Question about Samsung DVD-M105 DVD Player
Setting the player to region free
we are trying to set our samsung p181 dvd player from region 2 to region free
we have tried the procedure explained in your site but after we select our language we cannot go on with the steps we select the language hit repeat button on the remote and enter the 5 digit region code thats stated in your explanation (38767) and after that nothing happens we dont see any code displayed  and when we proceeded from that step as if it has completed safely, we hit 0 for region free and nothing happens
why we cant go on after the language selection and repeat button? why we cant see our players region code displayed on the screen and most importantly why cant we set it region free :D to set it free and not to set it free thats our problem :D kidding aside if you could help us we really would lappreciate it :D
thnx for your time
  • cadvision Jan 10, 2009
    I too have the same problem.
    The instructions provided seem to be fairly generic and either do not comply exactly with this model (DVD-P181) or are incorrect.
    The player front panel comprises of 3 buttons (Power, Eject and Play).
    With the unit switched off (but plugged into live mains), I press (and hold) the Eject & Play buttons simultaneously. The player appears to power up and initialize and moments after, it will display the language menu.
    English is option 1, so I press 1 on the remote. As soon as I do this, the player goes back to the Samsung background.
    Pressing "repeat" on the remote seems to have absolutely no effect after the language number is entered and no screen with region codes appears at any time.
    Has anyone succesfully changed the region code on a P181 before that could provide some further instruction? By the way, the unit was purchased in Australia and is currently st for region 4.
    Looking forward to hearing from someone.
Apologies everyone.......
The instructions for the DVD-P181 are actually correct as described in other posts but can be a bit confusing. Please allow me to clarify using my example;
With your DVD-P181 switched on, follow these instructions using your Remote Control;
1/ Press the <DVD> button
2/ Press <0><0><0><0><0> (this is 0, 5 times)
3/ Press <repeat> (careful not to press the <repeat A-B> button)
4/ Press <7><6><8><8><4> (ONLY if your player is currently region 4 - refer to the table below for other pre-set regions)
5/ The Region window should now appear on screen saying that your current region is Region 4 and asking what region you want to change it to.
6/ Press <0> for the new Region (0 is region-free)
7/ Press <Open/Close> button once (to open the tray)
8/ Press <Open/Close> button again (to close the tray
9/ Press <Power> button to turn the player off
Now, when you turn the player back on, you should be able to play DVD's from any region. Good luck everyone.
_______________________________________________
This table refers to Step 4. You need to choose the Region code which your machine is currently set to, to unlock the Region Menu which allows you to set the device to another region.
In my example, the DVD player was purchased in Australia is by default set to Region 4. The 5 digit number I needed was 76884.
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Posted on Jan 10, 2009
1. Ensure disc tray is empty.
2. Press "Repeat" on the R/C then enter 5,7,5,3,8 or the region key for your region.
3. The numbers "02" appear in the top left of the screen.
4. Quickly press the number "0" button on the R/C, for "multi region".
6. Wait 20 seconds, then power off, then on again.
Thats it, and it does work!
I got the region codes from other threads as follows
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Posted on Mar 23, 2009
Wrong region
Here is a region hack said to make your model DVD multi region
http://www.videohelp.com/dvdhacks/samsung-dvd-p181/9303
Jan 28, 2014 | Samsung DVD-P181 DivX DVD Player
I have a region 2 samsung dvd player. All of a sudden the following message displays: '' Can not play disk. Wrong region code'' We have been playing the dvd for more than 1 year. What is the problem? Same...
What follows is mostly generic advice which applies to the vast majority of DVD players which I've tinkered with.
Your problem normally only happens if someone else has played a different region coded DVD on your machine. Normally you get seven chances to reset the region code before the machine locks itself permanently to one of them. before the changes are permanent the player will usually ask you if you want to change the region code when you try to play a disc from the wrong region.
Before doing anything else it's worth asking other members of your household if they have recently used the player, especially if you know anyone may have been using imported discs. If they've used up all of the region changing opportunities then hacking the machine might not work at all.
If you use a search engine you can search for DVD-P181 hack and these will guide you through the process to make your DVD player a multi-region machine, but there are three different hacks which I've seen for the same player so you may need to try them all.
Jul 03, 2009 | Samsung DVD-P181 DivX DVD Player
How to make a player Samsung DVD p181 multizone
Below is a process for your model of DVD player, not 100% sure to work. It is the only known multi region hack for this model however.
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT (do not confuse this with the A-B button) then the following codes for the required region the player is already set to (region you bought the player in) :
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
("E series M105", M205 and M305 users try: 57538)
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 0 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 (M203).
9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
Good luck hope this works for you. Thank you for trying Fixya! Please leave a positive rating if this solution has helped, or shed some light on the issue.
Mar 23, 2009 | Televison & Video
Won't play Canadian dvds
It is illegal to change the region code. I will not accept liability, but if you enter the phrase, "change dvd region code philips" on the YouTube website, some jokesters have some good videos which will show you how to do it. Two things they do not tell you:
1) It is illegal
2) It will only work 3 times, and then your player will be locked into whatever region code you set it to
You would really need a Multizone DVD player to do what you want to do legally (Philips does not currently make any of these)
-Tha Mp3 Doctor
Jan 09, 2009 | Samsung DVD-P181 DivX DVD Player
Dvd-p181 - Samsung Region-free
Try this hack as it seems to be another one available for this player and it doesn't include the play and stop buttons.
<DVD> ; press DVD button
<0><0><0><0><0> ; enter 5 times 0
<repeat> ; press repeat button (careful, not <repeat A-B>)
<5 digit code> ; see below, depends on region the player is currently set to
<0 for region free, 1-6 for other region> ; select new region
<open> ; open tray
<open> ; close tray
Now power off/on
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Note: reset player by powering down and simultaneously pressing <power> + <play> until display shows 'reset'.
Aug 17, 2008 | Televison & Video
Unlocking procedure for the samsung dvd-p181
Pls try:
This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 13, 2008 | Televison & Video
Unlocking zone for samsung dvd-p181
One of these 2 should work.
<open> ; open tray
<open> ; close tray
Now power off/on
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Aug 04, 2008 | Televison & Video
Brough DVD's from america. Wrong region for Australia. I have a Samsung DVD P181/XSA player. How can I play my dvd's. Is there a way to break the region code on my DVD player?? Thanks Sylvia ...
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 .
OR
<open> ; open tray
<open> ; close tray
Now power off/on
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Jul 30, 2008 | Televison & Video
Samsung DVD-M105 DVD Player Logo
1,244 people viewed this question
Jerry Greenberg
Jerry Greenberg
