HP PSC 1315 All-In-One InkJet Printer Logo
Posted on Dec 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer cartiage error
I installed a new cartiage and align paper came out accidentally hit off key instead of the scan button and now it just says cartiage error
Ben Johnson
Level 3:
  • HP Master 686 Answers
  • Posted on Dec 29, 2008
Ben Johnson
HP Master
Level 3:
Answers
686
Questions
0
Helped
256906
Points
1918
This page may help.  One of the things it's supposed to help with is 'cartridge error'.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00094661&dlc=en&product=374581
If that doesn't help, can you provide more detail about the cartridge error message?
2answers
What is HP E709n general printer error -0x61011be9?
Remove the ink cartiage and also the print head and reset the printer and then have the ink cartiage and the pinhead being reinserted again. Or the pinhead needs to be replaced and the ink cartiage also needs to be replaced and look for any paper being stuck inside of your printer too and remove any paper jams.
2answers
Keeps wanting to print alignment page
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Error after pulling out paper drawer during printing
The error button is probably flashing because there is paper in the printer that did not feed through. or just power off the printer and power back on and see if that helps
3helpful
Ckeck printer ##343
its a printer reset error press
*AF-Key = Additional Functions key = the black button with the star in a head above it.
1) Enter SERVICE MODE. (Press AF-Key, followed by "scan", "copy", "scan" -Keys)
2) Select TEST MODE (press right arrow button 13 times).
3) Hit -OK-
4) Select [8] PRINTER TEST
5) Hit -OK-
6) It'll now say "- 8-2 +" press the right arrow key once to get "- 8-3 +"
7) Hit -OK-
8) Select 0. [INK COUNT].
9) Hit -OK-
10) It should return to showing the "8: Printer Test - 8-3 +"
11) Press the [Stop/Reset]key - (black key with triangle and circle on it) - (returning to the state of 4), and then press the [ON/OFF] key.
Cleaning the print head:
At any time, DO NOT wipe the actual print head with your fingers. Use ONLY water.
-Remove print head assembly from printer.
-Remove ink tanks.
-Use running warm water, wash away the exess ink that is dried around the print head.
-Take one disposable mug, fill with hot water, drop the print head assembly in there, and let it soak for an hour, or so.
(-IF you have massaging shower head, with spray jet -function, use this to deep clean the actual print head.)
-Dry it up carefully, do not wipe actual print head, just tap gently with soft paper.
-Install ink tanks, install assembly to printer, let it settle for some time (5-30 minutes)
-Run Nozzle check, cleaning, print head alignment
hope this helps if you have further problem do let me know
pls appreciate by rating this solution
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Alignment problem
I want to start my office working with the HP F380 DeskJet....
Paper jam error message
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
58helpful
8answers
Sanning problems for multi function printer PIXMA MP 160
Just hold the stop and reset button until the warning goes away. Works like a charm
k24674
Grand Canyon Tech
Grand Canyon Tech
