Question about Dell 3000cn Laser Printer
Paper Jam 075-134 (states Open Reg cover and Check MPF)
Have not been able to find any trace of paper to cause jam and have even clean off sensors with a soft brush but problem persists
  • 2 more comments
  • jvanness Dec 29, 2008
    Same thing here. There is no jammed paper to be seen.
  • beckaangel Jan 22, 2009
    Same things:(
  • JLouisIII Feb 18, 2009
    Same problem. Dell techs advise that two major parts need to be replaced. Parts list at over $350. Tech dispatch estimated at over $150/hr. Dell will not guarantee that replacing parts will fix problem. I cleared memory and reset (MENU-CONFIGURE-MAINTENANCE-Init NVRAM) and the printer did print on the next try. It reverted back to the problem state after that and I have not had any success clearing memory again.
  • tjnorton Feb 20, 2009
    Same problem! There were marks on the edge of my paper, so what do I do now if it is not picking the paper up?
The problem might be that it isn't picking up the paper. This will register as a jam if the paper does not reach the next paper sensor within a certain amount of time. check the feed assembly and check the paper to see if there are any marks on the edge from the pickup roller.
Posted on Feb 02, 2009
My laserjet pro 400 color mpf m475dn printer is indicating " paper jam...open back door to clear jam," please describe how i will go about this process.
There is an access door in the back of the printer. Open the door and you should see jammed paper. If not then you have a faulty sensor or switch.
Mar 20, 2014 | HP LASERJET PRO 400 COLOR MFP M475DN
The scanner won't work because it is detecting a paper jam which is not there
There was this one time that my friends printer states that there's a paper jam even though there's no paper there.
What was actually there, is just a paper with length of roughly half a centimeter and width of roughly 3mm is in the printer, stuck on something which I assumed is one of the sensors. Removed that, and no more paper jam.
Apr 19, 2010 | Panasonic KV-S2046C Pass-Through Scanner
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
MY PRINTER SAYS PAPER JAM BUT HERE IS NO PAPER IN IT ???
Look for any traces of tiny paper shreds that might got stuck between the rollers. That might be causing the paper jam error. If you could open the back cover, check from there also as those paper shreds might also blocking the sensor.
Sep 18, 2009 | Canon L120 Fax Laser Printer
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
The printer says that it is has a jam and I removed the jam
HI,
you can open the lid cover of your printer and check inside if there are paper even how small it is it will cause the paper jam problem jsut double check.
any further question let me know.
Mar 29, 2009 | Office Equipment & Supplies
Dell 3000CN Laser Priner
Removed the fuser unit and also removed the left hand side panel to access the gearing mechanism.
Manually rotated the gearing a number of times thru 360 degress. This appears to have cleared whatever was causing the printer to detect a paper jam although there was no obvious sign of bits of paper or even dust build up.
Dec 28, 2008 | Dell 3000cn Laser Printer
Printer complains: Insert Paper fully into MPF
Pull the paper tray out and look for any obstructions in there.  Check for broken parts as well such a sensor.  Sometimes they get out of position as well.
Sep 17, 2008 | Dell 3100cn Laser Printer
Paper Jam Errors
switch off power to printer and switch on again, worked for me
Jan 14, 2008 | Dell 3100cn Laser Printer
Dell 3000cn Laser Printer Logo
1,175 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
