Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washing machine i would like to know if we can just run the cold water in to the machine it is a whirlpool american collection ultimate care 11 thanks
  • Kris Seymour May 11, 2010
    Hi Well you could just run cold water into it but it wont clean anything! Is this the commercial spec? If so it will need to be connected to hot and cold as they dont have heaters and rely on both water types! Most domestic type top loaders have heaters but i would need the model number to be 100% certain....
    Scholar:
  • 86 Answers
Hi, I have been searching all the whirlpool websites and now see what model you have! You can run your machine on cold water by using a Y Piece connector. Just connect both hoses to the connector and then connect it to the cold water inlet. Your machine does have a heater and 5 heating programms so you have no problems....
Hope this helpfull.?
Posted on Dec 30, 2008
  • Whirlpool Master
  • 3,463 Answers
If it is a hot and cold fill m/c, then you can just use it from cold water.
You would need to fit what is called a Y piece connector , this supplys water to both hot and cold valves regardless of what prog you select..
You connect the cold supply to the straight leg of the connector, and the hot and cold to the other 2 connections.
Plz rate this solution.
Thanks.
Posted on Dec 28, 2008
I load washer it starts the wash cycle it goes through wash cycle fine drains water but does not collect water for rinse cycle it just idles. So I turn knob to spin and it spins until done.
If it doesn't fill for the rinse, I would say that the cold inlet valve has failed. Check that the cold tap is turned on and check when the machine fills for the wash cycle and see if it is taking hot or cold water. You will probably find that it is filling only with hot water. A local spares store should have the valve you need.
Sep 17, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
Standard washing machine hoses dont seem to fit my Whirlpool Ultimate Care II washer? Do I need an adaptor of some sort....
The Whirlpool Ultimate Care II is an American top loading washing machine and requires different hoses available from Whirlpool.
May 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Hot water on cold washes
To solve this problem simply reverse the water hoses from the way that they are set up currently. Then do a test again to make sure that when you select HOT you are getting HOT.
Nov 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How do i clean the Whirlpool Gold american collection top loading washing machine? I can see no filter to remove and the inside of the tub is getting dirty. The holes inside the tub at the top seem to be...
Dumped even more HOT HOT HOT water while poking around inside dispenser. Softener dispenser suddenly became unclogged and water began running out of the opening showing me that the dispenser was indeed clogged with softener buildup.
Sep 20, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine not heating water
yes it will work but unless you have hot water going into the machine there will never be hot water there but you can just use it with cold water will not hurt anything just no hot water
Mar 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool american colleretion
Hi, Yes you can run this appliance on just cold water using a Y piece... Just connect the 2 hoses together on the Y piece and connect to the cold water!!.
Good luck and happy washing.......
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Cold wash
Hi if this intended to be used in a commercial environment then it will need to be hot and cold water supplied as commercial machines do not have heaters! I can tell you for sure if you give me the exact model number..
Dec 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer ultimate 11
probably bad fill valve ..if water continues to run in when machine is off valve may not be shutting off completely due to trash if screen in cold inlet has been removed to clean and not reinstalled trash can enter valve and prevent complete shut off ..remove 2 screwson back of console pull console forward and roll back pop 2 clips 1 each corner remove lid switch plug cabinet will lean forward and off to acess valve
Sep 02, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
82 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
