Question about Pioneer AVH-P6500DVD Car DVD Player
Eject my player won't eject the disc that is in it. i took the front off and there are two plastic guards that have engaged by metal prongs from within the unit. i need to know how to fix this
I have the same unit with the same problem, but i have a fix!! I contacted pioneer and they have service centers all over, i sent mine today to sybesma's electronics in MI thats close to me you can try there or call pioneer (1-800-421-1404) to get your own place. Good luck!
Posted on Sep 25, 2007
Where is the DVD emergency eject hole for DVD724?
If there is an eject hole, you should be able to see it on the front of the drive.
Dec 08, 2017 | Philips DVD724 DVD Player
Blu ray player won't play or eject disc
If you want to eject the CD you need to look on the front of the Blu-Ray drive for a small hole, about the size of a pencil-lead. If you open a paper clip and insert it, it should pop the drive open for you.
Mar 06, 2013 | Televison & Video
Samsung blu-ray won't load or eject
Someone is going to have to open it and look to see if the disc inside is out of position or jammed in some way----sometimes you can gently move it a little back into the position where it will eject the disc--which could be your entire issue.
May 28, 2012 | Televison & Video
Disc won't eject
Dirty or damaged disk. remove screws in back of player (carefully) and gently slide disc out, do not force. Or take player back to store and ask them to fix or replace it.
Joe Don
May 25, 2012 | Toshiba XDE500 Player
Cannot eject a dvd from a dvd player
usually if you look in the front you should find a small hole turn on the Player and push a Paperclip into the hole this is a manual eject for the tray. If there is NO hole then Unplug the Player and remove the outer metal cover Do NOT stick anything into the Inside of the Player taking a flathead screwdriver You can coax the slide tray to eject the disc If it is an internal feed and eject system across the top there should be a crossbar with a spindle in it facing downward onto your disc remover this crossbar and you can safely coax the disc out of the front without damaging your disc. your issue is when the disc was inerted it was misaglinged in the player so the system misinterpreted it as being a No Disc and locked out the ejection of the disc in the players brain there is NO disc in the player at all after you removed your disc reassemble the player and either return it or toss it out for recycling and get another one
May 04, 2012 | JVC Televison & Video
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
Kenwood KDC-C717 - E-99 error
Reset the unit ithe reset button is on the cd changer
Dec 01, 2008 | Kenwood KDC-MP205 CD Player
Jensen 9410 will not load or eject
i had my jensen three weeks everything was okay until all of sudden the unit wounld not load or eject CD's or DVD's
Mar 20, 2008 | Jensen VM9410 Car DVD Player
I receive error msg and cant eject magazine
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Nov 28, 2006 | Panasonic CX-DP801 8-Disc CD Changer
Pioneer AVH-P6500DVD Car DVD Player Logo
79 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
