Question about Philips 37PF9731D 37 in. HD-Ready LCD Television
Philips lcd tv swithes itself of 37pf9731d/10
Hi
my 37pf9731d/10 lcd tv power light goes out after about 5 seconds from when the power at the socket is turned on im guessing its the power transformer or something like that ,if you think this is the case could you tell me the part number to rplace please
    Welcome Back:
    Visited the website for 2 consecutive days.
I fixed this by replacing the off/on switch which seems to bypass the stand by transformer which i think was causing the problem hoppe this helps someone
Posted on Dec 29, 2008
Philips service codes for red blinking power light
That mesns,your set reports a problem,onlt a technical person can fix this..horst in aussyland..
Aug 19, 2014 | Philips 37PF9731D 37 in. HD-Ready LCD...
I have no screen or sound the power light stays on for 5 seconds then goes out again
Get the TV model number and chassis version from the back panel and try
http://www.coppelltvrepair.com/Diagnose/
I wish I could be more helpful, but without those two pieces there's really nothing more I could do.
Mar 26, 2013 | Sanyo 42 in. LCD TV
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
Gray picture
Look for loose contacts in power outlet, RC Jacks, sockets, cables. Change input device to some other like a DVD that you are sure works. Swith off TV, switch off power, remove plug and retry after 48 hours.
If problem persists, call in a qualified service technician.
Aug 11, 2012 | Philips 40PFL3705D 40 in LCD TV
I am currently working on a Sharp Lc37sb24u. I was originally thinking it had a bad inverter board but now I am not so sure. When I turn the tv on the picture comes up with audio for about 2 seconds the...
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 27, 2011 | Sharp LC37SB24U 37 in. LCD TV
I have a philips 37" flat screen TV, when I switch
hi,
There is problem with the back light of your tv. In LCD tvs CCFL are used as back light to give light to independant pixels. CCLF lamps required high voltage to light. This high voltage is provided by the inverter board inside ths tv. If any one of the chopper transformer (high voltage transformer) have some problem then the inverter will shuts off itself preventing damges to the power supply.
You have to check the 24V from the power supply. If its ok the you have to check the inverter board.if avilabe replace the same. if you are not able to do the same i will prefer to consult some one experienced in it. Back light inverter board will look like one in the picture.
ok
Aug 03, 2011 | Philips 37PF5321 37 in. HD-Ready LCD...
37PF9731D/10 - when turned on the tv power light remains green but no picture or sound. Just a clicking sound - like it does normally when swiching on from being on standbay. It reapts the attempt to turn...
The clicking sound is from the main power supply relay being turning on and off, it is driven by hte main board and it gets the power from the standby power supply board.
You need to check the main powwer supply board and the standby power supply board voltages.
Check the resistor in the main power supply board also
Please see my pictures here: http://s807.photobucket.com/albums/yy352/budm/Philips/Philips%2037PF9631D_37/
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 16, 2011 | Philips 37PF9731D 37 in. HD-Ready LCD...
Hi I have a Panasonic LCD 32" and the following happens 1. I turn on TV and after 10-20 min it goes black screen and few second later it turns off 2. Red light blinks at one second intervals 3. I...
It may have unstable power supply due to bad DC filter caps, very common problem in ALL LCD TV's and monitors. You will need to do in-dpeth troubleshooting the problem.
May 05, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Hi there. i have the closest model, to LE-32B450C. Samsung LE-32C450. i guess..its europe model (im from greece). I bought the 32' TV a couple weeks back.. and now im messing with a shut down problem....
I have a few friends in the UK with the very same TV and no problem at all.
I would suspect either a power supply fault or a bad connection somewhere and I would return it for a replacement.
Mar 01, 2011 | Samsung LE-32B450C 32" LCD TV
Philips 37PF9731D 37 in. HD-Ready LCD Television Logo
315 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
