Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher & Paykel single drawer dishwasher F1 flashing.
Hi my Fisher & Paykel single drawer dishwasher appears to have turned itself on and is flashing F1. turned off the unit at the power point, is only way to stop it. Cant locate the manual. What does F1 mean? is it possible for me to fix it or will I require a service call? thank you
  • ezimm309 Dec 29, 2008
    f1 flashing on both drawers, turned off power at circuit breaker but this does not solve the problem
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Posted on Dec 29, 2008
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Flashes f1 with a wrench and motor is spinning fisher&paykel double dishwasrer
This video explains how to repair your double or single drawer dishwasher.
http://www.appliancerepairlesson.com
Aug 29, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Machine powers on by itself both drawers.. with the error message
F1 can mean two things - depending on which drawer it is coming in.
It is a sign that the water is leaking from the drawers into the base of the housing and tripping the flood switch.
To fix this you will have to take the drawers out and dry out the flood switch at the base of the housing. Use towels and hair dryer. Most like the dishwasher detergent is foaming or the door seal is leaking or the outlet drain is cracked. Make sure the mains power is turned off when you are working on the dishwasher.
The other reason is if the thermal cutout is blown in the lower drawer that can cause the F1 to appear in top drawer. But if both drawers are flashing F1 then this is unlikely.
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a nautilus dishwasher by fisher and pykel can't find any user guides Flashing F1 and has drained ...do these dishwashers have a reset button?
This video explains how to repair a double and single drawer fisher and paykel dishwasher.
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 in F&P 2 drawer dishwasher
You will need to be a bit more specific when you say "no flood".
Are you having this F1 fault in one or both drawers?
What did the engineer do when he was there last time?
Does the F1 code flash with beeps?
What happens when you turn the mains power off and on after a short delay?
Please provide the actual model number of your fisher and paykel 2 drawer dishwasher.
May 19, 2010 | Fisher and Paykel Dishwashers
F1 appears both drawers are flashing and beeping can't turn off power (it turns off for a moment and then turn itself back on with F1 code, beeping and flashing) Unplugged it hoping it would reset, it did...
F1 means that the flood sensor has been tripped. Remove the bottom draw and dry the water out. Mop the majority out and use a hair dryer to get it all nice and dry. This should clear the f1. There may be underlying issues of why the unit has leaked but see how you get on.
Dec 12, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 01, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer not working
sometimes if the heater is faulty only one drawer will work and the other drawer will flash f1
Nov 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
863 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
