Question about Cameras
Praktica dcz 7.5 lens error code 1302
When switching on the camera the screen switches on momentarilry and says there is a lens error 1302. The motoer behind the lens tries to work but fials to open the shutter. Any suggestions?
mcomijohns
  • 477 Answers
SOURCE: Casio Exilim EX-Z70 lens error
yes I can help you lens zoom motor is out or the gears are stripped. goto www.digitalcamrepair.com for more help.
Posted on Jun 12, 2008
SOURCE: L2 Lens Error
This didn't work for me!
Posted on Aug 23, 2008
SOURCE: praktica DCZ 3.2 D transfer pics to card
just phoned the praktica company and you cant download from camera to memory card you need a usb lead which they supply at £10.00 cheque or postal order
Posted on Jan 15, 2009
SOURCE: lens error
if the problem is due to the fact that u have dropped the camera on floor or put into water...then no other go you should change the whole lens array...contact your nearest service centre
Posted on May 13, 2009
SOURCE: No shutter release
It turns out that supporting the camera while taking a shot can impart a slight twist on the seated lens. This twist is just enough to cause the camera to think that there is no lens installed .. hence the error message. Solution (provided my Henry's Camera experts) was to reseat the lens by reversing the twist. It has since happenned twice and each time recovery was effective .... Keith
Posted on May 26, 2009
Camera wont switch on praktica dcz 8 lm busy light comes on 3 seconds then off and nothing after that
took the memory card out and then turn on the camera. Now see the busy keep coming or its gone. If not showing busy any more then format the memory card and then try to turn on the camera with inserting the memory card. Thanks.
May 23, 2012 | Praktica SlimPix Digital Camera
Praktica DCZ8LM switches off nearly immediatley. After switching on the red "busy" light comes on for about 3 secs then the goes off. No other indication theat the camera is working. It is not...
If you can, after switching on, quickly press to go into settings, and find the timer switch off spot, and adjust it to make it turn off to never, if possible, and see if that helps. If it does, go back and adjust again to a lesser time like two minutes, or your camera will eat batteries.
Dec 16, 2017 | Praktica DCZ Digital Camera
I CANNOT FIND THE INSTRUCTION MANUAL FOR THE PRAKTICA DCZ 8LM CAMERA
Hello
OK, at the l;ink below you will be able to download the manual in PDF format free of charge.
Click HERE to navigate to download page.
Fell free to contact me if you need any further assistance.
Kind regards
Andrea
Sep 25, 2010 | Praktica DCZ Digital Camera
Lens error 15 and 25
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 14, 2010 | Praktica DCZ 5.4 Digital Camera
Praktica dcz instruction manual
0e94afd.jpg May be this will help a little bit. Manual can not be found.
Jan 29, 2010 | Praktica DCZ Digital Camera
Hi My PRAKTICA DCZ 520 camera is saying CARD LOCKED when i switch it on, i cannot take photos, can anyone help me to unlock it please. Isabella
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Jul 16, 2009 | Praktica DCZ5.0 Digital Camera
Card locked! problem
If your camera uses and SD card. Take a look at the card. There will be a little switch on the side of the card. Move the switch to the unlocked postion, reinsert it in the camera and turn the camera on. It should fix your problem. Thanks for coming to FixYa.
Rob
Mar 17, 2009 | Praktica DCZ1.3S Digital Camera
Praktica dcz unable to delete photos and take picture
You probably have a memory card in your camera.
Remove it and check for a nearly microscopic slide switch on one edge.
This is a 'protect tab' and will not allow you access to memory unless it is properly set.
May 20, 2008 | Praktica DCZ3.2S Digital Camera
Cameras Logo
214 people viewed this question
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
