Question about HP Office Equipment & Supplies
I cant setup my printer to my new computer.
I am trying to connect my hpdeskjet 5552 to my new computer. (Dell XPS1)After inserting the setup disk an error message appears - "cant find SETUPX.DLL" After completing the setup the computer wont recognise or accept the printer.How do I go from there
(Maybe because computer is using windows vista - and setup disk is for windows XP??)
  • acl4254544 Dec 29, 2008
    All fixed now thanks
    Genius:
  • 2,120 Answers
Go to www.hp.com and let the website auto-detect your printer and download the correct drivers.
Posted on Dec 28, 2008
My hpdeskjet f4140 wont print a microsoft works document
Hi Josh,
Try disconnecting the usb connections to the PC.
Uninstall the printers software and reboot your computer.
Turn off the printer and then on again.
Insert the installations disk into your computer.Follow the installation instructions and connect the printer only when prompted by the installation setup to do so.
Hope this helps.Thanks!
Nov 14, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
MY SCANER IS NOT WORKING
Try running Delete Print Jobs to remove any stuck print jobs in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
Download the proper drivers. If using Windows 7 32-bit use the Vista 32-bit and if using Windows 7 64-bit use the Vista 64-bit drivers. Install the drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Virus programs and firewalls will block communications.
Links to the patch(drivers can be found at...
Dell 926 Photo All-In-One Printer owners thread (W7)
As for scanning, if you have the disk that came with the printer, then insert the Printer disk and stop it from running. Go to My Computer and double click on it. Look for the drive with the Dell disk in it. Right click on it, left click explore. Look for the OCR Folder. In the OCR Folder, there is an Abbyy Folder. right click on setup.exe, that's in the Abbyy Folder and left click run as administrator. This will install the OCR program.
Or
Try Simple OCR
Rick
May 08, 2011 | Dell 926 All-In-One InkJet Printer
I have a Veratec desktop computer and am having all kinds of problems with it. It is one year old. Will not communicate with my dell printer A920 and is difficult to operate otherwise. Please help.
Well what operating system do you have on it? Windows7 doesnt like some printers. check online for print drivers and update them. Follow this link to help you with that... http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_FA36C542525D975EE030030ABD621881&isLegacy=true
you can also try this approach... First, let's make sure your computer has the latest Windows Updates, especially .net framework, needed to run many applications and the latest Java.
Disconnect your printer.
Download and run this patch (***WARNING*** The patch for this printer also removes other Dell applications, like Dell Dock, Dell QuickSet and other Dell applications)(These applications can be downloaded at Drivers & Downloads and can be reinstalled) to completely remove the printer from your computer. Run the patch(A MUST on Vista Machines) until it prompts you to restart your computer.
If using Windows 7 also try...Manual Printer Driver Removal
XP Drivers
Vista 32-bit Drivers
All other drivers
Install the proper drivers. You'll be prompted when to connect your printer(powered on)
***To install drivers, sometimes the file unzips and does nothing. You have to look for the setup.exe file, right click on it, then left click run as administrator***
If using Windows 7, use the Vista drivers in the compatibility mode.
Right click on the setup.exe file, left click properties, left click compatibility. Change the compatibility to Vista(Try Vista SP2). Then install the proper drivers. You'll be prompted when to connect the printer(powered on)
Scanning
Scanning using USB connection, open the Dell All-In-One Center, click on scanning and copying and scan from there.
Scanning wirelessly, use the scan buttons on the printer.
Mar 04, 2011 | Computers & Internet
My dell 470 cant detect any hard disk while installing windows xp what should i do?
If the BIOS cannot detect the hard disk then most likely the hard disk has failed.
Try removing the hard disk and inserting it back into the computer, just in case it was not making proper connection.
If this did not fix the problem, then you need to replace the faulty hard disk.
Dec 19, 2010 | Dell Precision Workstation 670 PC Desktop
I have a Dell 944 all-in-one printer and just got a new Toshiba laptop. The new laptop uses Windows 7, which is not supported by the printer. Is there an update to the drivers & utilities to make...
Did you try the Vista drivers in the compatibility mode. Drivers and instructions can be found at...
http://en.community.dell.com/support-forums/peripherals/f/3528/t/19306932.aspx
Let me know what happens.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 09, 2010 | Dell 944 All-In-One InkJet Printer
My Dell 531S will not boot past the BIOS (Dell logo) screen. At first I thought it was the hard drive, since it wasn't recognizing anything connected to SATA port 1. Since then I have purchased a new...
It seems like you have multiple problems:
1. DVD-ROM drive not accessing the disk
2. unable to "disable" the "floppy" drive in BIOS SETUP
3. not recognizing anything connected to SATA1 port
It's time to take your computer to a qualified technician, for professional trouble-shooting.
Is your DELL computer still under warranty? If so, exercise the warranty.
Or, maybe you should just remove the "new" disk-drive, the RAM, the DVD-drive, and then responsibly "recycle" the old computer, and purchase a brand-new system, repurposing the disk/RAM/DVD components.
Sep 01, 2010 | Dell Inspiron 531s Desktop Computer
Back up disk for HPDESKJET F4140
Go to www.hp.com, their program will automatically detect and download the proper drivers to your computer.
Dec 24, 2008 | HP DeskJet F380 All-In-One Printer
NEED TO DOWN LOAD FREE PRINTER DISK FOR HPDESKJET F-4180
You had a question, I have an answer. Go here and choose your operating system. This is the driver and should also include everything the CD would have. If this does not fix your problem, just let us know.
Apr 06, 2008 | HP Compaq dc5700 Microtower - Free Flat...
Vista update
insert your windows vista disk and during setup youll see system restore it will fix your boot problem once after you run it
Mar 24, 2008 | Computers & Internet
65 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
