There is problem in uninstalling the autocad from my pc so what can i do ?
    Genius:
  • 2,120 Answers
Reinstall then remove in control panel
Posted on Dec 28, 2008
Find problem in Autocad 2014 while opening a file Fatal error: unhandled delayload "modlr19.dll"Module not found exception at 75bad36fh
Try uninstalling and then run CCleaner to remove any tombstones left over in the registry. Once clean try a fresh install once again.
Nov 25, 2014 | AutoCAD LT 2014 for PC
My autocad 2011 is not opening . it says the application was unable to start correctly (oxc0150002) click ok to close the application . i use google chrome and desktop . Win 7 ultimate installed .
Try this first:
Uninstall and Reinstall the Visual C++ 2005 and 2008 redistributables. Restart the computer and try it again.
If that doesn't work:
Try using the repair option on the install software.
Uninstall autocad completely, restart the comp, reinstall autocad.
Also what version of 2011 do you have? Student Edition or just the regular one?
May 04, 2011 | Computers & Internet
I am not able to uninstalled autocad 2006 through Add/remove programs. "Fatal Error while trying to uninstall Autocad 2006.
Reinstall & unistall the programme
or
Use the System restore Utility to restore it to the point before you install the programme.
Hope it helps.
Feb 03, 2011 | Autodesk AutoCAD 2006
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
See More
Issue:
Causes:
Solution:
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Sep 15, 2010 | Autodesk AutoCAD 2010
AutoCAD 2004 / Windows 7 compatibility?
If it works in Vista you shouldn't have any problems. Easiest way to find out is to install it!
You can always just uninstall the program fi you run into problems.
Dec 05, 2009 | Autodesk AutoCAD 2004 for PC
When i switch from a layout to another, my program (Autocad 2005), give's me error and it's shout down.
probably is a registry problem. Try to clean the registry or uninstall and proceed with a clean installation of the product
Jul 18, 2008 | Autodesk Autocad 2004 for PC
Autocad
if u have it on cd uninstall it , restart ur computer and reinstall it again
Nov 16, 2007 | HP Compaq nc6000 Notebook
16 people viewed this question
jasbo
jasbo
