Question about Whirlpool Calypso GVW9959K Top Load Washer
Washing machine won't pump out
CAN ANY ONE HELP ME LOCATE THE FILTER ON THIS WASHING MACHINE?
  • gcluckette Dec 28, 2008
    GOOD MORNING: I HAVE A WHIRLPOOL CALYPSO CATALYST CLEANING WASHER, I DO NOT NO IF IT COMMERCIAL OR NOT. I USE IT IN A RESIDENCE...I WASHED SOME BATHROOM THROW RUGS LAST EVENING AND IT DID NOT COMPLETLY DRAIN...HOW DIFFICULT WILL IT BE TO CHECK THE PUMP? DO I REMOVE THE FRONT OR THE REAR OF THE MACHINE TO GET TO THE PUMP?
    Scholar:
  • 86 Answers
Hi If this machine is a commercial w/machine it will not have a filter! The problem will be with the pump mechinism or the rubber drives from the motor to the pump. The rubber drives are a common problem with the whirlpool range but are very easy to replace!
Posted on Dec 28, 2008
  • Kris Seymour Dec 28, 2008
    Hi good morning! Ok well did any of the rugs fall apart? If so you could be looking that some of the rug is now blocking the sump hose underneath? What you will need to do is tip the machine backwards so you can get a clear view of underneath and there will be a hose that leads from the tub to the pump. Take it off ( mind there will be water in it ) and make sure that is nothing inside blocking it up.. Then if nothing inside check the pump and the rubber drives.
Where is the filter located on an unidentified washing machine?
Inlet or drain-filter????
ow To Clean Your Washing Machine Filter - YouTube
? 2:43
https://www.youtube.com/watch?v=Mmvr4Xn2W1w
Jun 17, 2012 - Uploaded by Kenneth Watt
For more washing machine help please see our website at ... Far more helpful than the wretched manual that came with ourwashing machine. :) ... I just did this to my washing machine, the filter was blocked up with wool, ...
[PDF]Owner's Manual
shop.amana.com/assets/pdfs/literature/40068302.PDF
manual stays with washer. Contents. Important ... Keep this manual and your sales receipt together in a safe place for ... Amana Appliances offers long-term.
How to Empty and Clean Out Your Washer's Drain Pump Filter
www.homesavvyatoz.com/washer-drain-pump-filter/
Oct 13, 2011 - Do you have a front load clothes washing machine? Have you every wondered what happens to that spare change you occasionally forget to ...
Amana NFW7300WW Washer Locate drain pump filter
Dec 30, 2015 | Washing Machines
Where is the pump and filter situated in a fisher and paykel 501 washing machine
These machines don't have filters,
All lint is pumped out with the grey water.
Turn off power & water taps before you remove the pump.
To remove pump tilt machine back on a 45 degree angle
against a wall, locate the white plastic pump lock tab push out and turn pump anticlockwise.
Dec 03, 2014 | Fisher and Paykel Washing Machines
Samsung SW60ASP washing machine won't spin or drain
5E is a Drain Error Code.
This can be caused by a clogged filter in the washing machine or a blocked drain line in your house. There can be a few other reasons, but these are the most likely.
If you would like to try to repair it yourself, then follow these instructions:
UNPLUG the washing machine. Repeat, UNPLUG the washing machine!!!
Check the filter in the back of the washing machine on the bottom right-hand corner. Place a shallow dish under the filter. Loosen the filter to drain out the water. Remove the filter and clean it out. Look at where you removed the filter and you will see the water pump impeller. Make sure it can move and isn't locked up. Remove any debris from the impeller.
Replace the filter, and plug in the machine. Try a short wash cycle.
Check for leaks around the filter.
Mar 11, 2013 | Washing Machines
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine won't pump out to go into spin cycle is there a strainer that needs cleaning
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Aug 15, 2011 | Frigidaire Washing Machines
Lg washing machine suddenly stop during washing
It would help to know at what stage the machine stops, however, lete me take a blind guess that it stops just before the spin cycle. If I'm guessing wrong, please tell us when the machine stops and if it displays an error code or any flashing lights (Please note WHICH lights flash and the number of times they flash, as this is an error code that will help pin the problem down).
If I'm right, then........
Jul 05, 2011 | LG Washing Machines
Hi I have a Bosch WSL1662 Maxx washing machine. The spin cycle does not work properly. What could the possible cause be. I have cleaned the outlet of the washing machine and the problem is still...
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months
Jun 23, 2011 | Washing Machines
F05 water will not go Indesit washing machine
F05 - Pressure switch jammed on full - Book a washing machine repair.
Was what the manual said. But then I found this write up from another source:
Drain machine by running the outlet pipe into a bucket at floor level or run the outlet pipe out of the back door if it'll reach. Check the filter unit for blockages. Filter generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together with a set of heavy pliers or vise grips, remove the hose, take out filter and clean. Be prepared for spillage of water. May help if the machine is tilted backwards at an angle.
If problem persists, check pump and pump hose. Pump removal: power off, drag machine out onto the floor, remove back cover or tip machine up at an angle, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace the pump.
Repair and service your own washing machine. Go to www.2ndwave.co.uk/manual.html
Jun 06, 2011 | Washing Machines
Washing machine is not draining and lights keep
It is likely that the pump/filter has blocked thus preventing the water pumping out.
You would need to check and if so unblock it. The location of the pump/filter varies with the brand but sometimes it is behind a flap at the lower front of the machine whilst on others you have to get the back off to locate it.
Jan 23, 2010 | Indesit Washing Machines
WMA46 washing machine not draining, filter blocked but can't locate filter
the filter is underneath on the pipe going to the pump, you wiull need to remove a hose clip.
Jul 11, 2009 | Hotpoint WMA46 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
143 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
