Error code 2329
Trying to download itunes keeps saying error 2329
  • nigsus Jan 23, 2009
    have same 2329 error code problem
  • little mini Feb 10, 2009
    error 2329 comes up after download complete and into halfway installing itunes+quicktime player
    President:
  • 80 Answers
It's a error message with Windows installer not for Itune.
Try to get latest windows installer from link below
http://www.microsoft.com/downloads/details.aspx?FamilyID=889482FC-5F56-4A38-B838-DE776FD4138C&displaylang=en
Supported Operating Systems: Windows 2000 Service Pack 3; Windows 2000 Service Pack 4; Windows Server 2003; Windows XP; Windows XP Service Pack 1; Windows XP Service Pack 2
Posted on Dec 28, 2008
Disable your antispyware when installing
Posted on Sep 12, 2010
  • Harshab2468 Apr 08, 2011
    Extract the files into a folder, you will get all the .msi files by right clicking and click extract files..., then right click at iTunes.msi and then extract that in the same folder, then open the iTunes.msi, it should install. It is a problem with the windows installer, they are extracted by windows installer to the Temp folder and it just confuses itself.
    To extract, you must have 7-zip
Posted on Apr 10, 2011
How to modify windows vista to be able to install itunes. I keep getting errors saying my system has not been modified to complete installation
You didn't mention the Make, Model of computer or what OS you have? 32 or 64bit version? You can find new and old versions 32 and 64 bit here: http://www.filehippo.com/download_itunes_32/, The 64 bit version is under RELATED DOWNLOADS.
Dec 09, 2012 | Computers & Internet
When trying to download itunes keep getting a report that says ''windows installer encountered errors and can not configure itunes.'' I am using a 64 bit PC with Windows Vista Home Premium. Thanks.
It means that the installer you downloaded is not compatible with the version of Windows you're trying to install it to. Make sure to visit iTunes.com and select the right installer for it to work.
Feb 19, 2011 | Apple iTunes
Ive tried downloading itunes but it keeps on saying some error has occured and when it does download it says itunes has encountered an error so they need to close
iTunes.exe has been set to run in compatibility mode for an older version of Windows. For best result, turn off compatibility mode of iTunes before you open it.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4; Its better you clean/repair Windows registry with RegInOut.
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
5. Start iTunes. The offending message should be gone!
Dec 22, 2010 | Apple iTunes
My computer keeps coming up error 2328 when i go to down load itune how would i get rid of it thank you :)))
If the error code appears during the installation, then your PC's memory might not be large enough. You said a package in the question. Is that a package you specifically bought from a store? If so, contact the location you bought it from. If it's a download or upgrade, then try going onto Google, typing in iTunes 9 Download, and see if that works.
The actual error code 2328 means there was an error getting file version info for file.
Hope I helped!
Jun 09, 2010 | Apple iTunes
When trying to download itunes keep getting a report that says ''windows installer encountered errors and can not configure itunes.'' I already downloaded regcure but that did not clear up the problem . I...
This solution worked for another person trying to do the same thing.
I hope it helps you.
Go to add or remove programs in the control panel, on Windows 7, just go to start, control panel, and then uninstall a program. Find Apple Software Update on the list, and click on repair. Once that is done, try to download iTunes again and it should work.
Pulled from http://en.kioskea.net/forum/affich-49217-error-msg-with-installing-itunes
Dec 13, 2009 | Apple iTunes
Keep getting error code 11222 when trying to access itunes store- have uninstalled and reinstalled but still comes up with error code and says not authorised
I have a couple suggestions for you.
First and foremost - make sure itunes can reach the internet. You need to double check that your firewall is not blocking it - if you can check the exceptions in your firewall make sure itunes is one of the unblocked programs. Otherwise, disable your firewall and then try itunes. (PUT IT BACK ON AGAIN AFTER)
Second - there could be a registry issue - Running ccleaner might solve this error - http://www.ccleaner.com/ see if that helps.
Dec 06, 2009 | Apple iTunes
Itunes Downloading Errors
What you can try is to create a new user and install itunes in it then give a try using Itunes...
if this step works fine, then its issue with windows user profile
Give a try and let me know if you still need any help on this
Jan 29, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod not recognized by computer or itunes
For it to recongnize, maybe try:
1: go to control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your ipod is now recognised by the computer
---John
Give credit to Randomassist
Nov 27, 2008 | Apple iPod nano
Computers & Internet Logo
4,284 people viewed this question
Alun Cox
David Payne
David Payne
