. This is essentially how your box will send out your SD channels. Try setting it to 480i and see if that works.
Good luck and Thank you for using FixYa.
Posted on Dec 28, 2008
  • 19,396 Answers
Try switching the HDMI cable to a different HDMI channel input at the back of TV, you will also need to change input with the remote, depending on the TV model.
If you have a different HDMI cable, test also a replacement cable, or buy a better cable, often this kind of problem is cable related.
I have try several times to connect my Welby big button remote control to my Panasonic TV.I have the codes of the TV but I can't get it to work.can someone guide me thru.I will appreciate it.
[PDF]Big Button Universal Remote Control User's Manual
www.magnifyingaids.com/pdfs/Big-Button-Manual.pdf
Big Button functions just like your original remote ... On the remote control, press and hold the MODE button (TV, VCR, CBL/SAT or. DVD) until the .... Q. Why won 't my Big Button work? A. Make .... PANASONIC 008, 051, 057, 076,. 149, 247 ...
[PDF]Big Button Remote Control Set-up Codes - ValuNet
myvalunet.com/.../Remote-Control-Big-Button-Remote-Set-up-Codes.pd...
Innovative System's Big Button Remote Control ... TV. Quick. Number. Manufacturer/. Brand. 0. SANYO. 1. SONY. 2. SANSUNG. 3. LG. 4 ... PANASONIC. 6.
Remote Control Setup, Codes and User Guides - FiOS TV ...
https://www.verizon.com/.../tv/.../remote+contr...
Verizon CommunicationsThis page provides links to setup instructions, remote control codes, user guides, ... No code for my device ... Want to buy the Verizon P283 Big Button remote?
Amazon.com: Gmatrix Big Button Universal Remote Control ..
Dec 14, 2015 | Panasonic Televison & Video
1988 KAWASHO TV: Need remote control codes for VERIZON FIOS Remote Control
You may want to try a different universal remote, like the Logitech Harmony.
Apr 07, 2008 | Onkyo TX-SR605 Receiver
Cant use fios remote to power/volume
Yesterday I called Dynex at 1-800-305-2204. The rep gave me 0463 which didn't work when I called VERIZON FIOS but the Dynex rep did inform me during the call that if it didnt that Dynex is comparible with Orian, Emerson, Memorex, Sansui, Sylvania and Zenith. So any of these tv codes should work. The code of Orian which is 0490 indeed worked!!!! And when you call Verizon make sure when they help you program your remote that they do the second step if they dont tell you which is add the code 799 which will let you just push STB then Power to cut on/off the tv. My bedroom tv, I always pretty much had to use the tv remote to cut on and off but when the Verizon rep gave me that step for the original tv I was having problems with told me this step, I had her walk me through the other tv remote and add that code and its great. She said that alot of technicians just been taught the other way. Hope this info help you.
May 23, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
NEED REMOTE CODE
Go on the Verizon website and request a new remote, the Verizon P265 Remote model. It will have all the newest firmware and it should have the code. I know this because I had a TCL 32" TV and the code wasn't on my old Philips RC 1445302 model. TV and new remote are "talking" just fine now. Verizon won't even want the old one back.
Dec 05, 2008 | Universal Remote Control Remote Control
Universal TV remote control
Target sells a GE Universal Remote Control, 5 Device with learning feature. I can't say if it works with your Verizon DVR, but its code for the Akai LCT3285TA is 1139. If you have the Verizon's remote, you should be able to use the learning function to make the GE control it - that's if the GE doesn't have a built in code that will work for this DVR.
Apr 26, 2008 | Akai LCT3285TA 32 in. LCD Television
FIOS remote with Olevia 532B12
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Jan 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
