Question about Sony KV-27V22 TV
Kv35s26 Sony Television Trinitron
The picture will not hold..As many have described at this site Flickers off and on continues with sound. Is it fixable without a lot of $$ 1998 Model pic n pic and yes I'd like a plasma, because this sucker is so big it takes three men and a mule to move it but want to wait till fall. HELP? PLEAse
  • 1,694 Answers
Re: kv35s26 Sony Television Trinitron
1) Solder pins of vertical output IC........if that doesn't do it.....
2) probable bad CRT = not worth pursuing..................T.
Please rate this solution.....................
Posted on Nov 15, 2007
0 characters
3 Points
Sony trinitron kv35s26 no high voltage.
Continuous blinking of standby light to Sony TVs indicates a fault with its II2C bus. Your set need an through checkup, which can only be done by any experienced service technician. Anyway, try the site linked here, and see is there any details which could help you. Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, but by brand name at first.
Dec 21, 2012 | Standard (CRT) Televisions
Television takes 10 minutes for picture to come on
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there
Oct 31, 2012 | Sony Standard (CRT) Televisions
My Sony Trinitron standyby/timer light keeps flashing,No picture or sound.Tried to hard reset it but wont work still its a kv35s42
Blinking of standby light to Sony TVs are fault indications. We can get an idea about the faulty circuit board, from the number of blinks occur at one time. Count this number. Make it sure by switch OFF and ON the TV at least three times. Visit this site named 'Electro-help". Blinking codes to Sony TVs are described in detail there. Pull up older posts. Check this link and select the site named above.
Jul 27, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My triniton wega tv 32 inch flashes 5 times and i lose the picture then it comes back on lasts awhile then lose the picture again flashes 5 times again over and over
you can ensure the connection and Heater's voltage, start from Flyback transformer ( Heater Pin) to Heater of the CRT tube, whether exist and normal ( Include : check Resistor in Heater area), perhaps there is lost connection for a while and connect gain. There should be 5 Volt AC available. otherwise check the socket of CRT Tube, unplug and clean it. If there is any question you can ask me and clarification with detail result from my solution.
Aug 21, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv35s26 TV: no picture, audio works, stanby light blinks.
First a couple of questions:
1) Does the standby light blink continuously or is there a repeating pattern?
2) If there is a pattern, can you please post the blink count?
With the above information, I should be able to provide you with a couple of possibilities as well as a few tests to perform. Please update this and we'll continue to try and resolve this.
Jan 19, 2009 | Sony KV-32FS13 TV
TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Dec 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Picture flickers on and off
Sounds like a typical sony that has a cold solder connection in or on the horizontal driver transformer or the output transformer. If your not a tech I woulf HIGHLY advise that you take or call an expert in to assit you with this repair . Good Luck
Jul 25, 2006 | Sony KV-32S26 32" TV
When you say flickers?? does the sound stay on or does the whole set go on then off or is it just the picture that flickers on and off and sound does flicker too? need more info please.
May 06, 2006 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Standard (CRT) Televisions Logo
95 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
