Question about Datamax DMX I-4206 Printer
Printer does not print after change of Printerhead
After changing a new printerhead on my Datamax I-4206 printer nothing seems to be printing. I had checked the cables, had also unplug the cables and replug it in, tried to do quick test but nothing print. Someone please help.
  • 96 Answers
Put the original printhead back in and test. If the original printhead prints even with missing elements then the new printhead may be bad.
Posted on Oct 13, 2010
How to make printer print
Take the print head on and gently tap the nozzles on a paper towel.If you see all the colors and black then unplug the printer after the printhead is out and the carriage travels to the end (capped0
Wait 30 minutes and re-install the head.
This hopefully will make the printer believe it is a fresh unit
Aug 21, 2014 | Canon PIXMA MP610 InkJet Printer
Brother DCP-130x - unable to print, error code 4F - How to fix it?
unable to print 4f means, theirs a problem in the printer head.. the best solution for your printer is to replace new printerhead.
Oct 24, 2017 | Brother DCP-130C InkJet Printer
My esp 3 kodak printer now has a printerhead problem after a year of use. When the printer does it's power up check I get a error with the ink cartridges indicator light lit up. When I remove the ink...
Your printer needs a service, in other words the waste ink sponges need to be cleaned and dried. They then need to be replaced and the printer reassembled. Then the Epson counter resetting software needs to be installed.
With this software the printer can be set to zero, it will work perfectly after this bit of attention.
It is a good printer, it's nothing that can't be repaired.
A computer technician will be more than happy to service your printer for you.
All the best!
damnor01
Feb 01, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson LX 300 printer. every line, starting
Try to check your printerhead it could be damage due to over use or old printerhead. Just replace your printerhead to print it normal.
May 29, 2010 | Epson LX-300 Matrix Printer
Black ink does not print
If your printer have a separate printerhead with the cartridge just try to replace the printerhead of that printer it is because the printerhead have a problem on that.
May 28, 2010 | Brother MFC 240C All-In-One InkJet Printer
The red prints just under the blue, everytime you print blue, creating a shadow. if you print red only, the letters look as if they are out of alignment.
Just align your printerhead by clicking the maintenance on the printer then click the printerhead alignment and follow the steps of how to complet the process.
May 27, 2010 | HP LaserJet 2605dn Printer
Will not print---all I get is a blank paper
Try to check the ink of your printer that they have more ink inside. Or els just check the printerhead of that printer its maybe that was a problem for that. If they could not print at all after this solution just change your printerhead it is because that was the problem. If your printer are using the built-in printerheat from the cartridge just replace the cartridge of what color are did not print but if your using separate printerhead of your cartridge just only replace the printerhead only.
May 27, 2010 | Dell 926 All-In-One InkJet Printer
MP 730 Printer alert flashing "wrong cartridge"
I had the same problem. I removed the cartridges and then the printerhead. I cleaned the printerhead with a piece of cloth and then replaced it and then the cartridges. This seems to have fixed the "wrong cartridge" problem for now. I was told by a friend that if the problem persits, replacing the printerhead may be a more permanent solution, but no guarantee.
Mar 05, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Datamax M-4206 printing too slow
The way you can do this is to use Datamax fonts in your LabelMatrix program instead of truetype fonts like arial or times new roman. After making this change, do a test print and see if print improves. Another possible solution is use USB instead of Parallel cable (if you're not using it already).
Aug 25, 2008 | Datamax M-Class Thermal Printer
Datamax DMX I-4206 Printer Logo
254 people viewed this question
Top Datamax Office Equipment & Supplies Experts
rongg
Johnathon Muise
Level 1 Expert
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
