Question about Creative Labs Zen V MP3 Player
My zen has frozen and it is still on.
My zen is on, but it has frozen and won't play, it won't turn off and can't be detected by my computer. while i was charging my zen it froze and its still on
  • Anonymous Dec 28, 2008
    The screen is stuck on CREATIVE.
  • Anonymous Jan 03, 2009
    I turn my Zen V on and it just stays frozen on the Zen V screen nothing else I reset it but that just turns it off I turn it back on and same thing happens.
    Novelist:
  • 146 Answers
Try resetting it with the reset button on the side of the player. You need to use a pin to push it. If it resets successfully use the players utility to reset and check it.
Cheers
Posted on Jan 01, 2009
Creative zen became frozen
Let the battery completely drain, and after a while charge it using the charger available else thru computer without turning it on.. let it charge for 50% and then try switching it on. Try this if not get back to me.
Jan 21, 2010 | Creative Technology Zen MX Black (8 GB)...
Zen V is frozen. Reset just brings back the frozen mode (Album...now playing)
Since the reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Feb 20, 2009 | Creative Labs ZEN V Plus MP3 Player
My zen is frozen on creative
If a reset does not work then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
My Zen mp3 player is stuck or frozen on "Shutting off" mode.
when off hold play down. then turn on(while holding play). then theres a recovery menu go to clean up.
Dec 28, 2008 | Creative Labs Zen Micro MP3 Player
ok look down on your zen u will see a play where u plau it in then nezt to it its a veru very little thing get a pin put it in there then it will not froze
Dec 14, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen is frozen!
I just read a solution posted by someone else for the same problem, they said to stick a toothpick into the pinhole reset button at the bottom of the Zen so i did this then turned it back on but i got the same problem, so i reset it again and then pluged it into recharge and this seems to have worked...hope this helps!
Oct 12, 2008 | Creative Labs Zen Digital Media Player
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Frozen
Try to download the "fixer" from Creatives homepage.
Apr 27, 2008 | Creative Labs Zen Stone Plus MP3 Player
Zen Neeon frozen completely
Leave it alone for a while, then try reinstalling the Zen Program, then plug it in, then rest it, then try to switch it on. It worked for me
Jul 27, 2007 | Creative Labs Zen Neeon MP3 Player
Creative Labs Zen V MP3 Player Logo
88 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
