Question about Espresso RMI La Cimbali Espresso Machine
Cimbali M 29
I have a problem with the cimbali M29. When I' trying to fil water to the boiler,doesn't stop so it is overfilled..what to to?
    Master:
  • Espresso RMI Master
  • 791 Answers
Overfilling boiler (won't steam and and water comes out of the over pressure and or vacuum valve)
*** BEFORE checking inside of machine. Check for table/machine is level!. Carefully fill a glass tumbler with water. Place on top of machine (cup rack is a good place or drain tray.) pour more water till near rim. water should be even all around the edge of cup! Not even? Turn/twist feet as needed to raise/lower machine to level. (cup sleeves work but needs replacement every week.) Level? okay recheck machine. Otherwise continue on:
1. water fill valve stuck and or leaking. Replace.
2. Manual fill valve stuck or leaking. Replace (OR disconnect and seal. Not used anymore when gas heaters were used at one time.)
3. water level probe. Clean or replace (it's just a shiny nail. Clean it.)
4. Water level float (like a toilet tank float but smaller) Check if full of water. replace.
5. water level probe wire disconnected (put back on probe tip)
6. Rare cases; bad PC board (Expensive)
Note; Most common problem is an unstable (not level) table. I've seen sagging tables, shelves, press board soaking in water. Icecream covers with planks, Card tables, Books, and rodents make homes under a nice warm espresso machine table.
youtube;ukeboy57
Posted on Nov 06, 2017
    Problem Solver:
  • 6 Answers
First check to see if it is electrical or Mechanical. Turn off machine see if it still overfills, if so you have a Mech problem. If not touch a screwdriver from the probe to the boiler and see if you can turn it off.
Posted on Mar 27, 2012
One thing to check... Have you switched to 100% reverse-osmosis or distilled water recently? I read that the water level probe needs conductive ions (e.g. calcium) in the water for it to detect that water has risen to the probe's level. So, water with too few ions will not register on the gauge, and the tank will continue to fill.
Posted on Sep 07, 2007
Brown water coming from la cimbali m29
Sounds like boiler is contaminated with milk.
Aug 26, 2013 | Espresso RMI Coffee Makers & Espresso...
Hi all. In desperate need of help. I have a La Cimbali M29 Select. I am unable to get hot water from the hot water tap and when the machine dispenses a shot of coffee, I have to turn the machine of...
From your description it sound that the button strip need to be replaced. All the buttons of the coffees and also for hot water are all set in one unit the button strip. This like a membrane and is located under the buttons. This is frequent problem with m29 select since the connector of the button strip it is exposed under the cup warmer area and is very easy to absorb the humidity from steam escape inside the machine and when one short circuit it happens then since the whole strip is one unit it will mull faction as you described.
Jun 14, 2011 | Espresso RMI La Cimbali Espresso Machine
La Cimbali Espresso Machine: How do you calibrate the dosing for a Cimbali M29 ...
Press and hold any Group stop button until beeping, then all the button will copy what you press. Hit any stop button to leave program.
May 18, 2010 | Espresso RMI La Cimbali Espresso Machine
How do you calibrate the dosing of the La Cimbali M29 Select?
should be the same method unless the stop button needs replacement. The stop button is one of the most often used (abused) buttons and frequently needs replacement.
ukeboy57
Mar 26, 2010 | Espresso RMI La Cimbali Espresso Machine
Problem with Cimbali M29 steaming wands
Check the water level, if you remove the top panel you will notice that the steam valve are connected at different heights on the boiler. If the machine has the silver probe remove it and clean.
Aug 04, 2009 | Coffee Makers & Espresso Machines
La cimbali m28 selectron manual could anyone tell me where to buy or down load one
This is for you....I hope this M29 will do what you need...I called he Cimbali 1-800 number and this is all they had...I tried...been working on this one for about an hour...found one in Russian....Italian...Spanish....but when I translated them and tried to paste them they came in both languages and intermingled somehow....wierd....but here you go ....I hope this helps...good luck and thanks for rating my effort....The Fang
P.S. any probs...call 1-800-724-6225 and speak to Trish. Thats 1-800-Cimbali. Take Care
May 19, 2009 | Espresso RMI La Cimbali Espresso Machine
Cimbali M29 Select
Remove the 3 screws on the side of the bell they might be bolts or allen wrench screws. That will give you easier access to the screen and screw(make sure you have extra screen and screws).
Aug 18, 2008 | Espresso RMI La Cimbali Espresso Machine
Used parts for la cambali M29 select
Sounds like the relay for the pump is gone. Replace relay.
Oct 28, 2007 | Espresso RMI La Cimbali Espresso Machine
Espresso RMI La Cimbali Espresso Machine Logo
400 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Mohamed Ismail
Mohamed Ismail
John
Mark Cheong
Mark Cheong
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
