Question about Electrolux Centralux Vacuum
Blockage I have a blockage in the hose - how do I get it out - i have tried broomstick - too short. or so i need to call a repair man - where do i look to find a repairman for this vacuum-
Lay out hose straight, get a friend, wrap a rag around the wall connection end to make a seal start a vehicle with an accesible tail pipe, quickly place hose end over tail pipe apply pressure, have a friend quickly step on the gas ( floor it, briefly) it has always blasted kids socks back out for me
Posted on Feb 04, 2009
    President:
  • 1,462 Answers
Get a longer poker - bamboo for example and clear it that way. there is no magic
Posted on Apr 24, 2007
Decreased suction for filterqueen vacuum
Put a broomstick or such down the hose, something may be stuck. Look inside with the bag out, is there a screen before the motor?
Dec 01, 2013 | Filter Queen Majestic Canister Vacuum
I can not get machine to distribute the water out
see the videos from bissell and proceed according :http://www.bissell.com/how-to-videos/ others help
normally you must check : tank full, maybe full need to emptied, or blockage, repair. Test the pump-motor for blockage too, and repair.+hose blockage too.
God bless you
Jul 15, 2012 | Bissell Vacuums
My Dyson DC07 vacuum works on the floors, but when I pull out the extension wand the coiled hose attached to the wand collapses and no suction goes through the hose?
Hi there, it sounds like you have a blockage in the hose. I have made a video to show you how to get the hose off and linked it to this answer. It is possible to split the hose in places trying to get the blockage out so try not to be rough. If you do damage the hose you will need to buy a new DC07 hose it is a waste of time trying to repair. If this was a helpful answer please take a moment to rate it or leave a testimonial.
Feb 20, 2011 | Dyson DCO7 Animal Bagless Upright Cyclonic...
When the hose is used the cleaner looses suction and the hose contracts. what could be causing this?
There is a blockage in the hose somewhere. Disconnect all of the hose sections (make note of how they all fit back together) and check each one individually for blockages. The straight sections can be done visually by looking through them towards a light source, e.g. a window.
The hose section can also be inspected visually if you compress the stretchy part into a straight line and also look towards a light source. If you can't see light through any section, you have probably found the blockage.
Pay particular attention to the point where the hose enters the vacuum at the back near the bottom. After releasing the hose from this connection, also check inside the fitting that the hose attaches to the hoover.
Once you have found the blockage you will need some kind of rod to remove it. This may be easy or difficult depending on where the blockage is. Basically, you need something about 2 feet long, fairly thin, stiff, straight and - most importantly - blunt ended so it will push the blockage out (rather than pierce through it) and also will not damage the flexible hose. I generally use a section of wooden dowel.
Once you have removed the blockage, reassemble the sections of hose and you should have suction again.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My DC vaccum it doesn't have any suction, only when i disconect the hose
chances are that the hose has some type of blockage. Take the hose off and look throught it to see if you can see light at the other end while holding it all straight out.If there is a blockage you can try to hook the hose to the exhaust of the unit and blow the blockage out and if this doesnt work try blowing it out with the exhaust from both ends of the hose. Lastly if this does not work you can use a coat hanger , straighten it out and veryh carefully push it in the hose and try po push and or oull the blockage out that way. good luck and be gentle with hose as it will puncture from the coat hanger if you are not careful.
Oct 07, 2010 | Dyson Vacuums
Light keeps coming on saying bag full but its not
Almost certainly there is a blockage in the pipes leading to the bag compartment. This will cause the red light to come on, and it will lead to the motor cutting out from over-heating (as there's not enough air flow to cool it). To test that the light is working correctly, you can unplug the flexible hose from the top of the bag compartment then switch the machine on. The red light should be off, but will come on if you block the hole with your hand. If that test shows the light is working, you need to search for a blockage - which is most likely to be in the flexible hose, but can be in the rigid plastic tube or in the base of the machine (turn it over and look in the little trap-door). Clearing a blockage from the hose can be difficult - you are more likely to be successful if you can devise a way to pull it out rather than trying to push it (as with a broom handle, for example), because pushing may just compact it.
If you need more help, just post a reply here. Good luck!
Apr 04, 2010 | Sebo X4 Bagged Upright Vacuum
Red light comes on saying bag full or clogged. Bag has only recently been changed so what do I look at next?
You look for a blockage - almost certainly in the flexible hose. Remove the hose from the machine completely (both ends, that is), then switch the machine on and the red light should not come on unless you block the hole on the top of the bag compartment with your hand. Then you need to investigate the hose, to find and remove any blockage. This is not always easy. You can try sucking a blockage out, back the way it came in, either with a second vacuum or simply by reversing it on your Sebo as best you can. This will often pull the blockage to the point where you can get hold of it with pliers or a bent wire or the like. Unless all else fails, and you get desperate, don't try pushing a blockage out with a broom handle or anything like that as you will probably only consolidate the blockage. You should also check in the little trap-door on the underside of the base to make sure all is clear there.
If you need further guidance, just post a reply here and I'll answer as soon as I can. Good luck!
Mar 26, 2010 | Sebo X4 Bagged Upright Vacuum
No suction
well, it actually sounds like there is a blockage. Try removing your hose and dropping something through it, like a quqrter. If it comes through, no clog. If it is clogged, I believe that machine has a blower on the upper part of the cleaner (maybe in the bag compartment towards the top. You can take out the filter holder and plug the hose in there and run the unit . Does the blockage come out? If not, Try shaking the hose, or you can put a stiff wire in it to try to free it. Do not run water through it. If there is no blockage at all, then you will probably need to take it to a service center. But I am pretty confident that we are looking at a clog situation. Let me know if this fixesya! Thanks, Rene (vacuum Doctor)
Nov 14, 2009 | Miele S514 Solaris Electro Plus Vacuum
My Kenmore Progessive vacuum wand does not have any suction. How can I repair it?
Detach the wand from the hose and see if you have suction from the hose itself. It is more often the blockage is in the corrugations of the hose than in the wand, but also check the elbows of any tools attached to the wand and look thru the wand itself..
Anything caught in the hose should be sucked backward with another vac.
Try opening the dust container, remove the bag if there is one and drop a coin through the hose to locate blockage. The coin will come to rest against the blockage if there is any or drop thru..
If you shake the hose you will locate the blockage by feeling the vibration of the coin against the wall of the hose.This will pinpoint your problem area.
Caution rough use with a wire coat hanger could damage the hose and broomsticks get stuck. Use another vac if the hose is blocked.
Sep 13, 2009 | Vacuums
Electrolux Centralux Vacuum Logo
95 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
